8 HP evenrude no spark help - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-29-2012, 05:25 PM   #1 (permalink)
robert stone's Avatar
Member # 985
Send a message via Yahoo to robert stone
got a little 8 horse outboard evenrude mid ninety's i beleave that i cant get running what do i need to look for ?
i just wanna go fishing
robert stone is offline   Reply With Quote
Old 05-31-2012, 08:36 AM   #2 (permalink)
FrankenToy's Avatar
Member # 36822
Since there ain't much to these ignition systems there isn't much to go wrong. Most of my failures with FHP engines were related to a wire's insulation being worn away and shorting to ground. You can use an Ohm meter to check for a shorted out or open coil/spark plug lead, too. These two reasons were the cause of about 95% of the failures I've experienced. Other thing could be a shifted flywheel (kinda rare).
Seems the fools are in charge now and they demand a high tariff... Me
FrankenToy is offline   Reply With Quote
Old 05-31-2012, 12:41 PM   #3 (permalink)
Member # 48978
Send a message via Yahoo to Steele
I've had issues with the dead man switch/ cord, if so equipped. The plastic was worn and did not seat all the way into the pocket which kills the engine/ keeps it from getting spark.
Steele is offline   Reply With Quote
Old 05-31-2012, 01:05 PM   #4 (permalink)
Poor White Trash
Norm's Avatar
Member # 4387
Rust on the magneto trigger on the flywheel?
"My Border Collie is smarter than our president"
Norm is offline   Reply With Quote
Old 05-31-2012, 02:52 PM   #5 (permalink)
Member # 140312
Check the points if it has them
sometoyotaguy is offline   Reply With Quote
