33/14.00/15 boggers. how low of psi can i go? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-29-2008, 04:43 PM   #1 (permalink)
POOPSMITH
abig84's Avatar
Member # 88383
just wondering if anyone is running this set up how low can i go without bead locks without busting a bead every 10 minutes like i used to do with my 33/12.50 a/ts on the same rims?
i have them filled up to 25psi now just to seat the beads and it looks like they are basically ridding on the middle 2inches
edit... 10 wide rims
Originally Posted by Lance View Post
Since you perverts have a billion porn videos posted in the TP, I've disabled the function in the TP. It works everywhere else.
abig84 is offline   Reply With Quote
Old 12-29-2008, 05:19 PM   #2 (permalink)
Member # 45049
Talking Tires...
Depends entirely on how much pr0n you have loaded in the back...
Seriously... Anything under about 10 psi and I'd be looking at a set of beadlocks. Money well spent, you can go as low as you want then.
80 F150 roller cam 5.0 with GT-40 heads Locked F/R 33" BFG M/T KM2's and a heavy right foot...
You break it then I fix it... Professional Mechanic
4x4mechanic is offline   Reply With Quote
Old 12-29-2008, 05:54 PM   #3 (permalink)
Member # 54522
i have heard that skinier tires keep the bead on better.
i ran 10 psi in the rocks on 35x12.50x15 on 15x8s. now i have bead locks and run around 4psi in snow.
you could just air down your tires a little extra and see how it goes, just stay close to the compressor.
86 4runner 7MGE bobed, exo, SAS on 38s, 5.29, fully locked with duals/4.7 and 30spl longs
dopeassjackson is offline   Reply With Quote
Old 12-29-2008, 06:09 PM   #4 (permalink)
POOPSMITH
abig84's Avatar
Member # 88383
one thing at a time. it took me 9 months to buy real tires. maybe another 9 months and ill get some beadlocks
Old 01-04-2009, 02:05 PM   #5 (permalink)
Wild Hare's Avatar
Member # 75473
if your running boggers you are obviously mudding so you can safely run 10#'s without issue. any crawling that would include any sidehilling or the like then anything under 15 would be marginal
lead or follow, it doesn't matter. Just get the F@#$ out of my way!
Wild Hare is offline   Reply With Quote
Old 01-04-2009, 03:31 PM   #6 (permalink)
POOPSMITH
abig84's Avatar
Member # 88383
eh, not exactly mudding. ocasionally i have no choice but to bounce into a hole or two but its mostly like hill climbing, dirt,trails, technical kinda garbage. i ran them new years day with 20psi in them and managed to blow a bead somehow... figured one had a slow leak but it held 20 for 3 days and just checked it today after sealing the bead and its still at 20
