dual toy cases oil fill - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-23-2010, 02:29 PM   #1 (permalink)
Member # 66955
Well I just finished welding in my trans tunnel and forgot to put oil in the range box(forward shift) and cant get to the access on top to put oil in without dropping the cases which involves a lot more than just that, so my question is if I put all the oil in the rear case will it flow to the range box or are they sealed from each other?
sherm$ is offline   Reply With Quote
Old 02-23-2010, 06:54 PM   #2 (permalink)
Member # 17904
there should be holes to allow for the flow of oil between the two. on the flip side, how do you take off the shifters with the tunnel completely sealed? cut the floor and install boots over them. it's easier to fill them this way.
HalfFastFord is offline   Reply With Quote
Old 02-24-2010, 02:31 PM   #3 (permalink)
95rokrunner's Avatar
Member # 97376
it will flow, once you think its topped up leave it for 10mins or so to give it time to equal then hit it a second time and go wheel
95rokrunner is online now   Reply With Quote
