94 f150 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-03-2010, 12:59 PM   #1 (permalink)
Member # 173040
94 f150
k guys dont kill me im doing a d44 swap n a 94 150 its out of a 78 bronco i want 2 no if i can change 2 an 8 lug rotor fairly easy HELP!
bikit is offline   Reply With Quote
Old 11-03-2010, 01:17 PM   #2 (permalink)
sas'd96TAHOE's Avatar
Member # 138362
yes
Sas'd 96 Chevy Tahoe. 44 front/Eaton rear, 4.56's, open, 37" hummer tires.
sas'd96TAHOE is offline   Reply With Quote
Old 11-03-2010, 01:25 PM   #3 (permalink)
Member # 173040
will they simply swap or do i change anything
Old 11-03-2010, 04:31 PM   #4 (permalink)
GMCTruxrule's Avatar
Member # 51243
if you can find an 8 lug dana 44 or GM 10 bolt axle, grab everything from the knuckles out and swap it over.
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR]
GMCTruxrule is offline   Reply With Quote
Old 11-04-2010, 11:57 AM   #5 (permalink)
Member # 173040
will the ttb dana50 swap
Old 11-04-2010, 01:25 PM   #6 (permalink)
broncogearhead's Avatar
Member # 33315
I know there is a step by set wright up on how to do this and what is used. It might be here on pirate. If not I'm pretty sure its on fullsizebronco.
But basically its exactly what gmctruxrule said.
If I remember right, you can not use any of the ttb 50 stuff.
95 bronco 10.25/d60 4.88's locked.
broncogearhead is offline   Reply With Quote
Old 11-04-2010, 01:44 PM   #7 (permalink)
Member # 172257
TTB stuff will not work on a SA D44, if i remember right from my research when i was gonna do the swap the TTB 44 and a SA D44 were almost completly different other than the carrier.
i know the breaks and all wont swao though..
dumb kid is offline   Reply With Quote
Old 11-04-2010, 03:34 PM   #8 (permalink)
Member # 51243
TTB 44 and solid axle 44 parts are not interchangeable.
A TTB 50 will however, interchange a few parts, hubs, lockouts with the Dana 60.
