Stock Toyota e-locker? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-07-2010, 12:52 AM   #1 (permalink)
thardy's Avatar
Member # 137929
I have a '96 4runner that came stock with a rear e-locker. I am planning on doing a SAS and I got an axle from an '83 toy. My question is can I swap the e-locker from the rear and put it in the front. I have heard yes and no. My '96 is a 3.4 V6 and the '83 was a l4.
Treasure Scout. 1966 Scout 800
[url]http://www.pirate4x4.com/forum/showthread.php?t=817142[/url]
thardy is offline   Reply With Quote
Old 12-07-2010, 06:05 AM   #2 (permalink)
Myanarchy's Avatar
Member # 14059
yes, you'll have to modify the front housing, to take the third, and modify the rear housing to take a regular third after moving the eloker
Jeeper89 is a bitch
Myanarchy is offline   Reply With Quote
Old 12-07-2010, 06:17 AM   #3 (permalink)
thardy's Avatar
Member # 137929
Are there any threads that you know of explaining how this can be done?
Sent from my SGH-T959 using Tapatalk
Old 12-07-2010, 10:33 AM   #4 (permalink)
I See You
Provience's Avatar
Member # 138976
Yes. Check out the toyota faq in the toyota forum. There should be a couple listed.
Up is difficult. Down is dangerous.
I Like Bright Colors
Romans 1:28-32
Provience is offline   Reply With Quote
Old 12-07-2010, 11:30 AM   #5 (permalink)
Member # 120505
I ve heard there is problems with the axle engagement into the spider gears once the swap is done. I can`t find any info on this in the Bible.
ANyone have any info?
Also if you can fit the 4:10 ring and pinion off the stock 8" housing on an e locker ??
95 sidekick, custom longarms, 16" coilovers, VW 1.9TD , Toyota axles tranny and dual cases.
slim_badboy is offline   Reply With Quote
Old 12-07-2010, 02:39 PM   #6 (permalink)
IDIot!
MT4Runner's Avatar
Member # 44480
Good for you for paying attention.
This is not a problem 100% of the time. From what I've read, it can happen with v6 leaf-spring housings, but not 4runner/coil housings, sometimes when teh moon is full, sometimes when my wife's aunt flo is visiting. All joking aside, pull the shafts out and measure from the axle flange/bearing surface to the center pin inside the diff, and measure the same point on the axle to the end of the splines on the shaft.
It's not in the bible, but I'll try to find the thread in the forum.
Edit: Here it is:
/forum/toyota-truck-4runner/806250-toyota-e-locker-fix-89-95-4runners-trucks.html
A "v6" 8" 4.10 R&P will fit an e-locker. If you change bearings when you regear, make sure you buy a bearing set for an e-locker. The locking side is a larger diameter bearing than a standard v6 bearing set.
MT4Runner is offline   Reply With Quote
Old 12-07-2010, 03:17 PM   #7 (permalink)
thardy's Avatar
Member # 137929
What if I were to just put the third from the rear already set up? Would it just bolt in? Then I could find a V6 third to put a detroit in the rear.
Sent from my Samsung using Tapatalk
Old 12-07-2010, 03:38 PM   #8 (permalink)
Member # 19077
Edit: Here it is:
http://www.pirate4x4.com/forum/showthread.php?t=806250
Just to add, 1986-95 ring and pinion is the same 4cyl or V6. Everyone calls them 4cyl or V6 but really they are early (79-85) and late (86-95). Inner pinion bearing is different. All the 4cyl aftermarket bearing kits are for the early style.
yotamasters.com <-------- NEW WEBSITE IS HERE!!!!!
Max Volume is online now   Reply With Quote
Old 12-07-2010, 03:40 PM   #9 (permalink)
Member # 19077
No it will not bolt in, you will have to modify both housings.
My advise is to leave the elocker in the rear, and run the detroit in the front. You will be able to steer alot better with the detroit in the front vs the elocker in the locked position. Also you wont need to modify the housings.
Old 12-07-2010, 04:37 PM   #10 (permalink)
IDIot!
MT4Runner's Avatar
Member # 44480
I agree!
Old 12-08-2010, 03:22 PM   #11 (permalink)
thardy's Avatar
Member # 137929
Thanks for the input
