Newbie
Member # 113516
Huge open-ended question.
Suspension lifts are what should be your primary source of gaining ground clearance and flex. Body lifts are a way to gain an inch or maybe two when going with that one or two more inches of suspension lift will cause many more things to be changed. If you consider the frame of a vehicle the constant. A suspension lift adds clearance by moving the axles away from the frame. This gives you more space for not only larger tires but also space for the axles to articulate before contacting the frame. A body lift just moves the body away from the frame using spacers. Doesn't do a thing for the performance of the suspension of a vehicle. Like I said, body lifts should be used as a one to maybe two inch boost over what you are getting with a good suspension lift. Not as the only source of lift. |
Member # 187330
BL aren't really ideal for offroading due to the fact you don't gain any suspension travel from them but a cheap way to gain clearance for tires. Just don't go to big. Most people say stay two inches or below Personally I would never run a BL. But with that most ifs lifts wont gain you any travel either there just adding a bracket. According to what type of wheeling you do really
Meow listen here
As other have said, definitely want your main source of lift to be suspension. However, body lifts can have some advantages. For instance, you can raise the body up an 1" (don't go big with a body lift) and then easily raise the motor up an inch to gain a little clearance there.
For someone who has never installed a SL , (ME) , how difficult and how long would it take to complete such a task, or should I just have a shop do the install. New to all this.
Look up, look down, look all around, can you see me yet? |
#7 (permalink) | |
Whatever Works
Member # 128472
Depends on the age and type of vehicle. Do some searching around to see what best fits your style of wheeling. Honestly, do all the work yourself. That labor will cost more than the parts and you'll save a bundle. That and you get an understanding of how it works.
As for the body lift, avoid it at all costs. Only time I'd use a BL is to be able to clock my drivetrain for a flatbelly.
Samurai Build on a Low Buck Budget: The Tin Can Quote:
Newbie
Member # 113516
3" lift to what? Difficulty depends on the vehicle and type of suspension as well as type of suspension lift.
3" lift for a TJ using stock control arms = easy 3" lift for a TJ changing over to a long arm suspension and coilovers = harder |
It depends on what you expect from it.
Many people mistakenly think that a suspension lift will "perform" better off road. Performance is a vague and ambiguous term, but for this purpose we'll define it as wheel travel. Wheel travel is the holy grail of almost every kind of off road performance. Desert racers need it to keep their vehicles under control at speed, and rock crawlers need it to keep their wheels on the ground for traction. But your typical off-the-shelf lift kit is not going to give you any more wheel travel than you have stock. In the case of an IFS vehicle, all they are going to do is replace your lower cross member so you can fit a bigger tire under the fenders. Your "performance" has not improved beyond the ability to fit a bigger tire. In the case of a straight axle, it depends on the kit. If you have flex joints at one end of each control arm it will give you more flex, but if it's a "cheepie" kit, the bushings won't last if you try to flex more than stock. They include bump stops to prevent that. So again, unless you go with high-end components, you are not gaining much. A body lift will give you up to 3" of clearance, which will let you clear some 33" tires. The advantage of the body lift is cost. Also, many people with 6" suspension lifts discover vibrations because they've changed driveline angles. Since you are not changing any mechanical components, you won't have those issues with a body lift. Last but not least, don't pay attention to the "body lift haters". Most of them have not seen a body lift done correctly. While a back-woods body lift is easy to spot, a proper body lift is not. In the case of a full size truck, a proper body lift will include bumper brackets and urethane gap guards to cover the gap between the body and frame. Here's a picture of a 2011 Raptor with a 3" body lift
You are entitled to your own opinion. You are not entitled to your own set of facts. |
Member # 10063
Agreed. Body lifts do have their place (I have a 2" on mine and did as Rendered mentions with my t-case for more belly clearance), but like said, your initial focus generally should be on a suspension lift. To help us better answer your difficulty of install question better, you might want to tell us what kind of vehicle you're working with (and model year).
'90 Bronco II, 2.9L, Dual T-case, 5.13s, 35x12.50s [url]http://www.cardomain.com/ride/702959[/url] |
Gettin there!
Member # 45202
Well since explaining what vehicle, or what your using it for is yet to be posted. Installation of a lift takes common sense
Wheeling before all the dbags made it "trendy" |
#14 (permalink) | |
Member # 132813
I am playing devils advocate here, but many of the wheelers on here can't afford a "decent" suspension lift and many suspensions lifts don't actually improve performance. If I can fit bigger tires, I get better performance offroad. That is as close to being a fact as anything on here. A body lift will get me that, cheap. It is not ideal, but it is not the devil either, especially if you only have $100 to spend. Last edited by higgo; 04-05-2011 at 07:19 PM. |
#15 (permalink) | ||
Whatever Works
Member # 128472
#16 (permalink) |
Money has nothing to do with my decision.
The goal I am trying to reach would be to have the ability to take the truck offroad and not worry about tearing up to much of the undercarriage. I am not really into the rock scene, I like dirt,mud,rough terrain,and such. Do I need to change my shocks when I put a lift on? Kreg
Look up, look down, look all around, can you see me yet? Last edited by sixfeathers; 04-05-2011 at 08:19 PM. |
#17 (permalink) | |
#18 (permalink) | |
For arguement's sake, lets define affordable as $2500, roughly five times the cost of a body lift.
#19 (permalink) | |
Whatever Works
Member # 128472
Ok. Forget it.
Go with a 4" body lift and 6" lift blocks. Thornbirds are the best tires on the market right now. For a cage, I suggest Sched 40.
#20 (permalink) |
Gentlemen, keep in mind this is my daily driver as well. I found out body lifts' are frowned upon here in MD , I have vehicle inspections every two years. I don't mind taking it out and rigging it out totally in a few years, but not yet. I want to have a nice lift so I can go offroad and play. Not looking to "play hard" yet. I did some research yesterday and I will get order a lift from 4wheeler. Icon shocks I like. pricey but I like the features of products. Probably go with a skyjacker lift. Thanks again for all the input. Greatly appreciated.
#21 (permalink) | |
Member # 148442
but dont forget this is the newbie forum after all. OP- I also think the others forgot to mention that body lifts are hard on body mounts. Theres plenty of people out there who run them with zero issues, but at the same time, theres also plenty who have put a lift block through the floor. Ive done it, and its not a fun thing to fix. They arent necessarily a BAD thing, as mentioned above, their main purpose is to gain clearance for things like clocking your T-case, and they make drivetrain swaps a little easier. Sometimes when people swap different body's to different frames, a body lift is necessary as well. All in all, a suspension lift is going to get you places. A body lift is just to keep from cutting fenders.
The computer beat me at checkers once, but it was no match for me in kickboxing. |
#22 (permalink) | |
Member # 132813
With a suspension lift you do get some more frame clearance (which will help with approach, departure and breakover angles) but your overall clearance is exactly the same because your diffs are exactly where they were before the lift. Most suspension lifts do nothing for wheel travel or overall articulation. The main drawbacks of a body lift are:
#23 (permalink) | |
I've found nothing that says you can't run a body lift.
You are entitled to your own opinion. You are not entitled to your own set of facts. Last edited by ibrocun; 04-06-2011 at 09:16 AM. |
#24 (permalink) | |
![]() I'm not really sure what you mean by big body lifts looking dumb. How big is big? I don't know of a body lift kit that's bigger than 3". If that's big, I posted a pic of a Raptor above with a 3" body lift, and it does not look dumb. But if you are talking about this I agree.
#25 (permalink) |
Member # 109328
Body lifts are AWESOME, check out the tire clearence this guy got with his body lift:
![]() I can see why people like body lifts now, it all makes sense ![]() On a more serious note, some vehicles look ok with a body lift and some don't. From my experience body lifts look on ok 03 and up Dodge's, Ford Raptor's, Nissan Titan's. Pretty much everything else looks like ass with the frame hanging WAY down below the truck. On Toyota there is a good bit of frame exposed factory and after a body lift it is a tremendous amount. I would steer you toward suspension on that particular truck. Last edited by Ho Shorts; 04-06-2011 at 10:23 AM. |
