2.5" shocks fitment in '80s Suburban - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-17-2010, 07:17 PM   #1 (permalink)
Member # 177323
Hello all,
I acquired a stock '84 Suburban Diesel earlier this year. This week I started with the first step of the build: a new suspension.
I ordered a burly set of springs from Alcan Spring. They were supposed to have a 4" lift - it looks a little taller than that, but I'm sure they'll settle (I didn't measure). Tires will be 35" Toyo M/Ts.
I have decided on Kings 2.5" external reservoir shocks. Piggybacks in front and remote reservoirs for out back. Here's my question: my installer thinks that if we mount the rear shocks to the stock mounts, the bigger shock bodies will run into clearance problems between the leafs at the bottom and the frame at the top once the suspension starts to articulate.
He doesn't know for sure but doesn't want to run the risk unless I specifically ask him to mount the shocks that way. He suggests building a lateral brace from one frame rail to the other, then tilting in the tops of the shocks and mounting them inboard.
Naturally, I'll be compromising shock efficiency by doing that. I'd really much rather keep the shocks as vertical as possible unless it's simply, well, impossible to do so.
What do you smart folks think about that? Will the 2.5's work in the stock location? Will the 2.5's work in a location outside the frame rails other than stock that's still better than moving them inside the frame?
Thank you all in advance for your time and your input.
Best,
-R.
Buckaroo is offline   Reply With Quote
Old 12-17-2010, 08:48 PM   #2 (permalink)
Member # 141906
Send a message via MSN to Flatdeck6.2
http://pirate4x4.com/forum/showthread.php?t=937389
I got this from asking a similar question in the newbie forum.
Living vicariously through you
Flatdeck6.2 is offline   Reply With Quote
Old 12-17-2010, 09:08 PM   #3 (permalink)
NorCal_Chris's Avatar
Member # 140551
get new mounts on top of axle just the plain ole triangles with holes would be fine. run shocks vertical and cut a hole in your wheel well and run a hoop there. Seems a waste to pay that much for a shock and run it diagonal
adfasd
NorCal_Chris is online now   Reply With Quote
Old 12-17-2010, 10:17 PM   #4 (permalink)
Member # 177323
Thank you for confirming my suspicions, guys. And a very informative article about shocks.
Best,
-R.
