Caliper Asm - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-16-2010, 08:31 AM   #1 (permalink)
Member # 152927
Caliper Asm
Painted some calipers, looking to asm them now. I dont really want to use brake fluid to grease the seals, pistons and o-rings.
Any idea what will work with brake fluid? Vasoline?
nwsprocket is offline   Reply With Quote
Old 07-17-2010, 12:18 AM   #2 (permalink)
Debauchery Wizard
BeefCakeScout's Avatar
Member # 80219
why did you disassemble them to paint? Masking would have been much easier. I wouldn't put anything in my brake system but brake fluid.
Why can't they have gay people in the army? Personally, I think they are just afraid of a thousand guys with M16s going, "Who'd you call a faggot?"
Rock Goonies
BeefCakeScout is offline   Reply With Quote
Old 07-18-2010, 03:27 PM   #3 (permalink)
mega hack!!
sjracer's Avatar
Member # 139150
well if you already made the mistake of taking them apart to paint them, then you already know you may have just f-ed up. brake fluid lube only the seal down in the piston bore, you should have enough talent to dip your finger in fluid and reach in there to put some on the seal. you don't lube the dust boot anyway when re-installing the piston. leave the calipers out in the hot sun a few days before trying to re-assemble and this may bake the paint on a little more for you making them less sensitive to fluid being on there.
sjracer is offline   Reply With Quote
