Front spool - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-07-2010, 05:40 PM   #1 (permalink)
Member # 145962
Question Front spool
Would a front spool for daily driving be out of the question if running lock out hubs?
OzarksYJ is offline   Reply With Quote
Old 05-07-2010, 07:34 PM   #2 (permalink)
Member # 145525
No.
dubya1 is offline   Reply With Quote
Old 05-07-2010, 07:51 PM   #3 (permalink)
Member # 143356
Up to you. Do you really need to on a DD? I wouldn't unless you plan on some good 4x'in. If it's just a DD and 4x is just for winter roads I don't think a spooled front would be practical. If you're in 4x and come across some bare pavement on a corner steering can be challenging.
4Xjunkie96 is offline   Reply With Quote
Old 05-08-2010, 07:05 AM   #4 (permalink)
enigma2y0u's Avatar
Member # 36955
I really hate the comment about only using one hub when you have a locker in the front on the road. IMHO, anyone who has actually tried that knows it sucks ass. So now.....
If your going to drive the truck on the street in conditions where you will be in spotty 4wd and 2wd areas all the time, then get an autolocker and lock both hubs when you need 4WD.
Now, If the ONLY time when you need 4wd on the street it's cause the SHTF and you really need 4wd then buy a spool and put that it, just don't use it on pavement AT ALL. Either full blown blizzard, no food for the baby, need to make a survival trip weather or no 4wd.
enigma2y0u is offline   Reply With Quote
Old 05-08-2010, 11:51 AM   #5 (permalink)
What did you expect?
HAPPYJOHN's Avatar
Member # 119290
I would say to get a selectable or limited-slip (like the Auburn )
as opposed to the spool. front spool is really hard to steer
on dry ground, and will stress the front axles a lot.....
"Safety and security mean nothing without liberty." JamToy.
History teaches that all conquerors who have allowed their subject races to carry arms have prepared their own downfall by doing so.
-- Hitler, April 11 1942
Originally Posted by Roxywheels View Post
...... Shove a tissue in her nose, don't kiss her and hump on. ......
HAPPYJOHN is offline   Reply With Quote
Old 05-10-2010, 04:11 PM   #6 (permalink)
Member # 117733
another thing to think about is that with a spool you will have to set up the back lash again and with a selectable you dont. there not much more than a spool anyway
92 yj,6"lift, 33" tires, 4.0. ax-15, rubicon 4-1 tc,44 rear,posi-lock, oba,homebrew bumpers and sliders,aussies front and back,hand throttle
bigsquat is offline   Reply With Quote
Old 05-10-2010, 05:19 PM   #7 (permalink)
Member # 145962
Appreciate the comments, although my question was more for curiosity than actual desire or intent. After seeing some run front spools in comps they now are turning to selectables for better handling.
Thanks again!
Old 05-10-2010, 06:20 PM   #8 (permalink)
Member # 99055
bigsquat..how do you figure that with a selectable you dont have to set back last up again. both a full spool and ANY selectable locker will require fully setting up the ring and pinion again.
I dont DD my jeep, but it sees plenty of street time with a spool up front and locking hubs. this year we saw record snows in Va. a few snows over 12 inches, and one over 2 feet. so when i needed 4wd, i didn't give a rats ass about if it would handle ok in the snow, because at most i was doing 15MPH on the road. now with 2-3 inches of snow where you can go a little faster, it might not have been pleasant, but for me i love it.
extremely simple set up, nothing to break, and reliable
iwishihad1 is offline   Reply With Quote
Old 05-10-2010, 09:00 PM   #9 (permalink)
POOPSMITH
abig84's Avatar
Member # 88383
i used to think the same thing till i seen a guy who had lockers in both his axles break one of his hubs in gooey mud. that none spinning wheel becomes like a anchor. he was running the same size tires as me and i have a locked back and open front and was doing way better then he was
Originally Posted by Lance View Post
Since you perverts have a billion porn videos posted in the TP, I've disabled the function in the TP. It works everywhere else.
abig84 is offline   Reply With Quote
