Member # 122262
link questions
first and formost, i have searched, i need to try to find an explination i understand.
My 3 link with a panhard, its was acting funny, and i cut it all off to start over. Before i cut this time i wanna see if someone can explain to me what went wrong. When ever i went to put it to full droop to charge my shocks, i noticed it was pointing my pinion down bad and binding my u joint. I dont have excell so the calculator is useless to me, and i dont understand it anyway. What would cause it to do that? Upper to long? Mounted too high? More foward? Backward? this is where im at now. I have 8" sep at the axle, bottom mounts 14.5"from ground about 3 " back from axle center and 25" from the ground at the frame with a 35" link i2i. the upper mounts 22.5" at the axle about 4 " back from axle center and hits the frame at 25" with a 28.5" link i2i. Belly is at 23" and i got 110" wheelbase on aired down 37s.........what say you?
Crawlingchaos Racing\ *[COLOR="Red"]TexasRockStars[/COLOR]* car #314 co-pimp car #187 Crew Chief [COLOR="DarkOrange"]Www.canyonsoffroad.com[/COLOR] |
Member # 1418
Your upper link and lower links need to be alot closer to the same length, otherwise its going to rotate the axle.
Build a smaller scale with pvc pipe to test........
Arizona Trail Riders ....... BRRRaaaAAAPPPPPPP |
