Member # 37244
AK reciever bending jig?
I`m going to buy one. I like the model DPH builds and it`s reasonable at $150. Has anyone seen any others worth considering? I`d like to spend no more than $200.
Member # 64421
They are a pain, at least the Tapco ones are, the AKBuilder ones are probably a lot better.
1. Make the bottom bend in the jig 2. flip the die over in the jig, use a hammer to get the bottom of the receiver fairly flat and sharpen up the bends. 3. Flip it again, hammer the upper rails over, hammer them some more, then use a piece of scrap steel to smooth them out. 4. weld the lower rails in. 5. install center support and rivet 6. adjust the holes to fit the kit 7. heat treat the receiver and ejector 8. rivet the receiver to the kit 9. use paint, marker, or dye to mark the rails and figure out where it's binding up the bolt and carrier, use files or a rotary tool to remedy this. Then you have a receiver. It's nowhere near as easy as a good premade receiver. |
Member # 60950
You could look at the Poor Man's Jig on Gunco.net. Couple of pieces of angle iron and some bolts. Most everyone that's used it says it works. YMMV. I've also seen it posted on AKforum and AR15.com in the BIY forums.
Fistful of Boomstick
heat with a oxy torch till a magnet will not stick and then quench in a metal "mud pan/wall paper glue pan" filled with used motor oil.
Then I stick it in a pan and burry/fill it with clean sand and bake at 350* for an hour and turn off the oven till cool to anneal it.
Doc-14 Tactical Products: When it absolutely, positively needs to be made from random crap found in the back of my garage. You cant ban knowledge, learn to make your own guns right Here. New York, Colorado, Maryland, Conneticut….is your state next? Yes it is. Write, Vote and Fight. |
lets go Squatchen
Member # 14561
I made my own jig. Details are in the AK DIY thread. Basically a piece of 2/3"x2"x12". two 1/4"x2"x12". Used the blueprints found online and a sawzall to cut to shape. Finished with a long flat file and a belt sander. The female part of the jig is some 1/4x2x2 angle welded together.
Want to know how I lost 25lbs in 9 weeks? Try INSANITY®. www.beachbodycoach.com/petermhope I love it when a plan comes together Colorado Springs, CO Based FFL-07/SOT |
Member # 37244
Just got back from the gunshow. I thought I might find an AK reciever fairly cheap, I was wrong. They started at $110 and went up. The DPH jig I wanted isn`t available now for some reason, according to their website.
![]() I don`t know what to do now.
#12 (permalink) |
Member # 6156
duh, make your own like plenty of others have mentioned on the site. plans are out there.
"whatever doesn't kill me postpones the inevitable" 92 xj, 01 xj, 09 kawasaki versys |
#13 (permalink) | |
Member # 21936
Sad, I know, but I really enjoyed filling the garage with smoke for a little while there. SWMBO couldn't figure out why I smelled like exhaust when nothing had been running
