Build my first AR! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-06-2007, 08:17 AM   #1 (permalink)
Jason R's Avatar
Member # 11598
Build my first AR!
Looking to "build" my first AR, but I was amazed that it was going to cost so much. I want to build a midlength rifle. I was thinking of having Denny build my upper (Globaltactical.com highly recommended on AR15.com) Here goes...
Lower:
RRA, LMT $115
Upper:
CMT $99
Barrel:
Denny's Operator $280
LPK:
RRA + Magpul Enhanced Trigger guard $70
Trigger:
Tuned RRA from WOA: $120
Rail system:
Daniel Defense 9.0 M4 Rail: $366
BUIS:
Troy Industries Rear BUIS: $140
Grip:
Tango Down Grip $31
Bolt/Carrier:
CMT/Stag M16 Staked Carrier $130
Charging Handle:
CMT?? $20
Buffer tube & STock:
Magpul CTR Stock Kit $167.95
Flash Hider
Not Sure??
Total: $1558.95
Seems expensive. Am I spending too much?
I also can't find a damned RRA lower...or hardly any lowers for that matter right now. I can find a complete RRA lower with LPK and 2-stage trigger for $350 :\
This space for rent.
Jason R is offline   Reply With Quote
Old 03-06-2007, 08:36 AM   #2 (permalink)
bronko's Avatar
Member # 18748
You can definitely do better on some of those prices. The Denny's barrel seems to be a waste of $$$ IMHO. Frankly give Pete at Legal Transfers a call at 603-770-2281. Pick up a complete RRA rifle with a NM trigger then go ahead and add your goodies. I believe he still has US property marked lowers in stock.
Bummin around in a SAS'd 88 Toy w/ a 3.4 :flipoff2:
bronko is offline   Reply With Quote
Old 03-06-2007, 08:45 AM   #3 (permalink)
Smores!
Scott@Rockstomper's Avatar
Member # 1889
Local shop had Bushmaster, DPMS, and Sabre stripped lowers the last time I was in there. Not sure mailorder-wise. Looked at all three, didn't see any reason (and interestingly, the counterman was the one who suggested it) to spend more than the $105ish on the DPMS. I really didn't like the engraving on the Sabre (it's pin-impact rather than machined) but that's a personal preference thing.
Your parts list has you spending a fortune on all top-end stuff... you can get by for a lot less $$$, but you'll step away from the top-end components you're pricing out, and trade away some features in the process. So "am I spending too much" is pretty subjective... to get what you've listed, you're going to spend what you've listed, give or take a few bucks here and there.
Scott@Rockstomper is offline   Reply With Quote
Old 03-06-2007, 09:11 AM   #4 (permalink)
Member # 64421
Magpul parts are gay.
TheRedHorseman is offline   Reply With Quote
Old 03-06-2007, 09:15 AM   #5 (permalink)
Petty Amm Flipper
aloharover's Avatar
Member # 14561
Scott,
was this at Jensens or a place closer to Denver?
Jensens has the DPMS for the same price, but if you found another plce further south I will check them out.
Want to know how I lost 35lbs? Try INSANITY®.
www.beachbodycoach.com/petermhope
I love it when a plan comes together
Colorado Springs, CO Based FFL-07/SOT
aloharover is offline   Reply With Quote
Old 03-06-2007, 09:22 AM   #6 (permalink)
Petty Amm Flipper
aloharover's Avatar
Member # 14561
Jason,
why not just get a prebuilt upper from your favorite vendor?
Bushmaster M4 type upper is 600.
RRA has a complete M4 kit for $680.
If this is your first AR get something like this. Build it, play with it. Then figure out what you want to change.
Old 03-06-2007, 09:30 AM   #7 (permalink)
Member # 64421
Or get an Ameetec one for $400, great uppers, awesome price especially if you order the complete lower a day or two later to avoid the excise tax.
UPPER Call them and ask for the chrome lined barrel, should cost you $30 more.
LOWER
Cheap RRA or WOA NM triggers
The M16 carrier is not 100% needed but it would be no problem to sell off the AR cut one that comes with the Ameetec upper and buy an M16 carrier from del ton or wherever. I'm sure you could always ask Ameetec to put an M16 carrier in for you, which they might do for cheap or free depending on if they have any handy.
Expect a couple weeks worth of wait on the lower due to the demand for them at that price.
Old 03-06-2007, 09:32 AM   #8 (permalink)
Jason R's Avatar
Member # 11598
The problem with pre-built kits is that I have a bunch of extra parts left over...especially if I'm going to go with a Rail.
Old 03-06-2007, 10:28 AM   #9 (permalink)
Petty Amm Flipper
aloharover's Avatar
Member # 14561
Plastic handguards and a barrel nut?
Old 03-06-2007, 10:35 AM   #10 (permalink)
Jason R's Avatar
Member # 11598
Ok....what tools are required to remove the front sight and gas block, barrel nut, etc...?
Old 03-06-2007, 10:40 AM   #11 (permalink)
Member # 64421
Call up Ameetec and see if they can build it for you like that, they have rails in stock. They can whip up just about anything you wish.
Old 03-06-2007, 10:43 AM   #12 (permalink)
Fistful of Boomstick
usmcdoc14's Avatar
Member # 13344
Send a message via AIM to usmcdoc14 Send a message via Yahoo to usmcdoc14
a hammer
Doc-14 Tactical Products:
When it absolutely, positively needs to be made from random crap found in the back of my garage.
You cant ban knowledge, learn to make your own guns right Here.
New York, Colorado, Maryland, Conneticut….is your state next? Yes it is. Write, Vote and Fight.
usmcdoc14 is online now   Reply With Quote
Old 03-06-2007, 10:49 AM   #13 (permalink)
Petty Amm Flipper
aloharover's Avatar
Member # 14561
Pin Punch.
Old 03-06-2007, 10:49 AM   #14 (permalink)
Smores!
Member # 1889
Jensen. I haven't found anywhere closer to home (or to Denver, for that matter) that has any of what I've wanted AR-wise, and has been open at any time I can get there.
Old 03-06-2007, 10:56 AM   #15 (permalink)
Member # 64421
Barrel nut requires a barrel nut wrench. Though I guess if you really didn't give a shit you could use some big assed vice grips.
Old 03-06-2007, 11:01 AM   #16 (permalink)
Petty Amm Flipper
aloharover's Avatar
Member # 14561
Shit I wasn't even thinking about removing the barel from the upper
Get a wrench, they are cheep <$20
Old 03-06-2007, 11:58 AM   #17 (permalink)
Jason R's Avatar
Member # 11598
Do you think I'm spending too much money on quality parts? AR15barrels.com quoted me about $950 on the upper using CMMG barrels and a standard bolt carrier.....
Old 03-06-2007, 01:02 PM   #18 (permalink)
Petty Amm Flipper
aloharover's Avatar
Member # 14561
No. But unless you are building a rifle to compete in High Power or a 24" HB varmit gun I personally feel like it's too much period. But that is my opinion, period.
If it's what you want the prices quoted for those specific parts are ok.
Old 03-06-2007, 01:27 PM   #19 (permalink)
Jason R's Avatar
Member # 11598
If you think it's too much, what other parts should I be looking at???
Old 03-06-2007, 01:52 PM   #20 (permalink)
bronko's Avatar
Member # 18748
Seems like your building more of a decent plinker and not a competition rifle so why blow the $$$ on bling unless you need to? If I were you I'd get the following things:
Flattop upper (mount whatever optics you want)
Yankee Hill flipup sights
16" Chrome lined barrel (contour of your choice)
Quality lower parts kit (RRA NM trigger)
And the rest really boils down to price. You can buy prebuild uppers from Stag or RRA for a good price and save some coin. That and the Daniel Defense Rail is WAY overpriced, Yankee hill makes some decent free float rails.
Old 03-06-2007, 03:32 PM   #21 (permalink)
Redmist's Avatar
Member # 43646
I have a hard time dropping $366 on a rail system....
I have used plenty of the $100 YHM Lightweight rails and they are great!
If your going to remove the barrel then you need an action block as well.
Redmist is offline   Reply With Quote
Old 03-06-2007, 07:18 PM   #22 (permalink)
Member # 3000
To me that seems like a rediculouse amount to spend on parts for an M-4gery. I personally don't like rail systems, what do you need 4 rails on the front of your rifle for? Especially one for $366. The trigger price seems alright.
Lowers are all pretty much the same. I could see spending that kind of money on a competetion benchrest rifle, but not on a carbine.
Aron82 is offline   Reply With Quote
Old 03-06-2007, 09:21 PM   #23 (permalink)
Jason R's Avatar
Member # 11598
I'd like to use it for 3-gun...
So should I stick with a standard guard? Should I go with a carbine length rifle?
Old 03-06-2007, 09:39 PM   #24 (permalink)
Member # 64421
If you NEED a rail just get the YHM free float, unless you are putting a light on there or a bipod(that sticks you in open class) then you are going to be just fine with standard handguards.
My YHM free float, rifle length on a carbine gas system. YHM flip up front sight, GG&G flip up A2 rear. Knights VFG, Pentagon X3 in a Daniel Defense offset mount.
Old 03-07-2007, 11:04 AM   #25 (permalink)
bronko's Avatar
Member # 18748
LOWER
Placed an order for two $200 lowers. Wait time [drum roll please]
May! [/drum roll please]
Still not to bad.
