FN/FAL carbon fiber full floating fore end - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-03-2006, 05:00 PM   #1 (permalink)
Fistful of Boomstick
usmcdoc14's Avatar
Member # 13344
Send a message via AIM to usmcdoc14 Send a message via Yahoo to usmcdoc14
I wanted a full floating hand guard for my FAl for some time but the 2 things that prevented me from buying one were either a shitty design or way too high of a price. That and every ones is offered only in aluminum.
And you all know I am a cheap bastard when it comes to gun shit so I built my own
for a total investment of $13 I had a length of 2in ID carbon fiber and a bunch of 2in OD aluminum pucks. I could have done this in all aluminum but it would not be nearly as pimp
First made the "pucks" This one is for the front
its job is to add shape and stiffness to the end of the tube
Then I made the rear one in a 2 piece clamshell design
The "tail" thing you see sticking out is where I cut away the bottom half as the barrel is too thick for it to clamp there effectively. I went and measured different distances on the barrel (as it tapers) and used the same size drill and stopped at key depths. Seeing as I do not have a CNC multi axis mill this is the best way to achieve a tapering hole I also cross drilled and countersunk for 2 6-32 stainless cap screws that fit nicely between the gas tube and the barrel. When its clamped down it holds onto the gas tube base and the barrel but NOT the gas tube. Like I said, full floating.
After making sure everything fit (and it did for some odd reason) I cut the carbon fiber tube and made it fit the contours of the shit on top
I then clamped it all together and made marks where the 8-32 cap screws were going to go. took it all apart,drilled tapped, you get the idea
and TAAA DAAAA
It is not only screwed together but also epoxied to the pucks. it is VERY stiff. much stiffer than the factory hand guard
here is a fuzzy pic of the "muzzle" end
Doc-14 Tactical Products:
When it absolutely, positively needs to be made from random crap found in the back of my garage.
You cant ban knowledge, learn to make your own guns right Here.
New York, Colorado, Maryland, Conneticut….is your state next? Yes it is. Write, Vote and Fight.
usmcdoc14 is online now   Reply With Quote
Old 12-03-2006, 05:02 PM   #2 (permalink)
usmcdoc14's Avatar
Member # 13344
I also drilled a lot of useless material out of both pucks
here is the reciever end
Old 12-03-2006, 05:03 PM   #3 (permalink)
Cue-Ball's Avatar
Member # 17311
Say that 5 times fast
Nex Pro Evinco "Death Before Defeat"
Cue-Ball is offline   Reply With Quote
Old 12-03-2006, 05:05 PM   #4 (permalink)
misfitcj's Avatar
Member # 11829
Send a message via MSN to misfitcj
so how does the mount on the crawler
A Fatmans fitness blog
misfitcj is offline   Reply With Quote
Old 12-03-2006, 05:09 PM   #5 (permalink)
usmcdoc14's Avatar
Member # 13344
I have a 1 foot piece of 2inch carbon fiber tube if you want to make wheels
Old 12-03-2006, 05:23 PM   #6 (permalink)
surpip's Avatar
Member # 22748
installed pics?
now polish the alum.
R.I.P. DOZER
R.I.P. Jason
GREAT SPIRITS HAVE ALWAYS ENCOUNTERED VIOLENT OPPOSITION FROM MEDIOCRE MINDS
-ALBERT EINSTEIN-
#472tellico rally
xtrm-s10 is a bad hauler dont let him haul your stuff
Buy my mega cab
KJ6IYH
surpip is offline   Reply With Quote
Old 12-03-2006, 05:27 PM   #7 (permalink)
Member # 32841
Send a message via AIM to cybergeek23851
Gil......You are lucky enough to have a garage to work in, yet you're working on the kitchen/bar counter
AND Lighting is not an issue.... I know!
cybergeek23851 is offline   Reply With Quote
Old 12-03-2006, 05:34 PM   #8 (permalink)
usmcdoc14's Avatar
Member # 13344
No I am taking pics in the kitchen I had to wash the oils off before I epoxied it.
assembled pics in a bit
Old 12-03-2006, 05:38 PM   #9 (permalink)
Member # 32841
That's better.....
Originally Posted by Aprilrazz
You know better than that!
Old 12-03-2006, 05:56 PM   #10 (permalink)
usmcdoc14's Avatar
Member # 13344
pics installed
you can see the 2 set screws here that clamp it on
and everything shiny will be duracoated
I may add some grip tape to the carbon fiber as it is slick
Old 12-03-2006, 06:12 PM   #11 (permalink)
surpip's Avatar
Member # 22748
did you build that or buy it?
how much
R.I.P. DOZER
R.I.P. Jason
-ALBERT EINSTEIN-
#472tellico rally
Buy my mega cab
KJ6IYH
Old 12-03-2006, 06:15 PM   #12 (permalink)
Member # 39371
Send a message via AIM to currupt4130
how much
Did you read?
The mountains are calling and I must go.
-John Muir
currupt4130 is offline   Reply With Quote
Old 12-03-2006, 06:18 PM   #13 (permalink)
usmcdoc14's Avatar
Member # 13344
how much
the gun or the handguard?
the answer would be built
and both
Old 12-03-2006, 06:24 PM   #14 (permalink)
surpip's Avatar
Member # 22748
you build the fal?
how?
link?
R.I.P. DOZER
R.I.P. Jason
-ALBERT EINSTEIN-
#472tellico rally
Buy my mega cab
KJ6IYH
Old 12-03-2006, 06:27 PM   #15 (permalink)
Mr. Personality
Azzy2000's Avatar
Member # 11869
christ
Azzy2000 is offline   Reply With Quote
Old 12-03-2006, 06:36 PM   #16 (permalink)
usmcdoc14's Avatar
Member # 13344
you build the fal?
how?
link?
I picked up a fal that some dude shot corrosive ammo through and destroyed the barrel.
Got it for like $400 and came with a spare barrel.
sent the spare barrel to.....fuck........someone from here 4runner? animator?......fuck, I don't feel like looking for the thread well anyway they cut the barrel and threaded it. I pulled the old barrel. fixed the receiver brow and installed the new barrel. checked the headspacing and made all sorts of nifty shit for it like:
vertical take down lever with knurled knob
extended and widened magazine release
"fixed" extended safety
adapted a forward assist charging handle
you get the idea
total investment into the gun so far is maybe $600 (minus the EOtech) the gun is worth ??? i dunno
Old 12-03-2006, 06:41 PM   #17 (permalink)
surpip's Avatar
Member # 22748
why do you need a forward assist?
i know the m-16s have them also, just dont know what thier real purpose is
R.I.P. DOZER
R.I.P. Jason
-ALBERT EINSTEIN-
#472tellico rally
Buy my mega cab
KJ6IYH
Old 12-03-2006, 06:48 PM   #18 (permalink)
usmcdoc14's Avatar
Member # 13344
if you gently allow the bolt forward because you don't want to make noise the bolt will not lock as it does not have the momentum. The forward assist allows me to "hand chamber" a round.
Old 12-03-2006, 06:54 PM   #19 (permalink)
surpip's Avatar
Member # 22748
ahhhh
*goes to try it on his*
R.I.P. DOZER
R.I.P. Jason
-ALBERT EINSTEIN-
#472tellico rally
Buy my mega cab
KJ6IYH
Old 12-03-2006, 08:08 PM   #20 (permalink)
usmcdoc14's Avatar
Member # 13344
ahhhh
you shot yourself didnt you ?
Old 12-03-2006, 08:13 PM   #21 (permalink)
surpip's Avatar
Member # 22748
nope, no holes that shouldn't be in me
R.I.P. DOZER
R.I.P. Jason
-ALBERT EINSTEIN-
#472tellico rally
Buy my mega cab
KJ6IYH
Old 12-04-2006, 03:13 AM   #22 (permalink)
usmcdoc14's Avatar
Member # 13344
so did you see how a forward assist works?
Old 12-04-2006, 01:02 PM   #23 (permalink)
usmcdoc14's Avatar
Member # 13344
ok now to line the bitch for heat reflection.
Do you think aluminum foil (in a few layers) would be fine or should i use some aluminum roof flashing ?
Old 12-04-2006, 01:35 PM   #24 (permalink)
Member # 12499
Fiberglas insulation!
Wrenchin' to riches!
If you want peace, prepare for war.
PTSchram is offline   Reply With Quote
Old 12-04-2006, 02:28 PM   #25 (permalink)
Numidian's Avatar
Member # 36317
Send a message via AIM to Numidian
How about some of the insulation like they put the bottom of a car hoods
Brennan
Nemo me impune lacessit
Numidian is offline   Reply With Quote
