How to build a AK variant at home - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Closed Thread
Old 02-13-2005, 05:55 PM   #26 (permalink)
Fistful of Boomstick
usmcdoc14's Avatar
Member # 13344
Send a message via AIM to usmcdoc14 Send a message via Yahoo to usmcdoc14
or the ones you build yourself
i think a G3 might be a next project to build
Doc-14 Tactical Products:
When it absolutely, positively needs to be made from random crap found in the back of my garage.
You cant ban knowledge, learn to make your own guns right Here.
New York, Colorado, Maryland, Conneticut….is your state next? Yes it is. Write, Vote and Fight.
usmcdoc14 is offline
Old 02-13-2005, 05:58 PM   #27 (permalink)
Hef
Member # 11907
Send a message via AIM to Hef
Build a G3KA4. It's sooooooo cool.
Hef is offline
Old 02-13-2005, 06:03 PM   #28 (permalink)
Rapey
animator's Avatar
Member # 13701
Send a message via AIM to animator Send a message via Yahoo to animator
If only I could find someone who had a collapsable stock available, I'd be getting one for my CETME. Original wide HK front grips are in the works too
Think you're a marksman? Test your skills by joining the 200yd Iron Sight Challenge happening NOW in the OSR Forum:
http://www.pirate4x4.com/forum/outdo...-may-31-a.html
animator is offline
Old 02-13-2005, 06:05 PM   #29 (permalink)
Hef
Member # 11907
I saw the A4 stock for the HK91/G3 on Gunbroker a while back. They wanted $400 for it NIB.
Hef is offline
Old 02-13-2005, 06:18 PM   #30 (permalink)
Rapey
animator's Avatar
Member # 13701
Just noticed over on Florida Gun Works, they've got them back in stock for $330 roughly. I think that's still a bit pricey, and I know I've seen them on other sites for less. I'm keeping my eye out...
animator is offline
Old 02-13-2005, 07:33 PM   #31 (permalink)
Member # 3000
http://www.interordnance.com/index.shtml
has German G-3 kits avaliable with the colapsible stock. I would not want one personaly. The Choate sidefolder is well built, like anything from Choate. I don't like the idea of a folder on a .308. Whenever I shoot my .308s, either the Saiga or the CETME I shoot from the shoulder and make fairly well aimed shots. With My AK's I will make more shots and they aren't usualy placed as carefully.
Gil your build looks to be taking shape nicely, I don't know if I like the style or not, but it will be unique. The front grip really does help keep the barrel rise down when you run a clip through fast. It should be really nic3e when it is done. I use a pair of calipers when measuring for the holes on the front and rear trunion. If you haven't drilled the rivets out in the rear trunino yet, wait it is easier to drill throught the receiver and the trunion together.
Global trades is now making 1mm receivers to compliment their 1.6mm receivers. if you have a milling machine it was no big deal to take .6mm off the fornt and rear trunions, but most of us don't. I should post a couple of pics of my Bulgarian 74 and AMD-63. I will if I get time. Have fun with the build.
Aron82 is offline
Old 02-13-2005, 07:48 PM   #32 (permalink)
usmcdoc14's Avatar
Member # 13344
nope, no front vert grip. i am using a galli(sp) style front fore end. this gives plent of handroom when running 30 round mags.
already made templates for the rear trunnion and will make them for the front (and show how here) when i space it corrctly in the reciever.
I already ordered 2 ohio ordanance recievers because of the praise i have heard and also thier very good heat treating.
That and i got sick of waiting for the 1.6 recievers to be ready
Old 02-14-2005, 09:18 AM   #33 (permalink)
Member # 3000
I have 2 rifles built on OOW receivers a 74 and a 47. I have built 4 or 5 AKs with this receiver for myself and friends. They work well, the only small gripe I have with them is the selector lever gap, which is noticable, but only to those who know what they are looking for. You do have to take quite a bit of material off of the selector lever as well, but you can get a really tight safty fit if you grind and check slowly.
Aron82 is offline
Old 02-14-2005, 11:49 AM   #34 (permalink)
usmcdoc14's Avatar
Member # 13344
what area needs grinding or what should i look out for when i come to that point
Old 02-15-2005, 12:14 PM   #35 (permalink)
Member # 3000
You have to grind down the end of the tab, so it will engage the back of the trigger to block the trigger from moving and thus the safty is on. I will see if I can find a picture. It takes a while and you basicaly grind an check with a dremel.
Aron82 is offline
Old 02-15-2005, 05:21 PM   #36 (permalink)
Rapey
animator's Avatar
Member # 13701
update for today while waiting on the recievers:
peep (ghost ring) sights are few and far to choose from for AK's. all the ones i have found are eather too low or way to fawking pricey ...or both
welcome to the free AK47 peep sight I looked on the floor till i found a piece of steel, drilled a small hole in it, ground the old sight blade flat, welded it on. then i drilled it out till i got a hole size that made my eyes happy
dremeled it till i was happy with the shape.
That's really cool. Do something like that on a rear windage adjustable sight and I'd buy one from ya
animator is offline
Old 02-15-2005, 05:38 PM   #37 (permalink)
usmcdoc14's Avatar
Member # 13344
send me one..or two and i will do it for you.
just tell me what size apature you want
Old 02-15-2005, 05:40 PM   #38 (permalink)
Rapey
animator's Avatar
Member # 13701
I just might have to do that...
animator is offline
Old 02-15-2005, 05:41 PM   #39 (permalink)
Member # 9821
You're not done with this yet?
I'm pimping ScottFJ40's [URL=http://search.ebay.com/_W0QQfgtpZ1QQfrppZ25QQsassZthemanwithgreatseats]ebay shit[/URL] so he owes me a dollar.
[color=orange] Two wrongs don't make a right but three rights make a left.[/color]
[color=yellow]I before E except after C except in words like neighbor and Budweiser.[/color]
[color=lime]May clinging breasts always come to your aid in the kitchen.
[/color]
ForestCam is offline
Old 02-15-2005, 05:44 PM   #40 (permalink)
usmcdoc14's Avatar
Member # 13344
I am waiting for the recievers taint licker i should .."should" be able to finish them this week.
Old 03-25-2005, 05:18 PM   #41 (permalink)
Member # 34044
would gun shows have parts kits? anything special to look for when choosing a parts kit or are they all the same for each variant? awesome thread btw
'79 blazer on 4D's
srv8800 is offline
Old 03-25-2005, 05:44 PM   #42 (permalink)
ChiefSlapaHo's Avatar
Member # 2694
BTW, Gil.. the package has been delivered from our southern conection. Sweet! Ammo came today, I'll be slinging led tomorrow! Oh, the grip came as well.. you'd think it was Chistmas all over again!
ChiefSlapaHo is offline
Old 03-25-2005, 05:50 PM   #43 (permalink)
usmcdoc14's Avatar
Member # 13344
remember you have to switch the grip lug at the top to use the included screw or you just have to get a screw in the same thread as my block in the leingth as the one for your new grip.
oh because i fawked up this thread and didnt document the finishing of the build i force myself to maybe buy a few more parts kits
ohh the horror
I will have to bribe 85TrailToy and his brother with something for recieving the recievers if they will do it again
Old 03-25-2005, 07:06 PM   #44 (permalink)
Member # 2694
I remembered that..
Picked up a Vanguard case. Just awaiting the red dot and it will be compete.
Old 03-25-2005, 07:09 PM   #45 (permalink)
usmcdoc14's Avatar
Member # 13344
sweeet btw how well do those mags work? and you have my 4 right
Old 03-25-2005, 07:20 PM   #46 (permalink)
Member # 2694
Give you an update tomorrow.. might wake the neighborHOOD and surrounding counties
WHAT 4 MAGS??
Old 03-25-2005, 08:19 PM   #47 (permalink)
Member # 2133
Send a message via ICQ to 85TrailToy Send a message via AIM to 85TrailToy
I remembered that..
Damn that is schweeet! Figures you're shooting tomorrow, I'll be heading north in the morning. You need to come over to Inigoes and see the junk I'm working on.
85 4Runner 4.88's 4.7's Lockers 35's Drivetrain/Gas tank lifted Dents all over
[b]9-11-01: REMEMBER DAMMIT![/b]
"Who's the fella owns this saloon?"
[QUOTE=4RnrRick]Whay would woul have poer to teh wheels if I'm in neutal![/QUOTE]
85TrailToy is offline
Old 03-25-2005, 08:30 PM   #48 (permalink)
usmcdoc14's Avatar
Member # 13344
next weekend will be LOTs O' shootin at todds house
Old 03-25-2005, 08:57 PM   #49 (permalink)
Hef
Member # 11907
Poor bastard. Who's going to fix all the fawking holes in the house when you're done?
Hef is offline
Old 04-26-2005, 08:14 PM   #50 (permalink)
usmcdoc14's Avatar
Member # 13344
Update Soon
well there will be an update realy soon on how to mark the drilling holes for the trunnions and other details
Thats right, now i am building 2-3 (or more ) full size AK's for me
Closed Thread
