4wd trouble with 75 chevy - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-31-2010, 04:01 PM   #1 (permalink)
Member # 157459
i am really gonna sound like an idiot but i would appreciate any advice and help. i got a 75 chevy scottsdale with 4wd, a straight axle, and locking hubs in the front. i can't figure out the 4wd because every time i shift into it from nuetral, there is a loud grinding sound and sometimes it will shift into 4wd from park without a problem. i just got this truck so i am not familiar with its 4wd mechanism or the locking hubs and i would appreciate any info you got on this.
75 scottsdale is offline   Reply With Quote
Old 03-31-2010, 06:38 PM   #2 (permalink)
______________
Corey Young's Avatar
Member # 21622
Is it a NP205 t-case? Do you know the shift pattern?
Corey Young is offline   Reply With Quote
Old 03-31-2010, 06:48 PM   #3 (permalink)
Member # 157459
its a 208 alluminum transfer case. the shift pattern for the 4wd?
Old 03-31-2010, 06:55 PM   #4 (permalink)
______________
Member # 21622
NP208 in a 1975, neat. Try putting the transmission in neutral with your foot off the brake while shifting the t-case.
Old 03-31-2010, 07:07 PM   #5 (permalink)
Member # 157459
Thanks for the help that was the problem as far as i can tell
Old 04-05-2010, 04:39 PM   #6 (permalink)
Member # 157459
speedo cable replacement
i have a 75 chevy scottsdale with a bad speedo cable which i am trying to replace. After unscrewing the end attached to the transfer case, i found part of the cable was torn off and stuck in the transfer case. Should i just yank that piece out or am i supposed to unscrew it?
Old 04-05-2010, 10:42 PM   #7 (permalink)
GMCTruxrule's Avatar
Member # 51243
Unscrew the cable from the gear housing. Both screw together and bolt into the transfer case. If part of the cable is stuck in the housing, pull it out.
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR]
GMCTruxrule is offline   Reply With Quote
