SHOOT TO THRILL!
Member # 26382
m4 going under the knife
there has been a couple things i wanted to do to my m4 now that that fed assault weapon ban has sunset. the m4 was previously a post ban by federal standards. being that my m4 is already registered as a california assault weapon, i can now add some of the evil features that the fed wouldn't allow before.
a collapsible stock was a must. i went with a rock river arms 6 position stock. now for some gunsmithing. i knew i needed a flash hider. i wanted to stay with the m4 look so i wanted to go with an a2 flash hider. since my barrel was a non threaded m4 profile i decided to cut it down to about 15" and thread it to 1/2-28. this will give about a 16-1/4" length with the flash hider. ![]() ![]() since i still can not have a sbr in california i needed to permanently attach the flash hider. i chose to braze it on. i used a fast flowing brazing filler that melted at 1200*. the filler flows like solder and was sucked into the threaded connection. this should satisfy the law. after brazing it and seeing how much heat is actually involved i decided that i will not use this method again. ![]() next i bead blasted the flux and other mess off the barrel and preheated it to about 150*. after it heated up for about 10 minutes i sprayed it with norells moly resign in flat black. it then went back in the oven at 300* for an hour. ![]() ![]() ![]() next was the upper receiver. i cleaned it up real quick in the blast cabinet and heated it to 150*. i sprayed it with the moly resign and baked for an hour at 300*. ![]() ![]() now it was time for assembly. this is where i messed up. i used a leather tig welding glove to protect the upper receiver in the vice. this was not good enough as the picatinny rail cut through it like a razor. the picatinny rail is messed up enough that i am going to buy another upper receiver. i went ahead and assembled it anyways for now. ![]() ![]() what i learned from this project: like i said earlier, i am not going to use heat to permanently attach the next flash hider. instead i am going to use a blind pin and a small tig spot weld to close the hole. i will then finish with a file to hide the weld. also, i am now going to get a set of vice jaws for the receiver.
87 4runner d44f/9"r full width, 5.38/5.43/ARBs, superior shafts, ctm's, twin stick 4-1 dana 300 behind toy t-case, allpro springs f/r, 39.5 iroks on aluminum trail ready bead locks ΜΟΛΩΝ ΛΑΒΕ I'm just a peckerwood who lives in the hills with too many guns. |
#3 (permalink) | |
SHOOT TO THRILL!
Member # 26382
yea, that's what i get for not using the right tool for the job.
Member # 53024
http://img.photobucket.com/albums/v6...rebarrel05.jpg
Might be a noob question but I have only worked with Issued M-16's, shouldnt there be a gas tube along the top of the barrel? Or did you remove it for the baking and all that? |
#5 (permalink) | |
SHOOT TO THRILL!
Member # 26382
lets go Squatchen
Member # 14561
Nice
While I understand the desire to have a weapon that looks like an M-4 I have never really understood why civilians would want the M-203 notch in the barrel. I could be wrong, but I don't remember the M4 having a reduced diameter under the hand guard. I would think that a full lenth heavy barrel would be better, strength, accuracy, heat dissipation, etc.
Want to know how I lost 25lbs in 9 weeks? Try INSANITY®. www.beachbodycoach.com/petermhope I love it when a plan comes together Colorado Springs, CO Based FFL-07/SOT Last edited by aloharover; 11-24-2006 at 08:51 PM. |
#7 (permalink) | |
SHOOT TO THRILL!
Member # 26382
almost every m4 profile barrel i have seen had the reduced diameter under the hand guard. i think i have only seen one that didn't and it was an off brand manufacture. as far as the m203 notch, it just looks cool i have 2 other barrels i am going to play with. i think i will make my other m4 barrel 14-1/2" and permanently attach a phantom flash hider. i have a strait contour barrel that i think i will leave 16" but thread the end and leave the flash hider non-permanently mounted.
Member # 22748
O/T do you know where i can get some 203 hand guards, i have a 203 in 37mm, and i would like to mount it to one of my Ar's but i cant find guards for it anywhere
R.I.P. DOZER ![]() R.I.P. Jason ![]() GREAT SPIRITS HAVE ALWAYS ENCOUNTERED VIOLENT OPPOSITION FROM MEDIOCRE MINDS -ALBERT EINSTEIN- #472tellico rally xtrm-s10 is a bad hauler dont let him haul your stuff ![]() Buy my mega cab KJ6IYH |
Angry Gecko
Member # 23744
Location: White Mtns., Arizona... it's on the map, just not on any map!
Hey 300Sniper... really nice job man.
Do you do extra on the side? I have a postban Bushmaster shorty carbine that I would like to have threaded. Either that or I get off my cheap ass and order a different upper. Think about... pm me or just throw a cost out there if your interested.
I R A REVOLUTION LEADER! |
#10 (permalink) | |
SHOOT TO THRILL!
Member # 26382
let me mess with my other barrels first to get comfortable doing it before i do any one elses. i still need to get more tooling for my lathe. i kind of winged it on this project.
#11 (permalink) | |
Mr. Personality
Member # 11869
#12 (permalink) |
Member # 73194
not to like totally hijack your thread 300sniper, but how many of you guys here, the few that i assume are the "gun guys" of the board, are current previous service eh?
Rollin slow in a rebuilt 4RNR! I'm just a peckerwood that lives in the hills with a lotta guns! |
#13 (permalink) |
Member # 75135
Nice job on the barrel! Have you thought about silver soldering the next one? It wont take nearly as much heat and is very strong. Most of your manufacturers use silver solder. From bolt handles, vent ribs, to attaching barrels together for double barrels. Just a thought.
#14 (permalink) | |
Angry Gecko
Member # 23744
Well if that was your first time doing anything like that then I am really impressed!!! Seriously, that's fairly advanced smithing in my book... and it turned out awesome.
#15 (permalink) | |
Member # 16699
My thoughts too. Silver Solder is a great way to go. Nice work
__________________ 07/C2 SOT /Making guns and fun toys, one hammer swing at a time Need quality ammo ? AMERICAN LEAD DISTRIBUTORS Need a POV system ? REPLAY XD |
#16 (permalink) | |
SHOOT TO THRILL!
Member # 26382
#17 (permalink) | |
SHOOT TO THRILL!
Member # 26382
that was my first "real" project on the lathe that i actually had to use callipers and a dial indicator. it was also my first time threading with the lathe. i have only messed around with it making shift knobs and other un-precision parts so i was pretty proud of how the threading turned out.
#19 (permalink) | |
SHOOT TO THRILL!
Member # 26382
#20 (permalink) |
SHOOT TO THRILL!
Member # 26382
one more thing i learned last night. some times it is good to read the instructions before you attempt a project. i was reading in an old military manual on the m16a2 about replacing barrels and found out that you are supposed to hold the barrel in the vice, not the receiver. i still would have messed something up with out a holding fixture but now i know the proper way.
time to see when the next big reno gun show is.
#22 (permalink) | |
SHOOT TO THRILL!
Member # 26382
http://www.molyresin.com/molyresin_about.asp i used it on my upper and lower intakes, valve cover and timing cover on my 22re and it turned out nice also: ![]() and the gears and pulleys on a lathe i restored:
87 4runner d44f/9"r full width, 5.38/5.43/ARBs, superior shafts, ctm's, twin stick 4-1 dana 300 behind toy t-case, allpro springs f/r, 39.5 iroks on aluminum trail ready bead locks ΜΟΛΩΝ ΛΑΒΕ I'm just a peckerwood who lives in the hills with too many guns. Last edited by 300sniper; 11-25-2006 at 09:00 AM. |
#23 (permalink) |
Fistful of Boomstick
If you need more practice let me know as I will send you stuff to thread
![]() I want a 16" heavy barreled flat top upper threaded for a flash hider but I can get a non-threaded one for cheap.
Doc-14 Tactical Products: When it absolutely, positively needs to be made from random crap found in the back of my garage. You cant ban knowledge, learn to make your own guns right Here. New York, Colorado, Maryland, Conneticut….is your state next? Yes it is. Write, Vote and Fight. |
#24 (permalink) | |
SHOOT TO THRILL!
Member # 26382
like i told flecker, once i am confident with threading my own barrels, then i could probably work something out. give me a couple weeks to get the proper tooling and we'll see what happens.
#25 (permalink) | |
Mr. Personality
Member # 11869
