need 3 inches for rear axle - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-25-2009, 07:43 PM   #1 (permalink)
POOPSMITH
abig84's Avatar
Member # 88383
i have a crummy thin aluminum block in the back now for mock up and the truck sits perfect.... i have some solid steal 3inch blocks in the back of my other offroading truck that i got with a parts truck. who sells solid steal blocks for the rear? or what other options do i have for the rear.
i was reading shackle flips give 4+ inches so thats out of the question.
85 k30 1 ton springs
Originally Posted by Lance View Post
Since you perverts have a billion porn videos posted in the TP, I've disabled the function in the TP. It works everywhere else.
abig84 is offline   Reply With Quote
Old 08-25-2009, 07:54 PM   #2 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
i have a few sets of 4" ish cast/forged blocks at work, can be cut down
callVVVVVV
Old 08-25-2009, 08:23 PM   #3 (permalink)
b454rat's Avatar
Member # 16536
ORD has a 2.5" shackle flip, I have one on my truck right now.
b454rat is offline   Reply With Quote
Old 08-25-2009, 08:36 PM   #4 (permalink)
What did you expect?
HAPPYJOHN's Avatar
Member # 119290
I have two 4" steel/cast iron? off a 77 gmc 3/4 ton,
let me know.
"Safety and security mean nothing without liberty." JamToy.
History teaches that all conquerors who have allowed their subject races to carry arms have prepared their own downfall by doing so.
-- Hitler, April 11 1942
Originally Posted by Roxywheels View Post
...... Shove a tissue in her nose, don't kiss her and hump on. ......
HAPPYJOHN is offline   Reply With Quote
Old 08-25-2009, 09:45 PM   #5 (permalink)
Member # 140549
you dont even need the shackle flip kit,...just take you old shackle off cut a hole out of the bottom of the hanger and move your leaf spring and shackle under the hanger thats what i did to mine,..just remember not to cut to much out,....mine has been drove to hell and back,..no cracks or anything
fultorn is offline   Reply With Quote
Old 08-26-2009, 12:51 PM   #6 (permalink)
Member # 123436
I know and have seen what you are talking about and most seem to hold up but.......GHETTO!
I'd go with the 4" DIY flip in the rear and put a Zero Rate under the front springs to make up the difference. Then you should be level from the info you gave.
You said 4" would be too much and make the rear higher than the front, right? Was your measurement level at 3" with the truck unloaded or if you put your tools and spares in the bed would your truck then have the rear lower than the front?
Big Blzn is offline   Reply With Quote
Old 08-26-2009, 03:21 PM   #7 (permalink)
POOPSMITH
abig84's Avatar
Member # 88383
Yea its on the ground. I actually have a 3 inch block in the back but its really flimsy and don't trust it. Wouldn't mind running a cast iron block. The truck has a bunch of crap in the bed. But probably only 200lbs of crap and that shouldn't matter on one ton springs. But I really don't want it any higher then 3 inches
Old 08-27-2009, 11:41 AM   #8 (permalink)
Snowbird13's Avatar
Member # 44136
So do a shackle flip, then take a leaf or 2 out of the pack so it sits lower. A one ton spring pack is probably too stiff for a wheeler anyways. Besides, a one inch rake isn't very noticable.
Hammers Thread post #1388
Tellico Rallypost # 285
Snowbird13 is offline   Reply With Quote
Old 08-27-2009, 04:40 PM   #9 (permalink)
POOPSMITH
abig84's Avatar
Member # 88383
probably should have mentioned, this is gonna be a daily driver/ tow vehicle type set up, thats why im worried about leaving those aluminum blocks in the back. i want to keep the 1 ton leafs.... think i might just leave them in there for a while just to see how it sits on the street and with all the stuff out of the bed. maybe ill need to go higher or lower.
Old 08-28-2009, 03:57 PM   #10 (permalink)
jrw7072009's Avatar
Member # 135054
We use Skyjacker blocks with a lot of our kits, instead of stacking the blocks of that most kit call for we replace both of them with one. They are cast one piece and they come in a few different sizes.
jrw7072009 is offline   Reply With Quote
