Threading the holes in a lower... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-05-2012, 08:56 PM   #1 (permalink)
redpitbull44's Avatar
Member # 68844
Well, like in kwrangln's OCD build thread http://pirate4x4.com/forum/showthrea...&highlight=ocd
where he threaded through the grip screw hole for a trigger set screw and rear pin detent spring hole to keep the spring from taking flight; I was just thinking, why not do that on the safety detent spring hole too? I mean, one would be far more likely to remove the grip to try a new one than to remove the buffer tube. Has anybody done that yet?
BTW, WTF does kwrangln mean. Reminds me of the sound a wrench makes when you drop it, and it hits the radiator, all the fan blades, the cross member, and front axle before finally bouncing a few times on the concrete and coming to a rest.
ΜΟΛΩΝ ΛΑΒΕ
.308 Winchester: Turning cover into concealment since 1952.
Originally Posted by Texas97 View Post
dont know why... unless its some new hippie tree hugger brady campaign sissy ass bedwetter gun control nanny state facist orwellian barbara streisand law that just passed....
redpitbull44 is offline   Reply With Quote
Old 01-05-2012, 09:04 PM   #2 (permalink)
BigBlue&Goldie's Avatar
Member # 113019
The reason the safety detent hole can't be threaded is there wouldn't be enough room for a detent and a spring.
"Big Blue" 1977 F-150 ,"Goldie" 1999 F-350
BigBlue&Goldie is offline   Reply With Quote
Old 01-05-2012, 09:09 PM   #3 (permalink)
Bacon addict
smurfblue40's Avatar
Member # 32029
I saw that in a build thread (Calguns ). Not a bad idea really... I've seen a few people lose springs when they decide to do a "in depth" cleaning (then get their ass ripped off by the arms room guys for doing it too )
*edit*
Nevermind, BAC is low... proof reading owns me
Rick
'72 FJ40 -Lightly modified
'91 FJ80 -Work in progress
TLCA #14103
smurfblue40 is offline   Reply With Quote
Old 01-05-2012, 09:12 PM   #4 (permalink)
Doublewide engineer
kwrangln's Avatar
Member # 6971
I've looked into modding the safety detent like the takedown detent, but because of the depth of the hole in the lower (most of the spring is in the grip itself) it's just not feasable. By the time you trim the spring short enough to allow for a set screw in the lower there isn't enough movement left for the safety to cycle easily due to the length of the detent itself. If you were to cut down the detent it may work, but that was more than I was willing to mess with at the time.
As for my screen name, when I got my first YJ (in '92) I got vanity plates for it that said WRANGLN (YJ=wrangler) and I used that as my first email account ever. Eventually I had to get a different email account so I threw my initial in front of it and ended up with kwrangln. Used that email for a while after I registered here before getting a new one, but kwrangln was already stuck, and the rest is history.
I'm the "tack tack tack" welding nazi.
http://www.pirate4x4.com/forum/showp...&postcount=218
"I didn't mean to kill nobody ... I just meant to shoot the sonofabitch in the head. Him dying was between him and the Lord." R. L. Burnside
kwrangln is offline   Reply With Quote
Old 01-05-2012, 09:12 PM   #5 (permalink)
Member # 68844
I've never had one out, but it looks like there is plenty of detent spring there that could be trimmed down. I figured nobody had bothered. Didn't realize the spring protrudes into the grip.
Right on. It all makes sense now. Just know that when I see your screen name, in the back of my head I pronounce it kraang!!!!!
ΜΟΛΩΝ ΛΑΒΕ
Old 01-05-2012, 10:20 PM   #6 (permalink)
Rapey
animator's Avatar
Member # 13701
Send a message via AIM to animator Send a message via Yahoo to animator
Now you know why there's that little hole in the top of the grip...
Think you're a marksman? Test your skills by joining the 200yd Iron Sight Challenge happening NOW in the OSR Forum:
http://www.pirate4x4.com/forum/outdo...-may-31-a.html
animator is offline   Reply With Quote
Old 01-05-2012, 11:08 PM   #7 (permalink)
Member # 13467
I guess the level of mental capacity or knowledge around here must run a lil deeper than where you're from.
Apparently not
[QUOTE=Willyswanter's Dad;8398776]I'm trying to find spinner caps that will fit the wheels so when I'm stuck it will look as though I'm still wheeling[/QUOTE]
Ben Segrest is offline   Reply With Quote
Old 01-06-2012, 06:01 AM   #8 (permalink)
Member # 31422
Send a message via AIM to tmacie
I've done it with a spikes lower. You just have to radius the top of the detent a little. Took 5 minutes, teardown to reassembly. Selector worked much smoother than stock.
YMMV.
Travis
tmacie is offline   Reply With Quote
Old 01-06-2012, 06:21 AM   #9 (permalink)
thedonn007's Avatar
Member # 121794
YMMV.
Travis
What did you do with the spring?
When you act like you know everything you do not learn anything
thedonn007 is offline   Reply With Quote
Old 01-06-2012, 07:51 AM   #10 (permalink)
rockmup's Avatar
Member # 16699
Cut the pin in half and use a 1/8th long set screw with a cut spring
And trigger guards can be tapped 4-40
07/C2 SOT
/Making guns and fun toys, one hammer swing at a time
Need quality ammo ?
AMERICAN LEAD DISTRIBUTORS
Need a POV system ? REPLAY XD
rockmup is offline   Reply With Quote
Old 01-06-2012, 08:27 AM   #11 (permalink)
Member # 31422
Cut it pretty short. There was an article somewhere....I'll see if I can find it.
Old 01-06-2012, 12:51 PM   #12 (permalink)
Member # 68844
Cool. Please do!
ΜΟΛΩΝ ΛΑΒΕ
