I need some help with my AR - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-23-2012, 06:22 PM   #1 (permalink)
Charlie don't surf!
77bawls's Avatar
Member # 72494
For the life of me I can't figure out what's wrong with it. It feeds fine and ejects fine, but once in a while I pull the trigger and it just clicks. I eject the round and it just has the floating firing pin mark on it. I did the 15 minute trigger job on it but the rounds that do go off have a deep primer strike, so I don't think it's because the hammer spring was cut.
Originally Posted by southernfriedcj8 View Post
Are you hittin' on me?
Originally Posted by BeefCakeScout View Post
I was, but if you won't kiss me after I blow you then i'll find someone else
http://folding.extremeoverclocking.c...e.php?u=317103
77bawls is online now   Reply With Quote
Old 02-23-2012, 06:24 PM   #2 (permalink)
Member # 13467
simple test: Replace the hammer spring. See if it makes a difference.
[QUOTE=Willyswanter's Dad;8398776]I'm trying to find spinner caps that will fit the wheels so when I'm stuck it will look as though I'm still wheeling[/QUOTE]
Ben Segrest is offline   Reply With Quote
Old 02-23-2012, 06:32 PM   #3 (permalink)
nights end here
FlexCJ5's Avatar
Member # 35217
Hammer follow or bolt bounce. Change out the fire control springs and maybe the buffer spring.
Originally Posted by usmcdoc14 View Post
I build AK-47's in my living room and have a huge cock, my .22's compensate for my enormous manhood.
James Firearm and Palmetto State Defense
01/03 and 07/SOT
FlexCJ5 is offline   Reply With Quote
Old 02-23-2012, 06:38 PM   #4 (permalink)
Member # 13467
I ruled out hammer follow because he said he gets a click. It could be bolt bounce, but that's a little harder to diagnose.
Old 02-23-2012, 06:38 PM   #5 (permalink)
Charlie don't surf!
77bawls's Avatar
Member # 72494
Hammer follow?
I thought that it wasn't in battery so I hit the forward assist before every round and it still had problems. I have another trigger group for it that I will try. It's not a milspec buffer tube or spring.
I would also open it up re-cock the hammer and it would fire so it is in battery.
Edit: I assume hammer follow is when it follows the carrier instead of catching the disconnector and sear. That's one thing I haven't checked. (Take a peak before every round.)
Old 02-23-2012, 06:55 PM   #6 (permalink)
lets go Squatchen
aloharover's Avatar
Member # 14561
You have the firing pin installed fully into the bolt prior to installing the cottor pin?
See if you can pull out the firing pin without removing the cotter.
If installed correctly I would suspect weak hammer spring
Want to know how I lost 25lbs in 9 weeks? Try INSANITYŽ.
www.beachbodycoach.com/petermhope
I love it when a plan comes together
Colorado Springs, CO Based FFL-07/SOT
aloharover is offline   Reply With Quote
Old 02-23-2012, 07:07 PM   #7 (permalink)
Charlie don't surf!
77bawls's Avatar
Member # 72494
Nope, the pin is installed correctly.
That's the only thing I can think of too, but why would it not have a primer strike on some and deep on others?
Old 02-23-2012, 10:03 PM   #8 (permalink)
Member # 105338
Have you lightened the hammer at all? I've had some that worked with the stock weight hammer and others that needed the hammer lightened a bit to work right ( shaving the tail off )
As suggested before, put a stock hammer spring back in it, I bet it works....
Unka-Boo is offline   Reply With Quote
Old 02-23-2012, 10:11 PM   #9 (permalink)
Member # 24649
What kind of ammunition are you using?
Zuki Tyler is offline   Reply With Quote
Old 02-23-2012, 10:18 PM   #10 (permalink)
Charlie don't surf!
77bawls's Avatar
Member # 72494
So far it's been nothing but PMC. I did just buy 420 rounds of 855.
Old 02-23-2012, 10:38 PM   #11 (permalink)
braxton357's Avatar
Member # 14685
Send a message via AIM to braxton357
I bet you cut a leg off of the hammer spring didn't you. Replace it with another or buy a two stage trigger.
In vino veritas
70 turbocharged 351w fastback mustang
73 linked 5.8efi Bronco
99 QCLB 4x4 twin'd cummins on meth.
braxton357 is offline   Reply With Quote
Old 02-24-2012, 01:00 AM   #12 (permalink)
Charlie don't surf!
77bawls's Avatar
Member # 72494
I said I did the 15 minute trigger job.
I replaced the spring and cleaned everything. When I was looking at it in order for it to not be in battery the carrier needs to be about a quarter inch back which definitely wasn't the case. I put the new spring in there and if it fixes it, I'm going to have to get a Geissele, because I can't stand the stock trigger pull.
Old 02-24-2012, 03:31 AM   #13 (permalink)
Member # 48233
Pop the rear takedown pin.
Pull charge back halfway so you can see the empty chamber.
Insert live round
Let the bolt down via charge handle.
Push the bolt into battery. It should settle in with a click and the bolt should cam fully.
Close the rifle up and push takedown pin in so the upper and lower are together securely.
Aim down range, turn safety off, pull trigger.
If it goes bang, then your hammer spring is fine. If not then there is a good chance you have a weak buffer spring and its not going fully into battery.
[quote=texasblake;11194923]
they may be waving like mccain for the rest of their life, but you taught them an important life lesson and they had fun doing it.[/quote]
[QUOTE=xyjbeaker;9759686]"mexican food reminds you of my face?"[/QUOTE]
Doc Holiday13 is offline   Reply With Quote
Old 02-24-2012, 05:03 AM   #14 (permalink)
Doublewide engineer
kwrangln's Avatar
Member # 6971
I'm betting hammer spring since you modded it. If the new hammer spring solves the problem then you are good to go. If you like where the hammer was at except for the reliability, then once you have the problem figured out you can get a set of JP yellow springs and lighten your hammer to do away with light strikes.
I'm not a fan of modding springs.
As for why some and not others? Could be as simple as a lube issue or variance between primers, who knows.
I'm the "tack tack tack" welding nazi.
http://www.pirate4x4.com/forum/showp...&postcount=218
"I didn't mean to kill nobody ... I just meant to shoot the sonofabitch in the head. Him dying was between him and the Lord." R. L. Burnside
kwrangln is offline   Reply With Quote
Old 02-24-2012, 10:06 AM   #15 (permalink)
*blank*
ShmUDE's Avatar
Member # 109953
i have the same issue in one of my AR's after doing the 15min trigger job. Figured i cut too much off the spring. Been waiting to get a new one or a 2 stage trigger to fix my issue.
you could hack the back half of the hammer off to lighten it. That would fix your issue too.
ShmUDE is offline   Reply With Quote
Old 02-24-2012, 11:11 AM   #16 (permalink)
Aggro's Avatar
Member # 2587
Location: 38*45.859N 120*34.534W (N. Ca) Future location of beachfront property.
Firing pin slides freely in bolt?
Aggro is offline   Reply With Quote
Old 02-24-2012, 11:16 AM   #17 (permalink)
Blower Binder
64dumptruck's Avatar
Member # 142191
You should be able to shake the bcg in you hand and here the pin moving freely.
(jacking off motion)
"Those who would give up Essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety." Ben Franklin
"Nobody can give you freedom. Nobody can give you equality or justice or anything. If you're a man, you take it." Malcolm X
64dumptruck is offline   Reply With Quote
Old 02-24-2012, 01:30 PM   #18 (permalink)
Charlie don't surf!
77bawls's Avatar
Member # 72494
I'll try that
Good to know I'm not the only one.
Yes.
Old 02-24-2012, 01:55 PM   #19 (permalink)
Member # 13467
Insert live round
The buffer spring can't be the culprit if he manually closes the bolt and the rifle still doesn't fire.
Old 02-25-2012, 10:05 PM   #20 (permalink)
Member # 7968
Thread hijack- 77- if you want to try a factory trigger with the JP springs or a Gieselle- let me know and you can fondle mine. I tell ya- the JP springs have done wonders for the feel of the stock trigger. I know I measured the trigger pull but probably don't have the figures written down.
1983 Toy PU, a few mods, Marlinized, lockerized
Hooligan is offline   Reply With Quote
Old 02-26-2012, 06:52 PM   #21 (permalink)
Charlie don't surf!
77bawls's Avatar
Member # 72494
Sure, we'll have to go shooting sometime.
Old 07-09-2012, 10:55 PM   #22 (permalink)
JonsYJjeep's Avatar
Member # 47464
I just did the 15 minute trigger job on my MP15-22. Took it out out to the range. Never had a misfire before but this time I had about 12 out of 100 that misfired. Examined the 22lr and the rims had a soft impact from the firing pin. I noticed when firing that if I didn't release the trigger after pulling it I would get a misfire.
I considered adjusting the creep but I think I might lighten the hammer. But I'm not sure if this will fix it or not.
Glad I found this thread.
My 7/8 ton YJ build
JonsYJjeep is offline   Reply With Quote
Old 07-10-2012, 01:29 AM   #23 (permalink)
Member # 13467
Did you cut/bend springs, specifically the hammer spring? If so, you'll need to lighten the hammer.
