heat shield in a FAL custom handguard - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-25-2006, 09:44 AM   #1 (permalink)
Fistful of Boomstick
usmcdoc14's Avatar
Member # 13344
Send a message via AIM to usmcdoc14 Send a message via Yahoo to usmcdoc14
I am making a full floating handguard for my Fal out of 2in ID carbon fiber tube and some 1.5-2in thick aluminum "bulkheads" at either end. Now I know the carbon fiber can handle some heat but was thinking of putting a shielding material on the inside to just be safe and to keep the handguards cool.
Aluminum foil epoxied on?
I dont want to add a shitload of weight. I can put just about anything can be layed in there as the top is "split" as the gas tube sticks above it
like this but not with all the oval holes
and if I do add holes they will be round and aluminum grommited to prevent splitting and to look cool
Doc-14 Tactical Products:
When it absolutely, positively needs to be made from random crap found in the back of my garage.
You cant ban knowledge, learn to make your own guns right Here.
New York, Colorado, Maryland, Conneticut….is your state next? Yes it is. Write, Vote and Fight.
usmcdoc14 is online now   Reply With Quote
Old 11-25-2006, 10:15 AM   #2 (permalink)
basketcasejeep's Avatar
Member # 34936
So what do you want to know? Use heavy duty aluminum foil?
Just do it.
. . . but in the Kalahari it is always Tuesday, or Thursday, or whatever day you like . . .
basketcasejeep is offline   Reply With Quote
Old 11-25-2006, 10:21 AM   #3 (permalink)
Hophead
Joe_W's Avatar
Member # 4829
Send a message via AIM to Joe_W
stupid non-gun knowledgable question
Wouldn't aluminum grommets just transfer heat? For that matter wouldn't foil just transfer heat rather than shield?
Dunno..just wondering
Sure, there are 49 other states in the Union, but they are smaller, wussier, and the people talk funny.
Originally Posted by Muddin
The vagina doubles as a neat little fanny pack.
Originally Posted by ironpig70 View Post
Originally Posted by thumping View Post
Do you seriously have to shit on damn near every thread you find yourself in?
I do
Joe_W is online now   Reply With Quote
Old 11-25-2006, 10:24 AM   #4 (permalink)
usmcdoc14's Avatar
Member # 13344
Just do it.
If there is something better than aluminum foil
Old 11-25-2006, 10:26 AM   #5 (permalink)
usmcdoc14's Avatar
Member # 13344
it would reflect it unless it is in contact then it would radiate it.
The heat shields under your car are just aluminum spaced away from the cat/exhaust
Old 11-25-2006, 10:30 AM   #6 (permalink)
Rapey
animator's Avatar
Member # 13701
Send a message via AIM to animator Send a message via Yahoo to animator
Aluminum would definitely be the way to go.
Think you're a marksman? Test your skills by joining the 200yd Iron Sight Challenge happening NOW in the OSR Forum:
http://www.pirate4x4.com/forum/outdo...-may-31-a.html
animator is offline   Reply With Quote
Old 11-25-2006, 10:31 AM   #7 (permalink)
Hophead
Joe_W's Avatar
Member # 4829
Yea I got to thinking about just that after I posted...oh well
I do
Old 11-25-2006, 10:34 AM   #8 (permalink)
usmcdoc14's Avatar
Member # 13344
don't mock my ghetto/rednck gunsmithing
Old 11-25-2006, 10:48 AM   #9 (permalink)
Member # 144
Gil, heat shields work cause they're spaced away. If you can pull that off, it'll block the heat, if it's touching at all it'll transfer heat very efficiently
That's because you're a pinko fascist. - Haole
I know what antidisestablishmentarianist means
mike is offline   Reply With Quote
Old 11-25-2006, 10:51 AM   #10 (permalink)
usmcdoc14's Avatar
Member # 13344
ya I know but its is proving hard to find that layered/spot welded/aluminum shit they make head sheilding out of.
Old 11-25-2006, 10:56 AM   #11 (permalink)
Member # 144
yea, you'd have to get AL sheet and form it then spot weld it
Old 11-25-2006, 11:00 AM   #12 (permalink)
usmcdoc14's Avatar
Member # 13344
and I was looking in the wrong place. I think flexible automotive sheet stuff would work better
Old 11-25-2006, 11:04 AM   #13 (permalink)
SHOOT TO THRILL!
300sniper's Avatar
Member # 26382
how 'bout using some .049 6061 tube with stand offs for the heat shield?
300sniper is offline   Reply With Quote
Old 11-25-2006, 11:08 AM   #14 (permalink)
usmcdoc14's Avatar
Member # 13344
you mean the .049 6061 tube AS the heat sheild right?
Old 11-25-2006, 11:08 AM   #15 (permalink)
Member # 34936
There is. Heavy duty aluminum foil.
I think I've also seen some thin aluminum in rolls for roof flashing. I suppose that would work if it is not too thick and heavy.
Old 11-25-2006, 11:11 AM   #16 (permalink)
SHOOT TO THRILL!
300sniper's Avatar
Member # 26382
yes, with maybe .125-.250 spacers between the carbon fibre tube.
Old 11-25-2006, 11:11 AM   #17 (permalink)
usmcdoc14's Avatar
Member # 13344
that would work with some epoxy in strips to "stand it off" AND adhere it or maybe some high temp RTV.
hmmm what would be better?
see now we are working in the realm of cheap
Old 11-25-2006, 12:03 PM   #18 (permalink)
CJ5inFourWheelDrive's Avatar
Member # 19668
Doc, check this out, it should fit the bill.
http://www.denniskirk.com/jsp/search...eafCatId=31201
(1975 Jeep CJ-5) Being built: 2x4 A-500C frame, C&C 14 bolt w/discs & Detroit, D44 mini-spool, Flat Tops, Mad Mac Double Arms, 4.56's, SM420, D300, AA & Novak adapters, SOA on 2in. BDS YJ springs with a reversal, extended wb; 6in. front, 3in. rear, TJ flairs, hummer rims, hydroboost w/68' Vette M/C…
CJ5inFourWheelDrive is offline   Reply With Quote
Old 11-27-2006, 11:08 AM   #19 (permalink)
Member # 34936
Hmm... JB weld.
JB, JB quick, or putty?
