Rear driveshaft - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-18-2010, 09:57 AM   #1 (permalink)
Member # 103331
Rear driveshaft
My Jeep has a Dana 300 and I need to know if I should run a standard or CV driveshaft in the rear. I have yokes for both. The rear is stretched so the driveshaft would need to be ~35" at static height. What are the advantages/disadvantages to CV driveshafts in the REAR?
Rig specs are: TJ with 350/350/300, 44 front, 14 bolt rear, leafs all around
pcampTJ is offline   Reply With Quote
Old 04-18-2010, 02:24 PM   #2 (permalink)
sucker's Avatar
Member # 147955
is this a dd or strickly trail? If it's trail, I'd say make a square driveshaft. If it's a dd I'd say standard. CV shafts are junk all the way around.
sucker is offline   Reply With Quote
Old 04-20-2010, 08:13 PM   #3 (permalink)
Member # 103331
This will be 95% trail. In my area thats muddy hills, deep ruts, water crossings, and no large rocks. Even with a square shaft I would have to decide on a yoke. Why do you consider CV shafts to be junk?
Old 04-21-2010, 03:20 PM   #4 (permalink)
Member # 99723
Moore87 is offline   Reply With Quote
Old 04-22-2010, 08:25 AM   #5 (permalink)
CSP
Member # 1533
You only need CV shafts if the operating angles of a single joint shaft are greater than their limit.
It all depends on angles and vibration.
CSP is offline   Reply With Quote
