AR-10 Makers - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-10-2007, 04:53 AM   #1 (permalink)
4in100's Avatar
Member # 51267
Send a message via AIM to 4in100
AR-10 Makers
I saw Armalite, and their's are listing for like $2k. Who else makes AR-10s. I'm looking at possibly stepping up to the .308 caliber for fun and hunting.
Originally Posted by ky scrambled View Post
Boheefus I pray you make a squirty dirty in yer My Little Pony panties before noon
Tellico One 65
4in100 is offline   Reply With Quote
Old 01-10-2007, 06:44 AM   #2 (permalink)
indulf's Avatar
Member # 6156
http://www.rockriverarms.com/item-de...TOKEN=52911627
i like these and hope to get one in the next couple of years.
they have standard length ar10s for right at the same pricing, and a "varmint" rifle for a couple hundred more.
note that they aren't available until winter 07 or so depending on the model.
"whatever doesn't kill me postpones the inevitable"
92 xj, 01 xj, 09 kawasaki versys
indulf is offline   Reply With Quote
Old 01-10-2007, 06:46 AM   #3 (permalink)
4in100's Avatar
Member # 51267
sweet. If you might prefer a ar-15 we might could work out a deal. I don't need 2 EBRs
Tellico One 65
Old 01-10-2007, 07:04 AM   #4 (permalink)
Member # 79207
I have been looking at DPMS arms, but the more I like I think other semi auto 308 could be just as fun for less
otherloginbroke is offline   Reply With Quote
Old 01-10-2007, 07:47 AM   #5 (permalink)
Super Willie
Tech Tim's Avatar
Member # 19067
When looking at Armalite AR-10s, watch out for model variations:
Originally Posted by Armalite bulletin
Because of the small number of early AR-10s produced between the late 1950s and early 1960s, no effort was made to maintain interchangeability with them, and no testing has yet been conducted to determine which parts interchange.
....snip......
For brevity, the new ArmaLite rifles are collectively referred to as AR-10s. Four models of the AR-10B series exist:
AR-10B: The base model of the new ArmaLite line. It is patterned after early 1960 era rifles, and is produced largely for nostalgic reasons. The charging handle looks like an upside down trigger and is located at the front of the carrying handle. It special brown furniture and a rear sight elevation window at the rear of the carry handle.
AR-10A2; virtually identical to the M16A2 service rifle, but caliber .308.
AR-l0A4: A flexible combination of the AR-10A2 and the AR-10(T). It is generally identical to the AR-10A2 except that the upper receiver and gas block are manufactured with the “Picatinny Rail” sight mounting surfaces of the AR-10(T). Removable iron or telescopic sights are optional.
AR-10(T); target model featuring a 24 inch long, medium weight target barrel, tubular handguard, match trigger, and Picatinny Rail receiver and gas block.
Each rifle is matched by a similar carbine: virtually identical save for a 16 inch long barrel. The T carbine is equipped with a standard trigger rather than the match trigger of the AR-10(T) rifle.
My vote goes for the Stoner SR-25. Beautiful rifle and many of the parts are interchangeable with and AR-15, so if you have both, you can cut back on spares. Don't have one yet, but it is on the list...
Tim Lund
Yeah, I wear a Kilt... what you're not man enough?!
Want beadlocks? Allied Beadlocks.... Best designed and best priced aluminum beadlock on the market!
Got 40 SPLINE? Time for you to get 40 spline too! 40 spline hubs, spindles, outer stub shafts, 40 spline 14 bolt & Dana 60 Air Lockers
http://www.wildwestfab.com.... WILD WEST OFF ROAD 360-264-5363
Tech Tim is offline   Reply With Quote
Old 01-10-2007, 09:07 AM   #6 (permalink)
Vagitarian
planefixer's Avatar
Member # 33328
DPMS has their LR .308. Basically their version of an AR-10.I usually see them in the $1100-$1300 range.
Just anohter poop-flingin' day in the jungle.
planefixer is offline   Reply With Quote
