1995 chevy tahoe front axle problems can any one give me a idea on what it may be - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-02-2009, 10:08 AM   #1 (permalink)
Member # 136731
My transfer case is good and my accuator is new but it will not go in to four well drive has anyone had this problem.
Chevyde1 is offline   Reply With Quote Quick reply to this message
Old 06-02-2009, 01:34 PM   #2 (permalink)
glenns89's Avatar
Member # 94897
I am not sure you will get the answers you want in here. I would try maybe in tow rigs or general??? Or maybe on gmfullsize.com. You can get alot of good info in here if you want to put a solid axle under it and wheel the piss out of it. Not really the place for questions like this. Good luck. I hope you find your fix.
89 jimmy D60/ff14bolt/400/203/205. Detroit front and rear
glenns89 is offline   Reply With Quote Quick reply to this message
Old 06-03-2009, 04:06 AM   #3 (permalink)
Poseur SUV
Paul Gagnon's Avatar
Member # 610
Send a message via ICQ to Paul Gagnon
moved from chevy
Paul Gagnon
Sherwood Park, Alberta eh?
"No Brain, No Pain"
Paul Gagnon is offline   Reply With Quote Quick reply to this message
Old 06-03-2009, 04:23 AM   #4 (permalink)
Member # 130335
Are the axle shafts seated all the way in the housing? I once had that problem, wouldn't go into 4x4. I could actually pull the CV towards the wheel and see axle shaft. Stupid IFS.
If you actually wanna wheel ditch that independent garbage and straight axle it. I've broken the front way too much on my '90 Chevy so I bought a Dana 60 and I'm currently doing the swap.
MegaCPC is offline   Reply With Quote Quick reply to this message
Old 06-03-2009, 02:02 PM   #5 (permalink)
joshgammill's Avatar
Member # 123460
Get another accuator, I had to replace mine once and the parts store gave me a bad one. Not all that uncommon to happen.
joshgammill is offline   Reply With Quote Quick reply to this message
Old 06-03-2009, 03:38 PM   #6 (permalink)
Member # 126903
X2
Those actuators are notorious for going bad.
Quick test: Use a test light and make sure you have power going into the actuator when you put it into 4 wheel drive.
No power = Bad relay, loose connection, short, blown fuse, etc....
Yes Power but no 4x4 = Bad actuator.
Sometimes my thoughts get bored and wander down to my mouth. Often, this is not a good thing!
Beener is offline   Reply With Quote Quick reply to this message
Old 06-03-2009, 05:28 PM   #7 (permalink)
Member # 134442
Is it lever shifted or pushed buttoned. My aunt had one that the push button went bad
welderman420 is offline   Reply With Quote Quick reply to this message
