Member # 122846
Rear Squat Problem?
I have a problem that I need some help with. I am going to upload a video and will post the url when I have it but for now I will have to simply describe the situation. Jeep Hill Trouble on Vimeo
The problem is that when I climb a hill, the front of my jeep continues to be a bit tippy and the tends to leave a tire high in the air rather than it dropping down. It continues to feel that the jeep is going to tip backwards. One tire is typically high in the air and the other is on the ground when this situation occurs. The jeep is using a coil conversion and thus I am running on coils instead of leafs and have the sway bar disconnected (when wheeling) and have the trackbar connected due to having coils. The flex of the jeep seems to be respectable for this type of a setup. I am thinking it has something to with the rear of the jeep because this situation usually occurs when the back tires are in a run or something that makes the back of the jeep squish the coils. So, it seems that the rear tires get tucked pretty high in the wheelwells and thus forcing the front of the jeep to remain high??? The suspension is a procomp coil conversion. It has short control arms, but those do not appear to be limiting me either. The coils are defienetely not maxing out in the front and I am also considering that the front shocks may be limiting me a bit. However, when I watch video's of a fellow YJ on leafs it doesn't really droop the tire any more than mine but mines seems to struggle to climb the hill and the front of the jeep keeps going backwards and I worry about tipping. So, I don't think the issue is simply a flex issue... is what I am trying to say with the note regarding the other YJ. It could be that my trackbar is maybe limiting the droop of that tire a bit but I am not sure. Maybe you guys have experience in an issue such as this. I am fully locked with ARB's, using 33's. I have had this issue numerous times and it is really bugging me. I would appreciate any information that you can provide. Let me know if you need additional photo's. Here is a link to a different photo of my jeep flexing in another area around BFE.. It almost appears that the rear flex is almost better than the front, which is sad. I am leaning toward the issue being due to the soft coils in the back (145lb/in) and then when they compress down it causes the front to rise. I am looking into maybe stiffer coils in back. Maybe the RE models at about 240lb/in. THoughts? Help! |
Member # 44086
To be honest, watching the video it appears to me that your Jeep is doing exactly what you would expect from a short wheel based Jeep on coils with a short arm lift. Lifting a front tire on the hill is unavoidable with what you are running. The tippy feeling you are getting is the steep hill and your short wheel base. Looking at your jeep, I would estimate you have around a 90 to 92 inch wheel base?
Member # 122846
Pics of the rear small, tiny, short arms...
http://cid-947f6613a773d22f.skydrive...px/Moab%202010 Yes, wheelbase of aroudn 91/92". |
