Member # 78258
Engine swap buick v-6 supercharge
3800 Buick supercharge 99 have a turbo 350 need info on adapter to fit the transmission & have someone do the electrical wiring for my buggy/rock crawler (it is a transverse "front wheel" drive motor so I will need an adapter to fit on the turbo 350)
#2 (permalink) | |
Member # 30359
search general4x4 for the "3800". You'll turn up the 3800 bible thread and several other really good threads.
BDR 67 FJ40 "Last Minute" - build thread 97 XJ Quote:
Member # 98130
I have a 97 3800 and am using an aw4 tranny(1991-2001 cherokee) and a dana 300. No adapters needed and because the tranny uses electric solinoids you can have a revers valve body if you buy an aftermarket shifter.
Just another route cheers
4X4S ARE BUILT NOT BOUGHT |
#4 (permalink) | |
Member # 30359
It's important to mention here that it would have to be the AW4 that came behind the AMC 2.5L 4 cylinder. The one behind the 4.0 I6 has a different bellhousing.
Member # 47454
What year is your harness/ECU?
I have the pin-outs for most of them and can walk you through what you do and do not need to get the engine up and running. Follow my thread here: /forum/jeep-hardcore-tech/872757-overdrive-yj.html 3800 Bible: /forum/general-4x4-discussion/841159-3800-bible.html |
Member # 103279
904 from '84-'86 2.8 cherokee is 4.75" shorter than th350 AA dana 300 adapter combo. I got ECM from Loyde at FastFieros cheaper for custom tuning buggy stuff than ZZP and Intense. You want a '99-'03 GTP harness is simplest but any '98 up pcm series ii should work. '96 and some '97 pcm's are 256K and the '98 and newer are 512k speed. If you are dead set on a th350 I have a perfect AA dana 300 adapter I'll take $350 shipped for. Speedwaymotors has your 3800 to Chevy trans adapter for like $65
#8 (permalink) | |||
Member # 30359
#9 (permalink) | |
Swag Sales
Member # 90594
if so i could take one and put it on my 4.0 aw4 and not worry about Isuzu parts.
I can put your business, personal and/or club name on shirts, hats, coolers, koozies, pens, jackets and more! Just ask! Get with me on your industrial safety needs as well! Andrew Dial Jedco Sales Inc. jedcosales.com PM me or email andrewd@jedcosales.com We are family owned and in our 30th year! Big enough to get great products and prices. Small enough to know who you are! |
#10 (permalink) | |
Swag Sales
Member # 90594
looks like google found my answer
http://en.wikipedia.org/wiki/List_of...using_patterns
Swag Sales
Member # 90594
So I was searching for 3.5L isuzu transmisions on ebay and a whole bunch of hummer, colorado and canyon tansmisions came up and the ads said said fits Isuzus also. INTERESTING! Put in a 3800 motor with a 3.5 colorado bellhousing and jeep aw4?
![]() EDIT: Looks like the trans in a colorado is a 4l60E, and the 3.5s are not the same. From what I understand (which could be wrong) The 4l60E wil lbolt to a 3800, but you cant use its bellhousing to bolt the motor to an aw4.
I can put your business, personal and/or club name on shirts, hats, coolers, koozies, pens, jackets and more! Just ask! Get with me on your industrial safety needs as well! Andrew Dial Jedco Sales Inc. jedcosales.com PM me or email andrewd@jedcosales.com We are family owned and in our 30th year! Big enough to get great products and prices. Small enough to know who you are! Last edited by dozer_xj; 02-25-2011 at 08:52 AM. |
#12 (permalink) |
Member # 78258
The engine I have is out of a Regal GS 99 as far as I’ve gotten is pulled the motor out of the car it is still attached to the trans I haven’t had anytime to separate it yet but I’m working on it any info on hooking up the electrical wiring would be great I have a turbo 350 with a atlas 3.8,running Dyno trac pro rock sixty’s with walker Evans bead locks and red label 39 crawlers. I originally had a 85 3.8 Buick sequential injection motor it will be nice to get my rig running again to see the power difference its going to be nice.
