1995.5 s10 blazer ignition - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-09-2009, 01:43 PM   #1 (permalink)
Member # 94383
wiring mine to the cad 500. had to get out a volt meter. Found the accesory and run wires, and a start wire. on start all other wires die, this one goes to 13/14 volts. but in run its also on. doesn't that mean that the starter is on, then is on just a little slower after start? from the schematic i found yellow (this live/more alive) wire is the one that is supposed to go to the neutral safety switch then the starter. have i just misunderstood ignition systems all along or is this weird?
mrarmyant is offline   Reply With Quote
