decelerator pads for rifle - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-12-2007, 10:51 AM   #1 (permalink)
Member # 13707
Who makes a good decelerator pad for a rifle?
How do you know if you need to add a little length to better suit me?
I have a savage model 10 in .308. The stock pad doesn't do much, and I shot enough rounds to bruise my arm.
Toyoda is offline   Reply With Quote
Old 08-12-2007, 06:02 PM   #2 (permalink)
Member # 377
If a .308 is bothering you, I suggest duct taping a maxi pad to rifle to ease the pain on your vagina.
Just kiddin'
Actually, I've heard very good things about both the Limbsaver and the Kick Eez.
east_beast is offline   Reply With Quote
Old 08-12-2007, 07:04 PM   #3 (permalink)
Member # 17904
I've often wondered about those mercury (or some heavy liquid) filled recoil compensators that I've seen in Brownell's catalog. Anybody use one of those?
HalfFastFord is offline   Reply With Quote
Old 08-12-2007, 07:29 PM   #4 (permalink)
Member # 377
I've been curious about them as well HFF. I'm curious to hear from those with experience. I wouldn't think it'd be all that beneficial in a relatively light recoiling gun like a .308 though. I could see it in an ultralight .300mag and up from that though. I've been kicking around the idea of getting a Tikka T3 in .338mag and if I did, I'd definitely be looking into a Kick Eez and possibly the mercury deal as well, maybe even a muzzle brake too.
Old 08-12-2007, 07:49 PM   #5 (permalink)
Member # 34433
Well I shot a 338 win mag with nothing but a rubber butt stock and for those long days at the range I run a shoulder pad
tonka22 is offline   Reply With Quote
Old 08-12-2007, 07:58 PM   #6 (permalink)
Member # 377
My biggest concern with the Tikka T3 in .338 is that the gun itself comes in at 6 3/8 pounds. Figure a pound for rings and scope and you're still in the neighborhood of 7 1/2 pounds. A .338 that light is gonna kick like a mule.
Old 08-13-2007, 01:26 AM   #7 (permalink)
Member # 3723
I am looking into this system
http://www.knoxx.com/index.html
They list a few rifle stocks. However, if you go to the FAQs, if you have a Hogue stock, they can convert it to their system.
I was pretty impressed by watching people shoot high power rifles with their shoulders against a post, and not having a broken collar bone.
Might be the solution you are looking for
Entropy "After a solid fifteen minutes of passing what felt like multiple babies out my purple starfish, it was over....When I stood up and looked back at my handy work I was pleasantly surprised to find nearly all the water in the toilet completely displaced by what was now a literal MOUND of crap"
themaddhatter is offline   Reply With Quote
Old 08-13-2007, 09:12 AM   #8 (permalink)
Member # 13707
Just kiddin'
I knew that was comming.
I shot off a bipod on the bench for the first time, I didn't really like the way it felt. Running hot loads doesn't help with it either.
my .308 feels worse than my buddys wsm300, and not just a little worse.
Old 08-13-2007, 12:31 PM   #9 (permalink)
Member # 377
Haha! Actually, man I know where you're coming from. My .308 Model 700 just has the factory hard plastic buttplate and when shooting 180gr loads, it can start wearing on you when you start putting round after round through it. I'm going to put a Kick Eez or Limbsaver on it. For a .308, a good decelerator pad is all you'll need.
Old 08-13-2007, 04:22 PM   #10 (permalink)
Member # 13707
It wouldn't be bad, if I didn't insist on using it for a varmit gun, target rifle, hunting gun, do all gun.
Thats the advantage of handloading though.
Old 08-13-2007, 05:23 PM   #11 (permalink)
Member # 377
I understand. Right now, the only centerfire rifle I own is my .308 Model 700. The .308 with the right ammo will take any big game animal in North America (with the exeption of brown bears) within the proper range. It'll take whitetails out to 500 yards or so. Elk out to 300 or so. Black bear to 300. Moose to 150 - 200 or so.
Now, if elk or moose is your primary quarry, you may be better off with another caliber, depending on your hunting territory, but the .308 is a very good all around rifle. When I think of all around big-game calibers for North America, I think of the .30-06, .308, .280, 7mm, and on the bigger end the .300mag.
Now that I'm moving to CO, I may look into picking up a .300mag in the next coupla years.
Old 08-13-2007, 05:28 PM   #12 (permalink)
Banned
Member # 14006
Just kiddin'
Dickfoster is offline   Reply With Quote
Old 08-13-2007, 07:39 PM   #13 (permalink)
Member # 13707
Thank you "DickFoster"
Old 08-13-2007, 08:36 PM   #14 (permalink)
TNToy's Avatar
Member # 5776
I shot a couple rounds through an 870 with a Knoxx stock on it.
When I buy a shotty, I don't know what else I'm putting on it, but come hell or high water... it's getting one of those. If you can make one fit your rifle, do it.
[size=1]ASE Certified Master Automotive Technician
Toyota Certified Expert Technician
Volvo Certified Expert Technician
Suzuki Certified Master Technician
IDPA Certified Master Cardboard Killer[/size]
TNToy is offline   Reply With Quote
Old 08-14-2007, 03:29 PM   #15 (permalink)
Member # 36733
Adding length provided by a 1-2" pad helps if the stocks pull isnt long enough. Pull is defined by the distance from the trigger to the point of the heel of the stock (IIRC). Too long and yer reachin fer the trigger and stretched out across the stock, too short and yer cramped with yer knuckles in yer nose (or thereabouts). I happen to be 6"-3" with long arms and in my case 99.99% of "factory" stocks are about 1.5-2" too short fer me so I've added length with a pad until I get around to restocking the rifle. Cuz I happen to think those pads are kinda ugly the stocks get redone quickly with either a steel crescent or original hard plastic plate.
As to the bruise, only time that is an issue is when the stock wasnt fitted and I didnt have the rifle in the right place when holding it...
D.
[I]Vegetarian is an old Native American word for bad hunter[/I]
DavidVanVorous is offline   Reply With Quote
Old 08-14-2007, 05:49 PM   #16 (permalink)
Member # 13707
It could have been in the wrong position, it was the first time I shot from a bipod. It never felt very comfortable.
Old 08-15-2007, 11:28 AM   #17 (permalink)
Member # 36733
Makes sense, prone really doesnt allow for the same shoulder hold and usually places the butt high in comparison to the other shooting positions. Leastwise thats my experience anyho...
D.
