Fistful of Boomstick
gun people: .308 headstamp ID/WTF is this ammo
What the fuck is this round.
FMJ, copper bullet Headstamp:308W at 12 Oclock, circles at 9 and 3 Oclock, 83 at 6 Oclock.(pics if you need them can be got) I got as much as its Sellier & Bellot but is it corrosive?
Doc-14 Tactical Products: When it absolutely, positively needs to be made from random crap found in the back of my garage. You cant ban knowledge, learn to make your own guns right Here. New York, Colorado, Maryland, Conneticut….is your state next? Yes it is. Write, Vote and Fight. |
Rapey
I assume it's non-NATO?? No circle-cross stamping?
Think you're a marksman? Test your skills by joining the 200yd Iron Sight Challenge happening NOW in the OSR Forum: http://www.pirate4x4.com/forum/outdo...-may-31-a.html |
Member # 10854
Sounds like military ammo that was made in 1983. Is this surplus stuff?
A prisoner of war is a man who tries to kill you and fails, and then asks you not to kill him." - Sir Winston S. Churchill, 1952 |
this is it.
I just want to what the fuck it is alli have read about corrosive ammo is wash with water or windex and then clean as normal.
#7 (permalink) | |
#8 (permalink) | |
Rapey
ammonia in the windex neutralises the acid from the primers. I shoot corrosive in my mosin all the time with no problems. Just give it a good cleaning right after shooting.
Member # 5233
S&B from '83 and most likely corrosive. Only sure way to know is to pull the bullet and test the primer on bare carbon steel.
Is the bullet steel core? Did these come sealed in battle packs? Crate? The reason you use water to clean up after firing corrosive is the same reason it is used to clean black powder. Water dissolves the corrosive salt residue leftover from the ignition. Oil base cleaners will not dissolve salts as well as plain old water. Clean as you normally would after the water treatment. You will know within 24-48hrs if you didn't get it all out. |
#11 (permalink) | |
ya but i prefer not to just dump a bottle of Hoppes down my barrel and action as its kind pricey
#12 (permalink) | |
light blue paper boxes marked exactly "20pcs .308 Winchester (7,62 x 51 mm) " I believe they ARE corrosive as my barrel (used gun) is pitted inside and looks rough. The lands/grooves are sharp but it just looks "dirty" even after cleaning. (i have a spare barrel, i just want to see how this will shoot first)
#13 (permalink) | |
Member # 5233
Have a bullet puller? |
#14 (permalink) | |
copper wash? (doesnt seem that way)yes i have a bullet puller ![]() you need a description or pics?
#15 (permalink) | |
Member # 5233
Probably a copper plating over steel jacket. However, I have seen the copper wash to prevent corrosion on ammo made in 3rd world countries which didn't put much $ into their ammo. Take some copper solvent (sweets 7.62) to the bullet and see how thick the coating is. If it is a thin coat and you value your new bbl I wouldn't recommend shooting the stuff through it. No pics, I know what you're looking at. Nice bullet puller by the way. You should get an inertia puller. Doubles as a good cat thumper.
#16 (permalink) |
well i cant scrape it off so i know its not a wash, I will cut one in half tomorow.
so what is this shit good for (besides plinking) armor piercing abilities? good penitration, spalling? distance?
#17 (permalink) | |
Member # 5233
It will go through soft armor and through thin non-armor-rated metal stuff like car doors and the like. I'm guessing that it is 147gr so you're probably looking at an effective penetration distance of 500yds depending on the target. Spalling effectiveness is >500yds on concrete. |
#18 (permalink) |
well, lets see what it does at the range tomorow
![]() thank you for the info you have redeemed yourself from any previous lack of ballistic information
#19 (permalink) |
Member # 22748
spalling? what is that?
R.I.P. DOZER ![]() R.I.P. Jason ![]() GREAT SPIRITS HAVE ALWAYS ENCOUNTERED VIOLENT OPPOSITION FROM MEDIOCRE MINDS -ALBERT EINSTEIN- #472tellico rally xtrm-s10 is a bad hauler dont let him haul your stuff ![]() Buy my mega cab KJ6IYH |
#20 (permalink) | |
your target is behind a concrete wall, you know "where" he is, you shoot wall, you dont kill him with the actual bullet but with the chucks of high velocity concrete blown off the backside.
#21 (permalink) | |
Member # 22646
" Never underestimate the power of idiots in large groups" |
#22 (permalink) | |
but for my "home" aplication i would rather lay down a bunch of cheap 7.62NATO as i cant afford a .50 or the ammo for it Too bad they got/getting rid of the SMAW it is a great anti-sniper weapon (I am an "unofficaly trained 0351)
#23 (permalink) | |
Member # 22646
SMAW is an awesome weapon with many uses.....especially with the NE round
#24 (permalink) | |
