Identifying and questions - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-13-2009, 03:44 AM   #1 (permalink)
Member # 123509
I have a few thing i need help with. I just need some help identifying my T case, and how hard are they to inspect and work on yourself. I am a mechanic inclined person also my brother is a 5 year now diesel mechanic. Also weather my axle is a 10 bolt or a dana 44. And the last thing is that do I need special tools to or feller gages to rebuild my Th350. Thanks for your help here are some pictures
1979 Chevy K10 4x4 soon to be 4inch lift with DANA 60 14FF, 205
chevyforlife502 is offline   Reply With Quote
Old 05-13-2009, 06:18 AM   #2 (permalink)
Member # 103442
Send a message via AIM to GreatWhiteXJ
T-Case is a NP203 I think...axle is a 10bolt.
XJ on 42's
GreatWhiteXJ is offline   Reply With Quote
Old 05-13-2009, 07:41 AM   #3 (permalink)
Member # 13786
You got it right
KWTMECH is offline   Reply With Quote
Old 05-13-2009, 09:23 AM   #4 (permalink)
AllUpInYourFace
mudskipper4x4's Avatar
Member # 72951
Yeah you can wheel that 203 but once it gives you problems I would suggest swapping it out with a 205 before you put any money into it.
Im not sure about the feeler gauges or special tools for the th350 as I've never rebuilt one but maybe someone will chime in.
76 CJ-7... mostly chevy parts
www.centexoffroad.com
mudskipper4x4 is offline   Reply With Quote
Old 05-13-2009, 12:02 PM   #5 (permalink)
Member # 123509
Thanks guy thought i was a 10 bolt. Why would i be better with the 205? How much would i cost and do i need to change anything else.
Old 05-13-2009, 12:12 PM   #6 (permalink)
AllUpInYourFace
Member # 72951
The 203 chain will stretch out eventually and it wont work right.
a 205 is all gear driven, so it's stronger. You can get the 205 and adapter for $150 give or take a little.
Wheel it till it breaks and then swap to a 205. That's what I'd do.
Old 05-13-2009, 12:26 PM   #7 (permalink)
Member # 106427
Well with this and your other thread. From what I think that you are doing you will be fine. The 205's are better than a 203, but it not that a 203 is completely junk. I ran one on my race truck for years without problems, plowed snow, shoved around cars...ect.
If you are just replacing the clutches and steels in your trans then you will not need any specialy tools, a little ingenuity will get you through. If you are doing a complete rebuilt, then yes you will need some specialty tools.
later
jenks
jenks21 is offline   Reply With Quote
Old 05-13-2009, 03:11 PM   #8 (permalink)
Member # 123509
Well i am woundering weather i should take the 203 apart cause it off my truck. My brother said he put it in grear and it poped out i am just thinking that it was in far enough. Do you think it worth taking apart or should i put her back in and try it out with new gear oil.
Old 05-13-2009, 04:24 PM   #9 (permalink)
Member # 106427
Stock transfercase shifters for these bring the suck. They wear out over time and if you don't bunge strap them in gear they pop out. They seem to be worse in four low. You can make a twin stick or get one from ord that will solve the problem.
later
jenks
Old 05-14-2009, 03:26 AM   #10 (permalink)
Member # 123509
Thanks. guys i am going to look into the stick.
Old 05-14-2009, 03:30 AM   #11 (permalink)
Member # 123509
Ment to ask what year and style of trucks are the 205 in? Thanks
Old 05-14-2009, 07:21 PM   #12 (permalink)
Member # 123509
anyone
Old 05-15-2009, 01:29 PM   #13 (permalink)
What did you expect?
HAPPYJOHN's Avatar
Member # 119290
Late '70s 3/4 & 1 ton GM trucks usually, I know there are others....
HAPPYJOHN is offline   Reply With Quote
Old 05-15-2009, 02:30 PM   #14 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
69-91 square body blazers, burbs and trucks.
Old 05-15-2009, 04:48 PM   #15 (permalink)
Member # 123509
Thanks guys how are the 241 C T-case or is the 205 better? Also will the 205 work with my axles?
Old 05-16-2009, 08:08 AM   #16 (permalink)
Member # 123509
Bump
Old 05-16-2009, 10:15 AM   #17 (permalink)
HAPPYJOHN's Avatar
Member # 119290
Each has good&bad points; 205 is stronger, 241 has lower low range.
205 is all iron case, 241 aluminum. so it really goes back to priorities
and determining how you're REALLY going to use the truck.
Old 05-16-2009, 10:16 AM   #18 (permalink)
HAPPYJOHN's Avatar
Member # 119290
?? My '83 had a 208, my '89 & '90 both had 241s ( all K-5s )
Old 05-16-2009, 03:52 PM   #19 (permalink)
AllUpInYourFace
Member # 72951
They aren't in every truck k5 or sub from those years but they can be found throughout those years in some of those vehicles. Usually put more in the 3/4- 1 ton trucks but in 1980 all of them had np205s. fyi
Old 05-16-2009, 06:50 PM   #20 (permalink)
Member # 123509
I think i would be better off with the 205 it going to be a DD trail little rock and mud truck. later on Dana 60 and 14ff
Old 05-16-2009, 11:20 PM   #21 (permalink)
Valley Auto's Avatar
Member # 78079
keep the 203 that matchesyour trans and double it to a 205 for the pimp setup. offraod designs pionered this setup
Master of the wire Wheel!
Coastal Fabrication the " best damn shop in town"
Poly Performance
Pacific Fabrication
http://www.pacificfab.net/
Valley Auto is offline   Reply With Quote
Old 05-17-2009, 10:49 PM   #22 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
so, i have a 78 with power windows and a pull cable hood latch, not every vehicle was equiped the same.
Old 05-18-2009, 05:10 AM   #23 (permalink)
Member # 123509
What the point of doubling them up I see a lot of guys do this.
Old 05-18-2009, 06:17 PM   #24 (permalink)
Member # 106427
Give's more gear selection. I believe, and know that I am wrong, but i think it would give you around 4:1 low if you had both cases in low range. The crawler guys could give you a little more insight than I can.
later
jenks
Old 05-18-2009, 07:46 PM   #25 (permalink)
AllUpInYourFace
Member # 72951
^^yup pretty much, gives you a 1:1, 2:1, and 4:1 gear selection. Just helps with the crawl ratio.
