more time off work, muzzle brake time. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-19-2007, 06:34 PM   #1 (permalink)
SHOOT TO THRILL!
300sniper's Avatar
Member # 26382
i'm off work again this week because of the weather. time to mess around in the shop. i have had a couple muzzle brake designs in my head for a while. i decided to make one of the designs i had been thinking about. i just used cold rolled steel for this. if i like it i will make it again out of 4130 or 4140. it would take less than an hour to make a duplicate now that i have the program written.
here is what i came up with today:
i didn't take any pictures of it on the lathe but it looked just like this when it came off. i made the bar that is in the chuck to hold the muzzle brake during the milling operations. it is threaded to 3/4-28.
i center drilled and then drilled holes to give the end mill some where to enter.
cutting the ports with a 1/4" end mill.
ports cut.
300sniper is online now   Reply With Quote
Old 12-19-2007, 06:40 PM   #2 (permalink)
SHOOT TO THRILL!
300sniper's Avatar
Member # 26382
i used a 1-1/4" 6 flute end mill as a face mill to make some flats on the top and bottom of the brake.
one of the flats.
i wanted a 1" hex head at the rear. two flats for a wrench would have been enough but i thought this would look tougher. i kept the 1-1/4" end mill in for this operation.
hex head finished.
Old 12-19-2007, 06:44 PM   #3 (permalink)
SHOOT TO THRILL!
300sniper's Avatar
Member # 26382
removing the brake from the 3/4-28 threaded bar.
back view of the brake.
front.
and the side.
Old 12-19-2007, 06:44 PM   #4 (permalink)
PONY_DRIVER's Avatar
Member # 44662
I'm still jealous. Looks good, whatcha screwing it onto?
"I'm strangely comfortable with it."
PONY_DRIVER is offline   Reply With Quote
Old 12-19-2007, 06:47 PM   #5 (permalink)
SHOOT TO THRILL!
300sniper's Avatar
Member # 26382
i couldn't have a shiny brake so i tossed it into the blast cabinet.
i want to stick it back in the lathe and radius the edges on the hex head just a bit.
Old 12-19-2007, 06:52 PM   #6 (permalink)
SHOOT TO THRILL!
300sniper's Avatar
Member # 26382
i plan on threading the barrel of my htr so i will use it as a guinea pig testing the effectiveness of my creations. the factory loads in 300 win mag don't bother me but i plan on hand loading some hotter loads in the near future. i need to order a range rod to indicate the bore in the lathe before i thread it.
once the bore of the barrel is indicated in the lathe i will cut the threads. while the barrel is still in the lathe i will thread on the brake and use a boring bar to bore out the holes in the baffles to .015 over the bullet diameter. i will also open up the crown on the brake a little bit more.
Old 12-19-2007, 06:52 PM   #7 (permalink)
Member # 29385
Looks good. How involved is it to angle the ports back a couple of degrees?
[QUOTE=cdubzon40s]
matts what are you gonna do that would make my like miserable? kicking me off this lame ass site wouldnt mean a damn thing to me haha losers[/QUOTE]
Fisheadgib is offline   Reply With Quote
Old 12-19-2007, 06:55 PM   #8 (permalink)
SHOOT TO THRILL!
300sniper's Avatar
Member # 26382
with my 4 axis mill, it would be pretty tough. i think with something like a bridgeport mill you could angle the head to do it pretty easily.
Old 12-19-2007, 07:07 PM   #9 (permalink)
Fistful of Boomstick
usmcdoc14's Avatar
Member # 13344
Send a message via AIM to usmcdoc14 Send a message via Yahoo to usmcdoc14
it needs some sort or radius or transition from the round to hex. I liked it "pre-hex" better
as for angling the ports back you could use a dovetail cutter on just the back side of the ports and it would effectively aim the blast back.
Doc-14 Tactical Products:
When it absolutely, positively needs to be made from random crap found in the back of my garage.
You cant ban knowledge, learn to make your own guns right Here.
New York, Colorado, Maryland, Conneticut….is your state next? Yes it is. Write, Vote and Fight.
usmcdoc14 is offline   Reply With Quote
Old 12-19-2007, 07:16 PM   #10 (permalink)
SHOOT TO THRILL!
300sniper's Avatar
Member # 26382
i'm not real sure how i feel about the hex myself. this is just experimenting right now. i am not very concerned with aiming the ports back. from everything i have read, porting directly out the sides is going to work just fine.
Old 12-19-2007, 07:28 PM   #11 (permalink)
Weasel's Avatar
Member # 5639
That was my first reaction, but radius and fillets take some time. Looks way better with therm though IMO.
Just Add Lightness
I'd rather be simple-and-wrong than complicated-and-wrong.
Weasel is offline   Reply With Quote
Old 12-19-2007, 07:39 PM   #12 (permalink)
Keith Strong's Avatar
Member # 477
Send a message via Yahoo to Keith Strong
Needs more triangulation
When you decide you dont like that one you can give it to me
[CENTER][SIZE="5"][URL="http://www.strong-arms.com"]Strong Arms "Survival Slings" For Sale PM me for a PBB only price[/URL]
[/SIZE][/CENTER]
Keith Strong is offline   Reply With Quote
Old 12-19-2007, 08:48 PM   #13 (permalink)
lets go Squatchen
aloharover's Avatar
Member # 14561
Hmmm, wonder how that would work on a Saiga
Want to know how I lost 25lbs in 9 weeks? Try INSANITY®.
www.beachbodycoach.com/petermhope
I love it when a plan comes together
Colorado Springs, CO Based FFL-07/SOT
aloharover is offline   Reply With Quote
