Timing issues
Hello all,
Thought I'd see if there is any advice to be given on this one. 78 K10 350 My truck ran great when I first got it a few years back. About a year ago when I took it off the road it ran like total crap. I replaced the extremely worn timing chain and cogs. Timed it and it still bogs under load and back fires. I figured I had better replace the vacuum advance as well as it doesn't seem to be advancing when it should so that what I did today. Then timed it again. I checked the vacuum port on the Q-Jet as well and it pull vacuum when it needs to. Its much better but far from perfect/the condition it was in when I got it. I can get it up to 4K without much problem but still get some hesitation and the occasional backfire. The last thing I can really think or would be the cap and rotor. I replaced them close to a year and a half ago. When I popped them off the brass was somewhat corroded. Its just about 0 degrees here... I wish the truck would fit in the garage
"I'll gladly pay you Tuesday for a hamburger today" |
Member # 51243
Check/replace all the usual. Plugs, wires, cap, rotor.
If this motor is old(er) I'm gonna bet you got a burnt exhaust valve or flat cam lobe. Or both.
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR] |
AllUpInYourFace
Member # 72951
As far as timing goes, check your harmonic balancer and make sure the outter ring hasn't slipped. This would cause the timing marks to be off. It sounds like a strange thing to happen but this is exactly what happened to a friend of mines truck.
Well a small update,
It's currently 7degrees advanced. I replaced the cap and rotor. It ran much better. I'm going to pick up a coil, plugs and wires tomorrow and check the harmonic balancer... Good call I would have never thought of that. I dragged something home today for $100.00 tonight though 1990 Suburban 10bolt/Corp14SF 350/Turbo 400 Tranny is blown as well as the rear axle but hell for $100.00..... steal ![]() Here's some pics http://s463.photobucket.com/albums/q...rdferguson184/
Member # 88672
another thing to check is the springs on the advance weights in the distributor. I had them break/rust away on me before.
A... truck... kinda ... with stuff in it... |
