AMC 304 sudden loss of oil pressure - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-02-2011, 02:50 PM   #1 (permalink)
Member # 173519
I have a "79 AMC 304, pretty much stock which I freshened up about 3 years ago. One of the items I replaced was the oil pump components. I did not replace the timing chain housing which by most accounts is sometimes the problem with oil pressure loss (from what I have read within this forum). However, my particlar problem is the oil pressure is perfect for about 99.9% of the time and then sudden loss which recovers almost immediately. The other day, I was out trail riding (nothing crazy) and my oil pressure dropped to zero and the lifters started clattering (sure sign of oil pressure loss). I shut off the engine and checked under the hood for any obvious damages or leaks. I couldn't find anything abnormal and decided to start the engine just long enough to move the rig off of the trail. Upon doing so, the oil pressure came right back again and was fine for the rest of the way out of the trail.
Operating pressure is between 40 and 60 psi depending on RPM and about 20 psi at idle.
Does anyone have any ideas to the cause of this phenomenom?
29highboy is offline   Reply With Quote Quick reply to this message
Old 02-02-2011, 03:00 PM   #2 (permalink)
MC
Nose to grindstone
MC's Avatar
Member # 21997
Send a message via Yahoo to MC
Sticky oil pressure relief plunger. Take 7/8 bolt off the side and remove the plunger and clean it then re-install and try again.
MFGS of the STAR-LAB CNC machines
The finest CNC plasma tables
Made in the USA by Bulltear and can be found online at
and at local welding stores
Hypertherm and Thermal Dynamics
We also make parts for AMC
MC is offline   Reply With Quote Quick reply to this message
Old 02-02-2011, 04:38 PM   #3 (permalink)
Provience's Avatar
Member # 138976
Either that or possibly low oil/bad flow causing the pump to pick up air
To be clear, this is not to suggest that in similar circumstances, a person who engaged in this activity would face no consequences. To the contrary, those individuals are often subject to security or administrative sanctions. But that is not what we are deciding now.
- Comey on Clinton 2016
Old 02-03-2011, 06:31 AM   #4 (permalink)
Member # 173519
Thank you both MC and Provience for your quick replies.
I will check the plunger as you suggested. During the failure the oil level was checked and was good. When this problem occurred, I was on a flat portion of the trail (dry riverbed / wash).
Old 05-04-2012, 08:18 PM   #5 (permalink)
Member # 156897
I'm having psi problems now with my 304. What did you find out your problem was?
73 cj5 (super jeep)
78 cj7
88 YJ
Kingaircj is offline   Reply With Quote Quick reply to this message
