Finding a vacuum leak
I'm having a problem with a lean condition with my EFI setup. I've hosed it down with carb cleaner and used a MAPP gas torch trying to find a leak and did not. I also did a compression test, which came back good, and leads me to believe the HG is not blown. The bad new is that I should not start and run the vehicle because the tcase had to go back to AA for repair (auto trans). Anything else I can check or tests that I can do? Chevy SBC, if it matters.
[COLOR=Red][SIZE=4]ECV 7-11[/SIZE][/COLOR] Serving up a Tsunami of Swagger |
No booster, twin willwood manuals. Would it be possible to ahve a leak on the inside of the galley and have it scavenge air from within the engine? About the only place I can think of at this point, but hate to tear it down again on a hunch.
Member # 37184
I've read that you can test for vacuum leaks under the intake manifold by injecting propane into the valve cover.
Personally, I find that approach a little "scary". Give it try, and report back--if you are able!!
88XJ, Chevy 5.7L, Edelbrock MPFI, NV4500, Atlas, D44's, high steer, ARB's, 7" custom semi long-arm 3 or 4-link lift, BFG 33x12.5-15's. |
#7 (permalink) | ||
Tactical Turtleneck
I wouldn't worry about the PCV, it is supposed to pass air from the engine into the intake. Do check that your injectors are working, with TBI you can use a timing light. Otherwise, you can use a meter to make sure you have power to all your injectors. (GM TBI supplies power to the injefctors, and the ECM grounds them.) Check your fuses, too. I worked on a motor with a lean condition, turned out to be bad wiring to the injectors.
MASTER TECH
Member # 54844
he is running a massflow setup now - i think its the same one ?
wilson ? lean when? at idle, off idle - cruz, WOT ?
BSW Racing, Calrocs Super mods 12 & ? Driver: Aaron Whitehead - Driver: Joe Hutchins Spotter: Adam Kovarik - Spotter: Dustin Knight Crew Cheif: me fuckers ![]() build up of the truggy /forum/ford/544813-update-pics.html Last edited by f250rollinon37s; 06-22-2009 at 08:15 PM. |
