np 241 transfer case Q's - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-17-2009, 10:50 AM   #1 (permalink)
Member # 40759
I have a gmc 2500 with an np 241 behind an nv4500. This case has been nothing but trouble for the last few months. I want to replace it with a different one.
What I want to know is what transfer cases that I can swap in place of it. I'm not worried about reworking the mount or drive shafts. Just wanna know which transfer cases will bolt directly in it its place. I don't want to buy any different adapters to bolt it to the transmission that is.
jamesmross is offline   Reply With Quote
Old 10-17-2009, 01:15 PM   #2 (permalink)
Member # 78377
241 is a decent unit. id swap in a new one (or rebuild yours) or go aftermarket. but to answer your question a 208, 231, 300 and 261 should all fit. any of the work is worth doing is up to you
jeeplt1 is offline   Reply With Quote
Old 10-17-2009, 05:46 PM   #3 (permalink)
PAToyota's Avatar
Member # 37600
Send a message via AIM to PAToyota Send a message via Skype™ to PAToyota
What problems are you having with it? The only thing I've had issues with is the CAD (central axle disconnect) with that goofy gas expansion system for engagement. I replaced mine, but I'm going with either the electric motor or cable system if it goes bad again.
GET INVOLVED - Join the Blue Ribbon Coalition
SIGN THE PETITION - SAVETHEHAMMERS - #85
'93 Chevrolet 6.5TD K2500 NV4500 Std. Cab Longbed 170K
'85 Toyota 22R RN60 4x4 Std. Cab Shortbed 178K (Currently retired for rebuild)
PAToyota is online now   Reply With Quote
Old 10-18-2009, 03:58 PM   #4 (permalink)
Member # 40759
My problems with it are that it won't stay in 2wd and now it won't stay in high range at all. It makes clunks and grinding noises. I can get around in 4 lo right now without any noises or problems. So I guess I need to take it apart and see whats going on in there.
Old 10-19-2009, 06:16 PM   #5 (permalink)
Member # 62420
rebuild it and never look back
driver351 is offline   Reply With Quote
