Building a 300 blackout - Page 6 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-10-2012, 06:17 PM   #126 (permalink)
Member # 73883
Originally Posted by broncman View Post
Wilson Combat.
Anyone ever used anything from them? They have a 14.7" stainless and 16" barrel in stock for $249.
Been looking at their barrels and thinking about one. I deffiniteley want a carbine length gas setup instead of the pistol length gas setup. I believe Noveske are the ones that offer both gas lengths... Pistol length gas setup for subsonic only ???
I've always liked their 1911 stuff. I check every so often to see if the 16" fluted is in stock so I can grab one, but I'm not in a hurry to build my 300 yet.
CJNTN is offline   Reply With Quote
Old 01-11-2012, 10:33 AM   #127 (permalink)
Fistful of Boomstick
usmcdoc14's Avatar
Member # 13344
Send a message via AIM to usmcdoc14 Send a message via Yahoo to usmcdoc14
I may go Wilson Dombat if DSA can't do ...well what they normally do with orders
Doc-14 Tactical Products:
When it absolutely, positively needs to be made from random crap found in the back of my garage.
You cant ban knowledge, learn to make your own guns right Here.
New York, Colorado, Maryland, Conneticut….is your state next? Yes it is. Write, Vote and Fight.
usmcdoc14 is offline   Reply With Quote
Old 01-11-2012, 11:44 AM   #128 (permalink)
Texas97's Avatar
Member # 111524
i am absolutely going Wilson Combat. DSA seems to be indefinite on their lead times and out of stock items. Wilson Combat seems quality.
anyone looking into or thinking about the advantages of an adjustable gas block on the carbine lenght gas system?
Place whitty quote from some random PBB member here
CROSSFIT: Your workout is our warm-up.
Texas97 is offline   Reply With Quote
Old 01-11-2012, 11:51 AM   #129 (permalink)
thedonn007's Avatar
Member # 121794
I am not really in a hurry. I will probably even forget about it until it shows up on my porch. Maybe like Christmas in July?
When you act like you know everything you do not learn anything
thedonn007 is online now   Reply With Quote
Old 01-11-2012, 12:37 PM   #130 (permalink)
thedonn007's Avatar
Member # 121794
DSA says, "Also we are hoping to receive the 300 blackout uppers in the middle of February."
Old 01-11-2012, 01:22 PM   #131 (permalink)
Member # 47460
I am running a Wilson 16 inch barrel on my 300 blk. Have not shot it yet but should on Saturday. Workmanship looks top notch service was awesome. The bbl is HEAVY though. My build ended up much heavier than expected. Once mine is proved out I will be going sbr so that will help at least. Pics up later
TheRookie is offline   Reply With Quote
Old 01-11-2012, 04:50 PM   #132 (permalink)
Member # 46937
You can find them on gunbroker.
atblis is online now   Reply With Quote
Old 01-19-2012, 04:27 PM   #133 (permalink)
CJ5inFourWheelDrive's Avatar
Member # 19668
Is anyone making a 20" barrel?
(1975 Jeep CJ-5) Being built: 2x4 A-500C frame, C&C 14 bolt w/discs & Detroit, D44 mini-spool, Flat Tops, Mad Mac Double Arms, 4.56's, SM420, D300, AA & Novak adapters, SOA on 2in. BDS YJ springs with a reversal, extended wb; 6in. front, 3in. rear, TJ flairs, hummer rims, hydroboost w/68' Vette M/C…
CJ5inFourWheelDrive is offline   Reply With Quote
Old 01-20-2012, 05:03 PM   #134 (permalink)
Ball Ground
Member # 34061
Originally Posted by rsilvers View Post
It will be popular based on price alone. Reformed one-fired 223 brass is 10 cents each:
http://www.allweatherarms.com/1000-P...0-Blackout.htm
And new Remington primed brass is 25 cents each at Midway.
And while some bullets are more optimal than others, you can shoot any 30 cal bullet you have.
I ordered 1000 of their processed brass and it is formed wrong. The shoulder is 1.15" from the base and it is supposed to be 1.10" and will not chamber in my AR.
Bull Durham Racing
Team #360
Upper2 is offline   Reply With Quote
Old 01-20-2012, 06:15 PM   #135 (permalink)
lets go Squatchen
aloharover's Avatar
Member # 14561
I see 1:11 twist barrels and 1;8.5. sooo which one?
Want to know how I lost 25lbs in 9 weeks? Try INSANITY®.
www.beachbodycoach.com/petermhope
I love it when a plan comes together
Colorado Springs, CO Based FFL-07/SOT
aloharover is offline   Reply With Quote
Old 01-20-2012, 09:56 PM   #136 (permalink)
Mr. Personality
Azzy2000's Avatar
Member # 11869
I suppose it depends what weight bullet you plan on shooting? I'm curious about this too along with what weight bullet and length of barrel most people are using and staying subsonic. I want to build a short 300 blk upper for my SBR.. It would be used full time with a can and I definitely want it to stay subsonic. CMMG has a nice looking 8.5" upper in their catalog..
Azzy2000 is offline   Reply With Quote
Old 01-20-2012, 10:49 PM   #137 (permalink)
Member # 13467
1:11 is "regular" .308 twist. If you plan on much subsonic shooting, go for the faster twist.
[QUOTE=Willyswanter's Dad;8398776]I'm trying to find spinner caps that will fit the wheels so when I'm stuck it will look as though I'm still wheeling[/QUOTE]
Ben Segrest is offline   Reply With Quote
Old 01-21-2012, 04:41 AM   #138 (permalink)
thedonn007's Avatar
Member # 121794
So, for up to 300 yards, will it really matter if I use supersonic rounds through a 1:8 twist barrel?
Old 01-21-2012, 05:57 AM   #139 (permalink)
lets go Squatchen
aloharover's Avatar
Member # 14561
I know that on the .223 a heavier bullet requires a tighter twist. If you are shooting over 70gs you really want a 1:7. But you are also trying to push them 3000fps.
I was thinking the same way about the blackout. If I want to push something long and heavy like a 175smk I probably want a faster twist. But 308 match guns are only running 1:10.5 range for the 175.
So do you need an even tighter twist because the bullet is traveling slower?
I have me a hankering for a 12-14" barrel on a side charger upper.
Old 01-21-2012, 05:00 PM   #140 (permalink)
Member # 13467
yes. Stability comes from rpms. Theoretically, you can't over-stabilize a bullet. However, in the real world, bullets aren't perfectly balanced, so spinning them faster than needed might cause some accuracy issues.
Old 01-21-2012, 05:06 PM   #141 (permalink)
Member # 31422
Send a message via AIM to tmacie
So basically you'd need to build a rifle for subsonic loads and one for super?
tmacie is offline   Reply With Quote
Old 01-21-2012, 05:14 PM   #142 (permalink)
Member # 13467
Not according to what I've seen/heard/read. I'd just pick the twist to better suit what I would be shooting most of the time. Primarily a subsonic gun, go with the tight twist and vice versa for supers. But I'm really just speaking from a theoretical point of view. I don't have any first hand experience with this round.
Old 01-21-2012, 07:30 PM   #143 (permalink)
lets go Squatchen
aloharover's Avatar
Member # 14561
So the question really is, for me, is the 8 twist better with super sonics than the 11
Old 01-23-2012, 04:19 AM   #144 (permalink)
Merry Christmas
freerider5.0's Avatar
Member # 21312
Send a message via AIM to freerider5.0
1-8 Twist is the standard. Its what i have and mine shoots supers like a champ.
Elliot
Originally Posted by Gozuki View Post
Don't breath too deep, or you'll end up like redpitbull999...
freerider5.0 is offline   Reply With Quote
Old 01-23-2012, 08:12 AM   #145 (permalink)
Texas97's Avatar
Member # 111524
Theoretically, yes. but practically, might be a different story. if you start thinking about it itll make your head hurt, circular argument and all.
that being said, my 1:10 in 308 will stabilize up to the 208 gr amax bullet very easily, but for some reason i have a hard time with 155 grain bullets and i have discussed the idea of overstabilization off of a gunsmith and several handloader freinds. there could be other factors like bullet quality and symetry of those 155s, so i havent really come to a conclusion on over-stabilization yet.
Freerider... whats the heaviest supersonic round your shooting out of your 1:8 twist?
Old 01-23-2012, 09:02 AM   #146 (permalink)
Merry Christmas
Member # 21312
147-150 Plinkers. 220g subs. You also have to take in the fact that these rounds don't have the velocity behind them a normal 308 does. There for you can get away with the 1:8 twist.
Elliot
Old 01-23-2012, 09:21 AM   #147 (permalink)
Texas97's Avatar
Member # 111524
I want to shoot 175 grain supers, I think that would be fun for my purposes
Old 01-23-2012, 09:38 AM   #148 (permalink)
Merry Christmas
Member # 21312
That is going to be a slow round. What is your purpose??
Elliot
Old 01-23-2012, 10:13 AM   #149 (permalink)
lets go Squatchen
aloharover's Avatar
Member # 14561
FWIW, a 1:7 223 can have issues shooting stuff below 55gr
I tried some 45gr varmint stuff in a 1:7 and it was all over the map. Same round in a 1:9 was moa accurate.
Old 01-23-2012, 11:03 AM   #150 (permalink)
Bipedal 'Poccylyps
jettscott's Avatar
Member # 107403
Looking at Wilson's stuff andthey have a 7.62X40 WT? WTF?
http://shopwilsoncombat.com/762x40-WT/departments/411/
Their .300 BLK uppers are no longer available. The barrels seem to be in stock.
Buying a complete upper is just like anything else I guess, some stuff is greatly expensive (like Noveske) and some isn't (CMMG). I'd like to have an upper and swap it out with my 5.56 lower for a while until PSA puts theirs back on sale.
BTW, does any agency get curious or frown upon an individual buying say... half a dozen stripped lowers?
I like this barrel:
http://shopwilsoncombat.com/Wilson-C...o/TR-300RC16F/
"He who joyfully marches in rank and file has already earned my contempt. He has been given a large brain by mistake, since for him the spinal cord would suffice."
jettscott is offline   Reply With Quote
