lets go Squatchen
Member # 14561
If you are ever going to be in a situation where a single source of fuel might be an issue, like in a foriegn country, then most definately.
Having something that runs on white fuel, kerosene, and diesel is kinda cool. But the later do introduce a lot of maintenance.
Want to know how I lost 25lbs in 9 weeks? Try INSANITY®. www.beachbodycoach.com/petermhope I love it when a plan comes together Colorado Springs, CO Based FFL-07/SOT |
Fistful of Boomstick
I like multi fuel stoves just for the reason of a "backup"
Ya its nice to run white gas all the time but I can find diesel or kero just about anywhere in any god forsaken country/place
Doc-14 Tactical Products: When it absolutely, positively needs to be made from random crap found in the back of my garage. You cant ban knowledge, learn to make your own guns right Here. New York, Colorado, Maryland, Conneticut….is your state next? Yes it is. Write, Vote and Fight. |
#5 (permalink) | |
look at some MSR or something
lets go Squatchen
Member # 14561
MSR x2
Look in the camping thread for some online stores/sources This thing is awsome, but pricey white gas, petrol, diesel, kerosene, avgas, moonshine, etc http://www.cabelas.com/cabelas/en/te...cat570007&rid=
Want to know how I lost 25lbs in 9 weeks? Try INSANITY®. www.beachbodycoach.com/petermhope I love it when a plan comes together Colorado Springs, CO Based FFL-07/SOT Last edited by aloharover; 01-05-2007 at 07:00 PM. |
I have never had a coleman/peak(whatever) stove not rust/leak/catch on fire
Member # 5233
I'll cast a vote for the Brunton http://www.brunton.com/product.php?id=60
I'll also cast another vote against coleman. Even though Peak is their "high-end" line and are good stoves, stay away from the ones only labeled coleman. |
#10 (permalink) | |
Member # 144
That's because you're a pinko fascist. - Haole I know what antidisestablishmentarianist means |
ya its fun to throw a flaming peak stove out the vestibule of the tent while trying to make some fucking oatmeal in a 6 foot base of snow
ya, I HIGHLY recommend that
#12 (permalink) | |
Member # 144
I caught a national forest on fire once with white gas anyway, I can't say squat ![]() FWIW a whisperlite international will burn anything and can be had for around $70. Why buy cheap?
That's because you're a pinko fascist. - Haole I know what antidisestablishmentarianist means Last edited by mike; 01-05-2007 at 08:16 PM. |
#14 (permalink) |
I'll get 'flamed' for this for sure, but
I've had a coleman dual fuel lantern for roughly a decade and similar stove for about 5 years. If nothing else I like it because unleaded pump gas is way cheaper than white gas. Plus I only have to carry one kind of gas can for quads, etc. No heavy ass propane bottles. No extra can of special white gas. Whatever. I don't know what these guys are talking about with their problems with coleman. They've always done right by me. I still have a stove and lantern that came from my parents and are just about as old as me and they still work fine. They just burn the white gas only is all.
Mantra: The more you learn, the more you realize how little you really know. Translation: If you think you know it all.....you don't know jack. |
#16 (permalink) |
Member # 4862
I used a Coleman 440 multi-fuel for almost 10 years, never gave me a single problem. However, the newer stoves are lighter, use a wider range of fuels and are easy to repair in the field. Not to mention that with a different range of fuels you can select a fuel that has a higher "BTU" to shorten your boiling time on water. I have no beef with Coleman/Peak1 but MSR and some of the other brands make some really nice stuff. Their technology is first rate...
[url]http://www.myspace.com/jerrywsparks[/url] Last edited by fatkid; 01-14-2007 at 06:46 PM. |
#17 (permalink) |
IMO unless you're traveling to foreign countries or are in locations where fuels are scarce, the multi-fuel stoves are more expense and trouble than they're worth. Burning diesel or other types of fuel will be undesirable in most situations due to the maintenance involved as well as the lower amount of heat they put out. What kind of stove are you looking for anyway? Everyone is posting backpacking and lightweight stoves which may not even be what you're looking for. I personally have an MSR Pocket Rocket stove and love it.. doesn't take time to "prime" or heat up or anything.. just turn the knob and it heats... FAST.
#18 (permalink) | |
Member # 4862
[url]http://www.myspace.com/jerrywsparks[/url] |
#20 (permalink) | |
Member # 17311
I have a "wisperlite" Love it. I don't remember what it burns, but I got enough white gas to last a WHILE.
Edit: Just looked it up. It's the Wisperlite International Quote:
Nex Pro Evinco "Death Before Defeat" Last edited by Cue-Ball; 01-16-2007 at 11:02 AM. |
#21 (permalink) | |
Member # 4862
#22 (permalink) | |
Member # 34936
. . . but in the Kalahari it is always Tuesday, or Thursday, or whatever day you like . . . |
#24 (permalink) |
Poor White Trash
Member # 4387
I have a multi fuel coleman, works fine. It holds enough fuel in the tank for two or three days, which is usually plenty. I've used both unleaded gas and white gas in it, both work fine(but the unleaded is a bit stinky).
