sbc350 quadrajet idle stuck at 2700 rpm ??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-24-2009, 04:02 PM   #1 (permalink)
rockthedog's Avatar
Member # 19510
seems like a newb question to me. like the title says my idle has gotten stuck at 2700 rpm.. i have a rochester Qjet on it. i'm guessing the problem is the carb somehow as the idle seems excessive for a vacume leak (which i checked for). and i did look at the dizzy weights just in case.... so the carb gets trashed everysummer with the thick dust on the norcal trails rubicon etc. so its due for a good tear down. i've checked all the linkage , return springs etc as best as i can . just wondering if there is anything in a q-jet that could go south enough to cause this.....been doing this stuff for along time and have never had this happen . help??
i searched with no luck so for whoever was thinking it
thanks
glenn
77fj40, 1 TON
530-268-9494
tlca# 12281
semi_budget 1ton build
linking the rear
rockthedog is offline   Reply With Quote Quick reply to this message
Old 12-26-2009, 02:08 AM   #2 (permalink)
roy jones's Avatar
Member # 50585
Check the linkage on the side where the choke is. I have a older qjet with a Manuel choke and i had to zip tie the weighted part down
while you are tempting to help re-establish ballistic this just proves more to the fact they flat out don't fucking care and should be shit upon at every turn.
roy jones is offline   Reply With Quote Quick reply to this message
Old 12-26-2009, 05:45 AM   #3 (permalink)
Member # 36955
If you didn't live in california I would say this is a normal problem when it's -30 to -40 degrees, but I can't help now.
- Helping people find people.
enigma2y0u is offline   Reply With Quote Quick reply to this message
Old 12-26-2009, 10:53 AM   #4 (permalink)
mj
Member # 1919
secondary linkage hung open?
it is spring loaded
mj is offline   Reply With Quote Quick reply to this message
Old 12-26-2009, 01:04 PM   #5 (permalink)
rockthedog's Avatar
Member # 19510
i opened the flap above the secondaries to see if the the throttle was seated and it looks like it is , but the flaps arent what i would call flat, when they are seated are they at a slight angel ?-- not flat , same plain as the bottom of the throttle body. anyway i'm a two hr drive from my rig so anything i might need to check will have to waite till thurs
thanks again
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 12-26-2009, 02:50 PM   #6 (permalink)
Member # 91648
Sounds like the choke is on. If its electric, make sure it is still plugged in and getting 12 volts with the key on.
If its manual, see if some squirrels have been busy packing stuff on the intake.
Get it started, and move the weights as mentioned above downward (yellow arrow pointing to it in the pic)(its a stepped plate/linkage, you'll feel it when you move it. When you press the accelerator down before a cold start your setting the choke and the choke spring will pull this up to whatever high idle setting you have). If the idle drops down you know for sure its choke related.
Alex.
GMGuy is offline   Reply With Quote Quick reply to this message
Old 12-26-2009, 06:29 PM   #7 (permalink)
rockthedog's Avatar
Member # 19510
thanks alex that is a great description....... thurs when i go back up i'll be checking that out.
never seen a red carb!
btw mine is an electric choke like that one too
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 12-27-2009, 08:32 PM   #8 (permalink)
What did you expect?
HAPPYJOHN's Avatar
Member # 119290
There is also an outside chance that you lost one of the butterfly plate
(a.k.a. throttle blade ) screws. with engine off, look down venturis to see
if the throttle plates are centered.
Dana 60 or 14 bolt disk brake kits $315 shipped
I'd call you a cunt but you don't have the depth or the warmth.
HAPPYJOHN is offline   Reply With Quote Quick reply to this message
Old 12-31-2009, 11:06 PM   #9 (permalink)
rockthedog's Avatar
Member # 19510
Alex.
that was it! the weight was stuck in the up position. pushed it down and it idles perfect. i will test later to see if the choke is faulty or just out if adjustment.
thanks again
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
