Member # 4886
Chevy engine replacement questions
My camper/tow rig is a 76 Chevy with a carbed 350. Long story short I ran it low on oil and smoked it. Now I want to replace it but it seems that I can find more EFI donor trucks than carbed ones around here so I figure maybe running EFI might give me a few MPG.
From searching through the Chevy FAQ (which is woefully lacking) I have noticed that the TBI motors are very common and pretty easy to setup. What years were the TBI motors and are they all the same or do some years have some differences that I want to avoid? The truck has a TH350 transmission right now. Can I still use it or will the TBI motors not work properly with it? (electronic issues?) And finally, if all else fails, is it possible to just switch a TBI motor to carb by swapping the intake? TIA. Sean
I'm gonna drive it 'til the wheels fall off and burn. I'll die when I'm DONE! |
#3 (permalink) | |
Tactical Turtleneck
There have been lots of tbi swaps and conversions over the years. I would stick to the 7747 ECM, was used '89-'91 IIRC. Those are tuner friendly and there is lots of tech on the interwebs about them.
You can keep your th350, or swap to a 700r4 that has a lockup converter and overdrive. The ECM will run the lockup.
only a few intake manifolds work, i beleive only edelbrock and weiand make the carb manifold that works on that head. or you could try a normal manifold and figure out a way to wedge the intake bolts near the egr crossover port in the head.
74k20 with 6bt nv4500, 203/205, d60, 14bolt, lots of metal and booger welds... one of these days. |
Member # 41969
There was one year that was a tbi style motor with a carb intake. I have one of those stock intakes if you need it.
08 LTZ Duramax Top Shop Champion Spring 2006-Team Toumbs Repair Top Shop Champion Fall 2006---Team Toumbs Repair Originally Posted by Dan Dibble "In my opinion this is a motor sport so I like to have one. Any more questions " Dan |
