'01 drw f350 d60 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-06-2010, 08:17 AM   #1 (permalink)
Member # 34044
'01 drw f350 d60
is the front end out of an '01 drw f350 a d60 or 50? thanks
mark
'79 blazer on 4D's
srv8800 is offline   Reply With Quote
Old 04-06-2010, 07:43 PM   #2 (permalink)
Member # 110419
It is a 60. Ford never used dana 50 in F350.
jeeyota00 is offline   Reply With Quote
Old 04-06-2010, 07:58 PM   #3 (permalink)
Member # 131556
that's not entirely true, sometime in the late 80's early 90's ford made a ttb dana 50 equipped f350 4x4 my neighbor had one with a 460 and a 5 speed
2006 SV1000S with 6xxx miles
carbon fiber slipon's new rear tire
needs a front tire runs great $4700 OBO
rattlecan78 is offline   Reply With Quote
Old 04-07-2010, 07:09 AM   #4 (permalink)
Member # 34044
i was asking bc i found an axle on craigslist for $200. i go to check it out and sure enough, it's a d60. ended up with a new d60 for $150. thanks for the help
'79 blazer on 4D's
Old 04-07-2010, 07:43 AM   #5 (permalink)
woodchuck2's Avatar
Member # 116651
1980-1996 years TTB were D-50, straight axles were D-60. Above that i am not sure.
79 F-150 302,np435, rest of the truck has been sold and is now retired.
woodchuck2 is offline   Reply With Quote
Old 04-07-2010, 01:58 PM   #6 (permalink)
Member # 34044
there's a straight axle 50 also.
'79 blazer on 4D's
Old 04-07-2010, 08:10 PM   #7 (permalink)
Member # 131556
yes any f250 from 99-04 and the excursion all have a solid 50, in 05 ford went back to 60's for everyone.
the only difference is ring and pinion size(they are both smaller)
Old 04-07-2010, 09:16 PM   #8 (permalink)
1sicbronconut's Avatar
Member # 37866
I'm at work right now (Ford Shop) and I just got done doing ball joints on a 99' F350 and it has a Dana 50 under it. I've seen lots of single wheel 1999-2001 F250-350's with Dana 50's under them.
RIP Ein the wheeling Corgi
1sicbronconut is offline   Reply With Quote
Old 04-07-2010, 09:18 PM   #9 (permalink)
Member # 37866
This is also wrong in mid 2001 F250's and 350's got a upgrade to a Dana 60.
Old 04-08-2010, 08:45 AM   #10 (permalink)
CSP
Member # 1533
Lotsa wrong info in this thread.
F350:
80-85 was TTB D44
86-91 was kingpin D60
92-97 was balljoint D60
Not sure on the Stupid Duties as there's lotsa conflicting info out there
F250:
80-9? was TTB D44 (I don't remember the cutoff year)
9?-97 was TTB D50
99-mid 2001 was solid D50
mid-2001 and up is D60
CSP is offline   Reply With Quote
Old 04-09-2010, 05:31 AM   #11 (permalink)
Member # 131556
F350:
80-85 was TTB D44
F250:
9?-97 was TTB D50
I don't think that's correct the f350's had TTB dana50's under em the f250's got the d44 until later on like you said....I am probably wrong on the 05, 01, d60 thing, although I looked at an 02 crew cab v10 before I bought my 99 and it had a d50 up front. I didn't think everything got the 60 till they switched to coils in 05.....ford does weird shit like the light duty f150 based f250 that (correct me if I'm wrong ) has a 7 lug bolt pattern.
Old 04-10-2010, 07:56 AM   #12 (permalink)
Member # 46175
This thread is full of posts that should be deleted.
All 99 and newer "Superduty" DRW fronts were Dana 60's. It wasn't until 2002 that they discontinued use of the Dana 50 in the SRW trucks and they all got the 60 from there on.
The old TTB 50 in 1980 was F-350 only. 1981 was first year for the TTB 50 in an F-250. After 1981, you could have either a 44 or a 50 in the F-250 until 1989. All 1990 and newer TTB F-250's were the Dana 50.
An easy way to identify the 60 from the 50 is the pinion nut. A 1 1/8" nut is a 50 and a 1 5/16" nut is a 60.
USED and NEW 4x4 PARTS - (716) 984-8715 8-5pm EST
Specializing in Axles and Transfercases
Mh4Runner is offline   Reply With Quote
