which holley carb is this one?
Hi guys, I just bought this holley 4bbl for a 350, but I cant find info about it. Does someone know which carb model is it?
http://imageshack.us/photo/my-images/62/p4210060.jpg/ thanks arriero
Wrangler YJ, 33x12.5r15, D44/F9, 4.88, TD27T SOA, tx10/D20 doubler F350 SRW 6.0L 4x4 "stock" |
Member # 41063
Look on the front of the air horn (where the choke is) and look for a list number. Google the list number and you should find everything you need to know.
1988 Dodge AW450 Ramcharger - 318TBI - NP435 - NP205 - D60s |
skullfuckery
Member # 29016
the cons...
its 460 cfm!!!! way way to small. its also a smog/efficency based setup, which means it would suck the balls off a bridge troll. take it, hold it in you power /throwing hand, over your shoulder, and chuck it in to a ravine/cayon/mine shaft/tar pit/ some where it will never be seen again.
Impeach or revolt, which will it be? buy my quad http://www.pirate4x4.com/forum/vehic...00-2500-a.html I WILL TRADE FOR A ROAD WORTHY 55-57 or 71-87 CHEVY 2WD PICK UP |
#8 (permalink) | |
Member # 116337
Member # 197170
If you have a 4V manifold with the proper mounting holes ( or an adapter) it will fit. For a stock 305 it would work. But just because something will work doesn't mean you should use it.
#12 (permalink) |
Member # 156801
I wouldn't mess with an emission-control oriented carburator. For a 350 I would get a 4150 650 Holley or a 670 Truck Avenger or Street Avenger. For a 305 I would probably get a 570 Street Avenger.
'66 Bronco D60HP-KP & FF narrowed 359W, NP435/D20 |
#13 (permalink) |
Member # 156801
"which means it would suck the balls off a bridge troll."
Lucky bridge troll! There aren't any trolls lurking around bridges out here. They prefer darker and colder and wetter regions.
