#101 (permalink) | |
lets go Squatchen
Member # 14561
If you have access to a sheet metal brake I say go for it. The 6x12 sheet metal blanks I got were 3$ each. Not like testing the brake method is going to send someone to the poorhouse. ![]() Pete
Want to know how I lost 25lbs in 9 weeks? Try INSANITY®. www.beachbodycoach.com/petermhope I love it when a plan comes together Colorado Springs, CO Based FFL-07/SOT |
#102 (permalink) |
Fistful of Boomstick
How To Re-crown A Barrel
This is RETARDEDLY simple to do and can improve the accuracy of a
barrel quite a bit. This is also if you cut down a barrel to carbine length (this is done on a FAL barrel as an example) First the shit you will need: crown cutter (i got mine from www.brownells.com it is the 11* target crown cutter. 11* is a great crown as it performs well and the countersink protects the crown) guide dowel to fit the caliber you are doing (once again, brownells. .30 cal guide for AK/SKS/FAL ) handle of some sort for it (i used a 1/4 all thread nut and a old die. or you can spend the cash on a handle. I don't recommend the drill bit one as you want to take your time) 0000 steel wool brass screw or brass ball bearing a little bigger than the cal. you are doing a 1/4 screw is perfect for .308/7.62 valve lapping compound cutting oil hacksaw with a new blade first i saw my crown was SHOT and also noticed that the barrel was corroded at the ends of the lands ![]() so i decided to cut it down to a 17.5 barrel because i should not have to open the gas port (you may/may not need to open the gas port on any gas operated weapon. the shorter barrel produces less pressure, hence less to push the action back) mark it square, i used an old pipe cutter to score it. plug the barrel with a patch a distance past where you are cutting to keep shavings out. ![]() HACK SAW MOTHER FUCKER !!! ![]() Now go and insert the crowning tool with guide dowel into the barrel. ![]() USE LOTS OF OIL AT ALL TIMES AND CLEAR THE CHIPS Apply good pressure and turn away. I rotate the barrel to a different position every time i clear chips and re-oil so i don't get a low spot from my hand pressure. Keep cutting until you have cut the ENTIRE barrel face (this does not apply to Bull or target barrels as they may be wider than your cutter. in that case stop when you get the recess you want) Once you do that keep decreasing your pressure and keep cutting, keep getting lighter and lighter till only the weight of the tool is on it. This give a nice fine finish. remove the tool and clean away any shavings. Now take the steel wool and use it to get rid of the sharp edge on the OUTSIDE of the barrel. The pic is over exaggerated i actualy only used a small piece and rotated it around the edge with my thumb and fore finger.
Doc-14 Tactical Products: When it absolutely, positively needs to be made from random crap found in the back of my garage. You cant ban knowledge, learn to make your own guns right Here. New York, Colorado, Maryland, Conneticut….is your state next? Yes it is. Write, Vote and Fight. Last edited by usmcdoc14; 12-02-2005 at 05:46 PM. Reason: board fuckup |
#103 (permalink) |
hopefully the board wont crash this time
Is the images in the above post working now?
Doc-14 Tactical Products: When it absolutely, positively needs to be made from random crap found in the back of my garage. You cant ban knowledge, learn to make your own guns right Here. New York, Colorado, Maryland, Conneticut….is your state next? Yes it is. Write, Vote and Fight. Last edited by usmcdoc14; 12-02-2005 at 02:21 PM. |
#104 (permalink) |
next you find a way to hold your brass screw. I used a tap holder. If you are using a brass ball just skip to the next.
![]() Dip it in your lapping compound and lap away ! ![]() just twist it back and forth. I once again changed barrel position and also the angle i was hitting at to make sure i did not get a low spot. Use a medium pressure, its better to take your time and do it right instead of too much. Check your progress and stop when you get a nice hairline at the grooves (lands are the high spots of the rifling, grooves the bottom) you can just see it in the next pic. Push out your plug/patch from the breech (dont push the lapping compound INTO the barrel ) and CLEAN THE SHIT OUT OF YOUR BARREL !!!!!and TAADAAAAA! ![]() you now have a barrel with a nice new 11 degree target crown I used a cold blue to protect it but it an be left bare as long as you oil it and remember its bare metal.
Doc-14 Tactical Products: When it absolutely, positively needs to be made from random crap found in the back of my garage. You cant ban knowledge, learn to make your own guns right Here. New York, Colorado, Maryland, Conneticut….is your state next? Yes it is. Write, Vote and Fight. |
#105 (permalink) |
finished and blued
sorry was making some money on some parts ![]() The trick to no streaks is to DEGREASE the fuck out of it with brake cleaner, buff lightly with 0000 steel wool and wipe the dust off with a clean dry rag.
#106 (permalink) |
Member # 6291
hey doc, do you have any more pics of one's that you've painted with that crinkle paint ? I think I'm going to paint some parts of mine that khaki color krinkle ...
[list][*][url="http://www.pirate4x4.com/forum/showthread.php?t=373488"][COLOR=lime]For sale: Ford D60 parts, D44 steering arms, etc ... [/COLOR] [/url] [/list] |
#107 (permalink) | |
#108 (permalink) |
Member # 34936
Doc, does it say anything on the can about baking? Is that something you just decided to do, and found it worked?
Do you coat the entire parts, or just the outer pieces? I'm just wondering how tight the fitup would be if everything(save action and barrel), inside and out, is painted? Those screws looked painted as well. I'm thinking about getting the Romanian one, painting metal parts with the Rustoleum texture, and the furniture with this: http://www.zolatoneaim.com/inter_1.html ![]() Maybe its just the ghetto in me... I like the Butler Creek folding stocks for 10/22's and Mini-14/30. I wonder how hard it would be to adapt the folder portion onto an AK. I haven't seen this type stock made for the AK. ![]() Oh, and Doc, did you test fire any at the range today? I think I remember reading that you were going to test fire a recent build today... I could be wrong, I've spent 12+hours reading on these since last night...
. . . but in the Kalahari it is always Tuesday, or Thursday, or whatever day you like . . . |
#109 (permalink) | |
I learned that baking on regular spray painted shit on metal will bond it a LOT better. Then i saw some guys on another board were doing it with the textured. I did test chunks of steel and subjected them to different torture/chemicals and was happy so i used it ![]() Entire parts, assembled gun. minus bolt/bolt carrier, trigger shit, springs, gas piston. Light coat inside, outside i control the texture till it looks like what i want. what cant get removed stays together and what comes off is sprayed separately. I let it dry and then bake in the oven at 350-400 for an hour and turn off the oven. Remove when cool (this also anneals the parts good too) Its the ghetto in you show me a pic of the stock and i will find you the AK version or how to adapt it Yes, the range was closed today and i did not know. Tomorrow at 10am unless i have to be at the airport i will be shootin'
#110 (permalink) |
Member # 34936
Ok, that makes sense about the coating. It definitely looks better than the factory blueing that comes on most of these things. The crappy looking wood stocks and ugly blueing is a lot of what has turned me off to these rifles before... I actually prefer stainless... but a good paint job will do for a beater.
![]() Here's an example of the 10/22 stock: http://www.gunaccessories.com/ButlerCreek/Folding.asp A mini-14 stock on ebay: http://cgi.ebay.com/BUTLER-CREEK-STA...QQcmdZViewItem Also another for the 870 shotgun here: http://www.combatstocks.com/Butler_C...ington_870.cfm I'll get a chance to look at some both on and off the rifle tomorrow, I'll see if it has to be cut off or can be otherwise detached. They feel very solid, and collapse tighter than the AR stock you used. Yours is practical for a better cheek weld, but the folder would take less room in the truck... and is cheaper. I read your description on how to heat treat the receiver earlier. It makes sense. I read another one on one of the sites mentioned here, and it claimed to heat the treated areas to red hot and quench, twice. Then, heat to red again and allow to cool. IIRC from welding school this actually softened the metal. Heating to 500 like you wrote would treat it to a good hardness. Baking to 400 would be on the verge of hardening it to the max. Somewhere in the 400-420 range is where the transition begins. If its bare shiny metal, you can see it form a straw color. Blue/Purple form in the 500-600 degree range... At least, thats how I remember it. I definitely neeed to brush up on this.
. . . but in the Kalahari it is always Tuesday, or Thursday, or whatever day you like . . . Last edited by basketcasejeep; 12-03-2005 at 07:54 PM. |
#111 (permalink) |
![]() hows that one ? thats from www.aceltdusa.com (same maker as my AR stock) they sell folding kits for it and a specialty adapter that you cut the back of the tang off and just bolt the stock on
#112 (permalink) |
Member # 34936
This is a good idea for a cheek rest.
![]() http://www.aceltdusa.com/images04/ga...Wrap1-602w.jpg AMD-65: http://www.aceltdusa.com/images04/Cu...373f2_615w.jpg
#113 (permalink) |
Knee Grow
Member # 12575
Location: It puts the lotion on its skin OR it gets the hose
I have read all of Doc's posts and I feel this would be a great addition to them http://gunsgutsandgod.com/SBS%20tutorial.htm
it answered a bunch of questions I had after reading through this thread
She said her name was Bambi, I said thats a coincidence darlin cause I was just thinkin about skining you like a deer then wearing your face like a mask as I do my little kooky dance |
#114 (permalink) |
Member # 6291
that's a good link, thanks jstarnes ...
hey doc, when I asked a couple of days ago for more painted pics I meant to specify ones that were any other color than the black ones you already posted. Where did you get the pieces in this pic you posted. I've searched a fair bit and can't find ones like that ... at least in the pics of the parts that places say they sell: ![]() EDIT: Just found the pistol grip piece. I saw one you guys reference a SAW and that's what the grip piece is from a SAW.
[list][*][url="http://www.pirate4x4.com/forum/showthread.php?t=373488"][COLOR=lime]For sale: Ford D60 parts, D44 steering arms, etc ... [/COLOR] [/url] [/list] Last edited by morpheus; 12-05-2005 at 07:40 PM. |
#115 (permalink) |
www.tapco.com makes them hey are styled after the M249 SAW
Doc-14 Tactical Products: When it absolutely, positively needs to be made from random crap found in the back of my garage. You cant ban knowledge, learn to make your own guns right Here. New York, Colorado, Maryland, Conneticut….is your state next? Yes it is. Write, Vote and Fight. Last edited by usmcdoc14; 12-05-2005 at 07:42 PM. |
#116 (permalink) | |
Member # 6291
#117 (permalink) | |
and when you do find mags that wont lock in grind a little from the "duckbil" on the mag NOT THE MAG LATCH ON THE RECIEVER !!! make the mags fit your AK not the other way
#118 (permalink) |
"Official"
Member # 27575
Doc,
When you bake stuff, do you use the oven in your kitchen, the same you cook with? I suspect you don't have any issue with fumes or any residual smells. I am going to be baking a finish onto some smaller parts and I have toyed with the idea of buying a small toaster over to use instead of the one in the kitchen. However if it's working find for your, the money could be better spent on more gun parts ![]() !
Wheeling?!?!? WTF is that?
#119 (permalink) | |
as I can suspend the parts from the inside and nothing fawks up the finish. That and the heat is nice and even inside.no issues with fumes when its done/finished, but it will put off a odor when baking. so no, my brownies dont taiste like Rustolium ![]() If you could find an old stove with shot top burners it will probly cost you less than the toaster oven (free on the side of the road) and you could also do home powdercoating in the garage to boot
#120 (permalink) |
Member # 34936
I think they may not have updated the site since the ban expired?
Maybe our resident gun law armchair experts will know whether guns built between 94 and 04 are still illegal to modify, and the ones built '05 and newer are exempt?Edit, Doc you beat me to it. So does the ban still apply to guns built in those years or are they now exempt?
. . . but in the Kalahari it is always Tuesday, or Thursday, or whatever day you like . . . Last edited by basketcasejeep; 12-13-2005 at 03:13 PM. |
#121 (permalink) | |
thread your barrels, throw away your thumbhole stocks, rape, pillage, plunder...
#122 (permalink) | |
Member # 6291
#123 (permalink) |
Member # 6291
I see a few of these laser cut receivers for sale for fairly cheap $30 ... they don't have the magazine "bumps" in them though ... what's the word on them ?
#124 (permalink) | ||
![]() its thin sheet so take your time welding, they require heat treating when done. If you want the "bumps" for magazine stability just measure how high it needs to be from the reciever stub in your parts kit and plug weld a plate to the inside that matches that thickness
#125 (permalink) | |
Member # 30359
Doc, I've been reading this thread over and over and have figured out what to spend my Xmas money on.
I'm planning on picking up a Romanian parts kit from Gunbroker. I thought about going to the next gun show, but I can't wait. Got a few questions for ya though, if ya don't mind. I apologise if any of these have already been answered, I have ADD Is this the skull bashing collapsable stock I would need? collapsible stock Also does the mounting for it count as the rear trunnion......I.E. would this be two US parts? But I'm also thinking....do I really need a collapsible stock like this? I like the fact that I could save a little room, but do these really collapse that far? It would save me a little money to just get a 4 piece set. I thought about a folding stock but I'm not sure wether I like them or not. I noticed in the rifles built on the first page you replaced the stock and hand grip (2parts), fire control (3 parts), and gas tube (1 parts) to make the 6 US parts you needed. But the reciever would count as a US made part wouldn't it? I'm going to get an unbent reciever to save a little money. On the trigger group, do i need the single hook or double hook? I've noticed most of the time they are the same price. And is "G2" better than anyone else's US trigger groups? So so far this is what I've got... part........................cost...............US parts romanian AK47.........$99.97 gunbroker.com collapsible stock......$84.95..............2 fl gun works pistol grip................~$20...............1 g2 trigger group.......$39.................3 tickbitesupply --or akparts.com.......$37.95 *not listed as G2 Unbent reciever......$24.95..............1 akparts.com Total...................~$270...............6 I plan on getting a front hand gaurd to match the stock/pistol grip when I get closer to completion, and a birdcage flash hider. And I didn't factor in the screws or other small supplies into the cost. Is there anything you can think of that I'm missing? TIA for the help! ![]() Edit: I just saw the link to DPHarms above..... They have a Ewbanks receiver that is already predrilled and folded for $50.....are these any good or should I stay with the unbent recievers?
BDR 67 FJ40 "Last Minute" - build thread 97 XJ Quote:
