Warn 8274 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-03-2010, 10:45 PM   #1 (permalink)
Peterbuilt84's Avatar
Member # 148659
Warn 8274
I'm a newb seeking some help. I ended up getting a winch for free and when I looked it up to see what it was it turned out to be a Warn 8274. It looks to be in decent shape, but I have no idea how to see if it works or to check what working Wacondition its in. Can anyone help me out?
Thanks
Peterbuilt84 is offline   Reply With Quote
Old 07-03-2010, 11:23 PM   #2 (permalink)
HARD ROCK VEGAS
burtv's Avatar
Member # 83644
If it came with a hand held control that plugs into the side of the winch just plug that in and then hook up the winch leads to a 12 volt battery and test.
burtv is offline   Reply With Quote
Old 07-03-2010, 11:27 PM   #3 (permalink)
75PPE's Avatar
Member # 63318
First of all, congrats on getting a free 8274. That winch is legendary and arguably the best winch Warn, or anyone else, has ever made. Did it come with a controller? If so, plug in the controller, attach the wires to a battery and flip the toggle switch on the controller. If everything is hooked up correctly, it should work. If it doesn't work, chances are, it's either a solenoid or motor issue. Whatever you do, don't get frustrated and throw it away. Call Warn, or a local dealer, and get a rebuild kit. Take the thing apart and freshen it up. Those winches cost around $1100 new and are still worth a couple hundred used, so you've got a solid piece.
75PPE is online now   Reply With Quote
Old 07-03-2010, 11:33 PM   #4 (permalink)
Member # 148659
Thanks for the info. I forgot to mention that it did not come with a remote. Any ideas about how should I go about getting one? I guess I could post in the wanted section.
Old 07-03-2010, 11:53 PM   #5 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
you can order on from warn.
check if it is a 5/6 pin or a 3/4 pin.
you can make your own with a simple double momentary switch if it s a 3/4 pin.
Old 07-04-2010, 08:29 AM   #6 (permalink)
HARD ROCK VEGAS
burtv's Avatar
Member # 83644
search Ebay, "warn control" there are several.
Old 07-04-2010, 06:02 PM   #7 (permalink)
Mr.N's Avatar
Member # 1635
Nice score.
I can't believe no one posted this link yet...
8274 Rebuild
8274 Rebuild. . A complete tear-down and rebuild of the king of all winches - the venerable Warn 8274. Tons of pictures inside and out. Includes pics of a cool custom in-cab remote control
Proud Catholic | My Dana Articles and Info -> http://77cj.littlekeylime.com/web_rs44.html
Mr.N is offline   Reply With Quote
Old 07-05-2010, 05:28 PM   #8 (permalink)
CJHeap's Avatar
Member # 30944
Send a message via AIM to CJHeap
they sell the remotes and Northern tool. Trailer supply places and 4 wheel parts.
[B]Hammers Post 1461[/B]
[B]Tellico Post 160[/B]
[B][SIZE="4"][COLOR="Magenta"] Nikita Khrushchev said[/COLOR][/SIZE][/B][COLOR="DarkRed"][SIZE="4"]"We can't expect the American People to jump from Capitalism to Communism, but we can assist their elected leaders in giving them small doses of Socialism, until they awaken one day to find that they have Communism. "[/SIZE][/COLOR]
CJHeap is offline   Reply With Quote
Old 07-05-2010, 05:51 PM   #9 (permalink)
Member # 158571
Expect 3 times that much in Australia...
Tom
smartmonkey is offline   Reply With Quote
Old 07-06-2010, 11:39 PM   #10 (permalink)
Member # 148659
Wow that's ridiculous.
Old 07-07-2010, 10:57 AM   #11 (permalink)
CSP
Member # 1533
Exactly. One pin for "in", one for "out" and one for the ground. Mine was made out of a switch for the flaps on a Boeing 737. You can use trailer connectors to attach the controller to the winch relay box.
CSP is offline   Reply With Quote
Old 07-07-2010, 09:03 PM   #12 (permalink)
Member # 148659
Does anyone have pics of their homemade remotes?
Old 07-28-2010, 03:26 PM   #13 (permalink)
Member # 99306
hey
Wanna sell it?
sparkyinky is offline   Reply With Quote
Old 07-30-2010, 02:33 PM   #14 (permalink)
IDIot!
MT4Runner's Avatar
Member # 44480
[SIZE="5"] 8274 Rebuild
No kidding!
Peterbuilt84, read this link, and it will become much clearer!!
If yours is a 4-pin, it's the same 4-pin as on the small round 4-pin trailer plugs, you can get the male plug for $6 at NAPA.
Yeah, but they're stupid popular for the winch pull stuff--including putting motors/gear heads on both sides of a single winch drum.
Tells Peterbuilt84 what a good score he's got.
Hardest part is figuring out something decent for a handle. Seriously, read the 8274 bible and it will be easy to figureout the wiring.
...or...a 12voltguy.com in-cab winch control panel will be cheaper than a replacement WARN controller.
MT4Runner is offline   Reply With Quote
Old 07-31-2010, 02:01 AM   #15 (permalink)
Member # 148659
Wow thanks. I haven't got a chance to really look at it yet, but I'll read up and check it out.
Is the 8274 bible the rebuild link?
Old 07-31-2010, 02:18 AM   #16 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
not really
one is constant hot, center pin
ground is provided via the relay's,
get a peice of extentioncord, doesnt matter how thick or long, it is a signal/no load circut.
white wire will go to the center pin of the toggle switch
green and black wires to one of the outer pins.
when you plug it into the winch it will run wone way or the other when you flip the switch down, if you dont like the rotation either flip the switch in the handle or swap the green and black wires around.
Old 07-31-2010, 01:12 PM   #17 (permalink)
IDIot!
MT4Runner's Avatar
Member # 44480
Yep.
I bought one for $200, spent $200 in rebuild parts, and $100 on a cable, and for $500, I have a $1,400 winch, and just followed BillaVista's 8274 bible for directions.
