Member # 69710
bbc with Rust on cylinder wall
So heres the deal. I just got this 454 bored .60 over. I bought it knowing that the head gasket was blown due to high compression and cheap head gaskets. So I took the heads off and it appears that the water sat on top of one the piston for a while? there is some surface rust on the cylinder and top of the piston. I got some 320 and 400 grit sand paper and lightly sanded off the rust that was at the top of the cylinder and it seems fine. Then I moved the piston down and there is some rust that seems to be "thicker" on the cylinder wall. I don't know if I should try to get it off with the sand paper or take it to the shop and have them hone it. I'm a tight budget and would rather save the money if I can do it myself. The motor only has a couple hundred miles on it and all the other cylinders look good I can still see the cross hatches on the cylinder walls. Any advice will help
#3 (permalink) | |
Member # 69710
