Slinger... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-16-2008, 12:58 PM   #1 (permalink)
Member # 115241
Send a message via AIM to varsis
Slinger...
I am going to put the bearing on the Pinion and want to know, if I should put this on or not. The rear set never had on and the front had one... Should I put one on both? Or is it best to not put them on at all?
Put them on the ones that had one and not that didn't? I am unsure on this Just wanted some clarification.
Chris
1997 Dakota, 4x4 green almost on 38's with 5.38 gears! and shift kit, with 5.9L mag. 64" deavers rear.
[URL="http://4wheelin.ca"]http://4wheelin.ca[/URL]
varsis is offline   Reply With Quote
Old 10-16-2008, 01:27 PM   #2 (permalink)
GMCTruxrule's Avatar
Member # 51243
If it came with the slinger, put it back on.
If it didn't, oh well.
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR]
GMCTruxrule is offline   Reply With Quote
Old 10-16-2008, 02:37 PM   #3 (permalink)
Member # 115241
I am regearing it, and want to know if I should put the slinger on both axles or just the one that had it before..
Old 10-16-2008, 03:12 PM   #4 (permalink)
Member # 51243
If the axle came with an oil slinger, put it back on. I mean, you don't HAVE to if you don't want to, you would have to mic the thickness and then add that amount in shims. But I would put the slinger back in.
Now if your other axle doesn't have an oil slinger, (and some don't) don't worry about putting one into it. Unless of course you run a steep pinion angle which a slinger will help keep the pinion bearings oiled.
Old 10-16-2008, 04:14 PM   #5 (permalink)
Member # 115320
Hey GMCTRUX i think you're using too big of words
ORWDon is offline   Reply With Quote
Old 10-16-2008, 06:23 PM   #6 (permalink)
Member # 115241
IL put the slinger on to help with oiling, not sure on the angle, but it will be abit...
Old 10-16-2008, 06:59 PM   #7 (permalink)
Member # 87058
The rear doesn't take a slinger. Don't put it on.
JGVABronco78 is offline   Reply With Quote
Old 10-16-2008, 09:46 PM   #8 (permalink)
Member # 51243
Don, be quiet and go back to your old folks home.
Old 10-17-2008, 08:26 AM   #9 (permalink)
Member # 115320
LOL GMC when you coming back to dago so we can harass each other in person?
