NP205 grinding on deceleration.... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-31-2010, 02:53 PM   #1 (permalink)
Member # 54033
twin sticked 205 with th350. Dont hear it on acceleration, left off the gas and it starts griding, hit the gas back down and it hit hards but then quits until I let off again. then when I put it in a bind and spinning the tires it will bang pretty hard ever few rounds of the tire. Transmission has been rebuilt and I have been thru the rear axle (14 bolt) and all seems good. Never been into one of these cases and was curious to what it could be. Any ideas?
lowharley is offline   Reply With Quote
Old 11-01-2010, 10:02 PM   #2 (permalink)
Member # 52710
It could be several different problems. My guess is bad bearing letting the gears out of alignment (thus the 'bang'). They are really easy to work on and a full rebuild kit is only about $170.
I bet if you dig into it, you'll find the problem quickly.
Slowly building:
[url]http://pirate4x4.com/forum/showthread.php?t=530478[/url]
jpmassey is offline   Reply With Quote
Old 11-01-2010, 11:42 PM   #3 (permalink)
sas'd96TAHOE's Avatar
Member # 138362
How much lift you got on the truck? Might be your pinion angle. My Tahoe did the EXACT same thing, threw in an axle shim and bam problem solved.
Sas'd 96 Chevy Tahoe. 44 front/Eaton rear, 4.56's, open, 37" hummer tires.
sas'd96TAHOE is offline   Reply With Quote
Old 11-02-2010, 06:58 AM   #4 (permalink)
Member # 63064
pinion angle
had same chit happen to me, EXACT same symptoms
'78 k10, 355/400/205, tons, 4.56's, 40's, shortened w/ interior cage
ramburger is offline   Reply With Quote
Old 11-03-2010, 04:08 PM   #5 (permalink)
Member # 54033
cj7 with 106 wheelbase. combination of front/rear stretch. angle doesnt look to bad.
Old 11-03-2010, 11:26 PM   #6 (permalink)
Member # 138362
looks can be deceiving. My truck had the EXACT to the 't' noise/vibration happening. After lots of searching, i found out that it was my pinion angle causing it. I didn;t think it was tooooooo bad, but I put 6* shims in and the noise was gone instantly. they're only 30 bucks...
Old 11-04-2010, 05:43 AM   #7 (permalink)
Member # 54033
If you are talking about the angle on the axle, the pinion was rotated up when the rear end was installed. There is no angle at the axle, points straight toward the tcase.
Old 11-04-2010, 05:47 AM   #8 (permalink)
ballardmotorsports's Avatar
Member # 100770
pinion angle my cj7 is 110" had a 205 and had this problem and swapped to a atlas 4 speed and still have some noise and vibration
RIGHT PEDAL DOWN!!!!
ballardmotorsports is offline   Reply With Quote
Old 11-04-2010, 05:58 AM   #9 (permalink)
Member # 54033
Does your driveshaft have a single joint or CV joint at the tcase?
Old 11-06-2010, 06:32 PM   #10 (permalink)
poorboy1's Avatar
Member # 57031
This.....if no cv then your axle should not point straight at tcase.
My Chevy Build
TTC 2010
F-O-A.com
RUFF STUFF Specialties
Originally Posted by rus-t View Post
You guys keep building bad ass rigs, we'll keep building tiny versions of em'
poorboy1 is offline   Reply With Quote
Old 11-07-2010, 06:48 PM   #11 (permalink)
Member # 54033
Took the case apart. There is a crack in the 205/th350 adapter but the bearings appear good. The selector gear (that moves with the shift forks) for the rear has very slight damage to the teeth on one side but the gear it comes in contact with is intact and looks fine. The twin stick kit looks like some homeade brew. thinking the shift forks is not lining up just right because of the mods to the shift rails. Can see where they had been grinding on them.
Old 11-23-2010, 10:26 PM   #12 (permalink)
mountainguyed67's Avatar
Member # 73602
U-joint angle,if no CV they need to be matched. I lifted A truck and had the same problem. Had the transfer case rebuilt and no change. Many years later,I was told it was the U-joint angle and addressed the problem. The problem went away.
mountainguyed67 is offline   Reply With Quote
Old 11-23-2010, 10:38 PM   #13 (permalink)
mega hack!!
sjracer's Avatar
Member # 139150
they are really common to crack at the adapter (a good machine shop can weld this but it's not cheap and if not done right can crack again), but i can guarantee that isn't your problem. gotta agree with the consensus. pinion angle is critical that it is matched on a non-cv shaft. the trans output angle is supposed to be (i think) within 2* of the pinion. there is better info on driveshaft tech here on pirate. also, like i've said here before, 205's don't need to be modded to twin stick, they can do it in stock form and have none of these type of problems that you described above. the only ability that you get by grinding the rails is the ability to do a front only dig, and i don't really see the point in that one.
74 chev tbi 350 sm465/203/205 d60 ARB/14b detroit 56's/64's on 40's!
/forum/chevy/933618-new-old-black-getting-1-ton-makeover.html
sjracer is offline   Reply With Quote
Old 11-24-2010, 09:49 AM   #14 (permalink)
Member # 54033
Appreciate the info. Looking for a replacement adapter, ordered a new seal/gasket kit while I have it out. Gonna clean it up and put it back in. Looks like the u joint caps are spinning, gonna replace the straps. Probably gonna get a cv shaft built.
Old 11-24-2010, 01:17 PM   #15 (permalink)
mega hack!!
sjracer's Avatar
Member # 139150
you might want to look into a flange style 205 ouput shaft for your cv. check jb conversions- they carry them for a 205. if you decide to get one make sure to order the seal at the same time.
http://www.pirate4x4.com/forum/showthread.php?t=933618
