help- Will 1995 4x4 gmc alum rims fit 1985 4x4? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-05-2009, 05:22 PM   #1 (permalink)
Member # 124434
Will a set of 6 bolt rims from a 1995 z71 4x4 fit on a 1984 or 85 full sized
blazer ? The hubs stick out on the 84/85 -would they fit through the 95 rims? or?
Any help appreciated- I have a set from my 95 to give a freind with a 85 or so -just wondered if they'd work?
jeep-livin! is offline   Reply With Quote
Old 12-05-2009, 05:44 PM   #2 (permalink)
Devout Newbie Hater
Grumpy_old_fart's Avatar
Member # 20147
ever think of trying it yourself to find out?
sympathy, empathy and apathy... i dont know which one is which....
But i know you can find sympathy between shit and syphilis in the dictionary.
Win this car for a whole BUCK!
Grumpy_old_fart is offline   Reply With Quote
Old 12-05-2009, 05:45 PM   #3 (permalink)
Member # 130483
yes and no
the bolt pattern is the same,its the center hole that is smaller on the z71
if they are factory rims no,aftermarket rims will fit if they have a large hole which is ~4+ inches
and watch out for the back spacing
92 S10,sm465/np208/np241,d44,9inch,spools,exo
99 Silverado,35's,locked 14b,4.8L,nv4500
92 s dime is offline   Reply With Quote
Old 12-05-2009, 05:59 PM   #4 (permalink)
Member # 124434
>me and the freind are a long way away from each other- and he needs them for tomorrow and would drive in if they worked........ Thought experienced folks here might know as a quick reference...Thought to ask the ones who would know prior to driving for hours.... but appreciate the one liner....
Old 12-05-2009, 06:00 PM   #5 (permalink)
Member # 124434
Originally Posted by 92 s dime View Post
yes and no
Thanks huge 92 s dime - Saved a fella a long drive- cant thank you enough.....
Old 12-05-2009, 06:04 PM   #6 (permalink)
Devout Newbie Hater
Member # 20147
any time...
perhaps if you invested in a tape measure....
Old 12-05-2009, 07:04 PM   #7 (permalink)
Flatline's Up!'s Avatar
Member # 103814
any time...
but then he'd have to post pics, then ask someone what the little lines ment between the number thingies and if he could get an opinion... besides, would he need a US tape mesure, or a metric one? and that little thingee on the end isn't staked down very well and he'd have to set the rivet tighter to keep it from sliding back and forth, then he'd have to go thru the instructions, pictures, and all that with his friend that lives hours and hours away, and...
and...
"but I just had a "quick question"" ALWAYS means in real words: "I just want a quick answer"
Flatline's Up! is offline   Reply With Quote
Old 12-05-2009, 07:39 PM   #8 (permalink)
Member # 24475
Send a message via ICQ to JeffsJeep04 Send a message via AIM to JeffsJeep04
and...
I'm sure you know and are just being sarcastic...but you do realize that slop in the end of a tape measure is on purpose, right?
JeffsJeep04 is offline   Reply With Quote
Old 12-05-2009, 08:00 PM   #9 (permalink)
Member # 147521
I got the same problem. I got 3-4 sets of the factory mid 90's z71 rims but they wont fit the straight axle front ends. I got a 90 K5 blazer that im trying to find a set of 16" rims to put some boggers on. Cant find a good cheap set anywhere. Tried CL for the past two weeks and after about 25 different cities i give up. Gonna put them on my 96 Z and with the 4" suspension lift i just installed on it i'm going with 35 or 36's on 15 inch rims. Good luck finding rims as 15" are plentiful and 16"s well i wish you better luck than i did.
PW69CAMARO is offline   Reply With Quote
Old 12-06-2009, 06:19 AM   #10 (permalink)
Member # 142668
I've been told that it had something to do with making up for the thickness of the hook for inside vs outside measuring, but I think they were pulling my leg!
I mud, therefore I'm a second class citizen. I can accept that.
PwrWagons4ever is offline   Reply With Quote
Old 12-06-2009, 10:08 AM   #11 (permalink)
Member # 24475
No sir, your leg is free from any pulling. That's exactly what it's for.
Old 12-06-2009, 06:28 PM   #12 (permalink)
POOPSMITH
abig84's Avatar
Member # 88383
someone gave me a set of aftermarkets off a late 90s suburban, the center hole was big enough but it had like zero backspacing and they hit the tie rods in the front
Originally Posted by Lance View Post
Since you perverts have a billion porn videos posted in the TP, I've disabled the function in the TP. It works everywhere else.
abig84 is offline   Reply With Quote
Old 12-06-2009, 09:05 PM   #13 (permalink)
What did you expect?
HAPPYJOHN's Avatar
Member # 119290
Zero backspace would mean that the back edge of the rim would
be even with the mounting face ( backside of lug holes ) I doubt
that there would be a tie rod interference issue.
Zero offset would meant that the mounting face is in the center.
offset is measured in mm, either positive(towards front of rim) or
negative,( towards backside of rim. )
( example; 8" rim with zero offset would have 4" of backspace )
"Safety and security mean nothing without liberty." JamToy.
History teaches that all conquerors who have allowed their subject races to carry arms have prepared their own downfall by doing so.
-- Hitler, April 11 1942
Originally Posted by Roxywheels View Post
...... Shove a tissue in her nose, don't kiss her and hump on. ......
HAPPYJOHN is offline   Reply With Quote
Old 12-08-2009, 09:12 AM   #14 (permalink)
bigblack75Chev's Avatar
Member # 15796
Originally Posted by happyjohn View Post
zero backspace would mean that the back edge of the rim would
be even with the mounting face ( backside of lug holes ) i doubt
Offset is measured in mm, either positive(towards front of rim) or
lmao
R.I.P. "Dimebag" Darrell Abbott
bigblack75Chev is offline   Reply With Quote
