2006 Cummins squeak....Bad u-joints? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-14-2011, 04:12 PM   #1 (permalink)
People know me
bigbadchev84's Avatar
Member # 68938
My 2006 3500 just developed a squeek, or a high pitched chirp. I have jacked up all 4 corners and spun the the tires, Brakes are fine.
The noise is only under load, and increases with mph, It is not dependant on engine rpm. I just drove it for 5 miles and the u-joints arent even warm to the touch. I have 106,xxx miles on it. Is there a for sure way to find out what u-joint it is or maybe the carrier bearing on the driveline? At $50 per u-joint I dont want to just throw money at it and hope that fixes it.
72' k5 blazer, 350/350/205, HAD shaft 8" lift, zero rates, 3/4ton 4.56s, 38/14.5/16 Toyo M/Ts
2006 Dodge Megacab 3500, 5.9 cummins, 6 speed, straight piped, cold air intake, Juice with attitude, 35's and leveling kit
67' Chevy 1/2 ton 400/400/208, 6" lift, 35" Toyo M/Ts
bigbadchev84 is offline   Reply With Quote
Old 03-15-2011, 12:06 AM   #2 (permalink)
______________
Corey Young's Avatar
Member # 21622
Look for rust around the rubber seal between the u-joint cross and caps.
Corey Young is online now   Reply With Quote
