Wiring rollbar lights - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-02-2010, 03:05 PM   #1 (permalink)
Member # 156105
So recently i decided to re-do my rollbar lights so they would actually work... and when i got all the wiring ran, found a constant power ground for my switch and fed the lights to the switch, i turned em on and they worked.. but then i noticed that my headlights didnt work nor did my spedo light... but my temporary highbeams worked? (when you pull the toggle arm back)... So i unplugged the power to the switch and it all came back... i have no idea what's wrong but i need some help thanks
ColtonS is offline   Reply With Quote
Old 07-02-2010, 06:09 PM   #2 (permalink)
I See You
Provience's Avatar
Member # 138976
it seems like you highjacked power from a wire that you shouldn't have. Go through the wiring diagram for your truck and see if there is a handy place to add a new circuit with a fuse and such just for the accessory lights.
Case in point, my buddy has an 02 ram, the fuse box is wired and fused for heated seats...he doesn't have that option. Good place to highjack power. Just make sure that you are using the proper size line and fuse, fire brings the suck.
Provience is online now   Reply With Quote
Old 07-03-2010, 04:41 AM   #3 (permalink)
sirmack10's Avatar
Member # 157670
yea u borrowed power from somewhere you should have the best bet because daylighters suck so much power is run the main power from the battery to the switch that way you have a strong source of power for all the lums your putting out!
sirmack10 is offline   Reply With Quote
Old 07-03-2010, 03:50 PM   #4 (permalink)
Member # 156105
I did a quick run through of my wiring diagrams... and i'm led to believe that the wire i poached from (it was just hanging there) is aftermarket... its not in my book.. anywhere... lol
Old 07-03-2010, 04:58 PM   #5 (permalink)
Tactical Turtleneck
Urban Wheeler's Avatar
Member # 26369
Send a message via Yahoo to Urban Wheeler
Run your lights thouh a relay under the hood. Run the relay ground into the cab and through a switch. Power to the relay comes from the battery, and you are done.
Originally Posted by usmcdoc14
sell. the correct word is "sell" you mouthbreathing fuck.
Type like you have a clue.
Urban Wheeler is offline   Reply With Quote
Old 07-03-2010, 06:10 PM   #6 (permalink)
Member # 156105
Good fucking call lol
Old 07-04-2010, 07:33 PM   #7 (permalink)
Member # 156105
Ok, so instead of doing the relay i did a fused link on the Constant power line, so the switch i have is 3 pronged (it has a light)
Ground
Light
Battery
The fuse is on battery and the roll bar lights are on light and a ground is on the ground... but now i have no power when the power is on the switch? Im so confused... i took the power off the switch and put it to the line directly and nothing... i think i may just run my own power... relying on these random hanging wires is making me mad.
Old 07-05-2010, 08:18 AM   #8 (permalink)
HARD ROCK VEGAS
burtv's Avatar
Member # 83644
Using "Relays" are your friend!
burtv is offline   Reply With Quote
