#126 (permalink) | |
El Guapo
Member # 9722
Romanians have chrome lined barrels, they are easy to tell because they have the hand grip on the front grip. I got mine on gunbroker for $105. Havn't looked at what receiver I'm going to go with. Still researching. |
#127 (permalink) | |
Fistful of Boomstick
also look at http://www.tapco.com/product_informa...t=214&last=214 ![]() $200 includes romanian kit, colapsable stock, fore end, grip, and fire control group.
Doc-14 Tactical Products: When it absolutely, positively needs to be made from random crap found in the back of my garage. You cant ban knowledge, learn to make your own guns right Here. New York, Colorado, Maryland, Conneticut….is your state next? Yes it is. Write, Vote and Fight. |
#128 (permalink) |
Member # 6291
hey Doc, I just got an M-4 stock and am going to make a piece out of 1" stock like Mac made you. My stock has this piece that I assume is an indexing ring (the threaded portion has a slot in it that a tab in the ring rides in) ... it doesn't look like your stock was like that. Is that where you drilled that hole for the small allen screw in one pic ?
a pic like the stock I got:
[list][*][url="http://www.pirate4x4.com/forum/showthread.php?t=373488"][COLOR=lime]For sale: Ford D60 parts, D44 steering arms, etc ... [/COLOR] [/url] [/list] Last edited by morpheus; 12-29-2005 at 07:30 PM. |
#129 (permalink) | |
you can buy it here ![]() http://www.aceltdusa.com/ar15.htm
#130 (permalink) | |
lets go Squatchen
Member # 14561
A 2mo an a 16mo don't leave me much time. Complete build...no. I did finally get some free time today and got the jig dialed in. 1st one I used 3/16" for the side plates by mistake. So the receiver was 1/8th too narrow. So I got some 1/4" and remade the sides. #2 bend was too wide... somehow .25+.25+.75=1.3"So I had to spend some time with some wet/dry and oil and worked on the side plates. Finally got the width correct and I measured it before bending a flat. #3 came out perfect. I got the trigger guard attached. Ft trunnion located, mags lock up tight no wobble. Located the holes, drilled the receiver, front trunnion is screwed in. Rr trunion located and screwed into place. Now I need to finish up the barrel & gas block mods I am working on and get all of that put back together. Then head to the range and test fire. If everything works ok, disassemble, sandblast, park, and GunCote. Pete
Want to know how I lost 25lbs in 9 weeks? Try INSANITY®. www.beachbodycoach.com/petermhope I love it when a plan comes together Colorado Springs, CO Based FFL-07/SOT |
#131 (permalink) | |
but if you cut off the pistol grip on a Romanian lower then yes you could HOW TO MEASURE THE DEPTH TO DRILL THE FRONT RIVITS !!!! 1) you need a pair of calipers or a depth micrometer to be "accurate" you can eye fuck it and still be fine. look at the front of the front trunnion right where the barrel sticks out. see the trunnion? see the barrel? That is the the max depth you can drill before hitting the barrel because neither the barrel or trunnion taper easy as fuck huh?Just take a drill, put the point of the drill on the barrel, slide a stopcollar till it hits the trunnion and thats it. ya need a picture ?
#132 (permalink) |
oh and as for "accedentaly" drilling into the barrel
big fucking deal look how deep the cross pin slot is drilled into the barrel and that is factory
#133 (permalink) |
lets go Squatchen
Member # 14561
Was able to get some more time in the garage this morning. Here is some more of my progress.
The die parts
Want to know how I lost 25lbs in 9 weeks? Try INSANITY®. www.beachbodycoach.com/petermhope I love it when a plan comes together Colorado Springs, CO Based FFL-07/SOT Last edited by aloharover; 01-29-2006 at 01:57 PM. |
#134 (permalink) |
lets go Squatchen
Member # 14561
Lining up the retaining plate and flat with a couple 1/8 punches
#135 (permalink) |
lets go Squatchen
Member # 14561
everything bolted down tight
#136 (permalink) |
lets go Squatchen
Member # 14561
Starting the bend
#137 (permalink) |
lets go Squatchen
Member # 14561
Little heat and 8oz ball pean to de-stress the corners
#138 (permalink) |
lets go Squatchen
Member # 14561
Bending the top rails
#139 (permalink) |
lets go Squatchen
Member # 14561
A pair of bent flats (flats I made my self
#140 (permalink) |
lets go Squatchen
Member # 14561
The FAK-47 is starting to really come together
#141 (permalink) |
Member # 6291
nice work man! You making your own rails too?
you going to heat treat them?
[list][*][url="http://www.pirate4x4.com/forum/showthread.php?t=373488"][COLOR=lime]For sale: Ford D60 parts, D44 steering arms, etc ... [/COLOR] [/url] [/list] |
#142 (permalink) | |
lets go Squatchen
Member # 14561
Yes, probably from some 1x1x1/8 angle Yes
#145 (permalink) | |
please fix my runner
hope he threaded it or pinned it on...I have watched them fly downrange with the bullet...
4.3runner ---A golf course is a pointless exploitation of a perfectly good rifle range--- buy my ultra rare Omega III presentation rifle special price $42500.00 |
#146 (permalink) | |
lets go Squatchen
Member # 14561
FAL parts. Brake, gas block, gas regulator, and gas block plug. Most of this stuff is a buck or two from Tapco so I ordered a bunch of parts. Thats why I call it the FAK-47 ![]() Barrel is cut down. FAL gas block actually is a press fit over the brake and then the brake is a press fit onto the barrel. It will get drilled and pinned. Inside of the gas block gets reemed for the piston, stock is threaded for the FAL gas tube. Regulator is going to be functional. Barrel is 16.5". With the folding stock its going to make a great little truck carbine. My next build is going to use a FAL barrel, piston, and gas tube. 7.62 nato AK ![]() Pete
Want to know how I lost 25lbs in 9 weeks? Try INSANITY®. www.beachbodycoach.com/petermhope I love it when a plan comes together Colorado Springs, CO Based FFL-07/SOT Last edited by aloharover; 01-30-2006 at 12:34 AM. |
#147 (permalink) | |
lets go Squatchen
Member # 14561
All I can say is if you don't have a variable speed dremel yet get one. I use a fiber disc to cut off the heads of the rivets, then pry the receiver off the trunion. Makes it easy to determin the exact size of the rivit and its center prior to drilling. Use the fiber wheels and smaller cutting wheels to do all the openings and trim the rails. Carbide cutter for general shaping, finish with sanding drums, or files. They make an attachment for the Dremel so you can use a drill bit thingy for cutting sheetrock and stuff, kinda like a Rotozip. That attachment actually makes a perfect depth gauge when used with the cut off wheel for triming the rails. Makes a perfect straight cut. Polishing wheels and bonnets to clean up feed ramps and stuff (ok mostly for the 1911s)
#148 (permalink) | |
cut off rivet heads with 4.5" grinder not giving a fuck if I chew up the receiver leftovers a little pry off receiver stubs sand rivet stumps smooth to the trunnion with the dremel sanding disks center punch the rivets drill a guide hole in the rivet using a small bit drill out rivet to a few sizes smaller than what i will be tapping/riveting it to remove rivet bits or grind them out the rest of the way with THE GOD OF ALL DREMEL BITS !!! the tungsten carbide cutter !! (large image so you may worship it) ![]() The rear trunnion rivets I keep drilling larger till they "get stuck" on the drill bit and then pull them out using the bit.
#149 (permalink) | |
lets go Squatchen
Member # 14561
The idea is from Sangrun's thread over at gunco http://www.gunco.net/forums/showthread.php?t=18008 BTW the link is a pretty nice write up with lots of photos.
#150 (permalink) |
lets go Squatchen
Member # 14561
OK, here is the current state of the FAK-47.
Passes the functions check. 16.5" bbl but thing still almost feels like a pistol. I really like the balance. Going to make the perfect truck carbine. Thinking about saving up for an Eotech site. Only a few items left on the to-do: 1- drill and pin the front gas block 2- make and install the cross support 3- drill holes for rear trunion. 4- heat FCG holes and rails. 5- order an ace skeleton side folder (will use old wood until it arrives) 6- finish the gas tube heat shield/rail mount (that can wait) I might just be able to test fire it this week end. ![]() Then can disassemble, blast, and paint. ps. I only photochopped the background so as to not further offend Doc.
Want to know how I lost 25lbs in 9 weeks? Try INSANITY®. www.beachbodycoach.com/petermhope I love it when a plan comes together Colorado Springs, CO Based FFL-07/SOT Last edited by aloharover; 02-09-2006 at 01:04 PM. |
