Stock painting question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-29-2008, 02:38 PM   #1 (permalink)
Stay the Trail
mrboyle's Avatar
Member # 3937
I have a Savage model 116 30-06 that I only use for dynamite shoots (not a hunting rifle). It has a composite stock on it and I was wondering if it could be painted? The reason I ask is a friend of mine is an airbrush artist and he owes me a favor or two so I was thinking since its just a play toy (not going to be used for hunting) why not have him paint up the stock? He will be using automotive quality urathane paints (if that matters). Will the plastic/composite take paint or will it just flake off every time you touch it? Would a wood stock be a better option? Thanks in advance!
Mike Boyle
1980 Toyota PU
"Those who hammer their guns into plows will plow for those who do not..." - Thomas Jefferson.
Battlement Fab
mrboyle is offline   Reply With Quote
Old 08-29-2008, 02:47 PM   #2 (permalink)
Member # 21479
Send a message via Yahoo to JeepinHank
I believe you will find the answers you seek in these two threads:
http://www.pirate4x4.com/forum/showt...e+camo+pattern
http://www.pirate4x4.com/forum/showt...ht=parkerizing
Almost positive painting of stocks is discussed in the home camo pattern thread.
JeepinHank is offline   Reply With Quote
Old 08-29-2008, 03:30 PM   #3 (permalink)
Axes of E-ville
Aces'n'8s's Avatar
Member # 48097
You can use automotive paint, I've used Dupont Chromabase, but you will need an adhesion promoter. Sure you can paint right over nylon/composite with enamel/urethane/poly, but I wouldn't run the risk of spider cracks and possibly flaking.
You do NOT want to get that stuff on your skin. It has a similar burn feel as chemical stripper....and if you're sweating....it's a lot worse. Use a proper respirator as well.
Aces'n'8s is offline   Reply With Quote
Old 08-29-2008, 11:20 PM   #4 (permalink)
tjsjr's Avatar
Member # 101572
"you" dont paint stocks, you send them to Doc duh
[QUOTE=4runner] Once you start tinkering, eveery gun gets tinked.[/QUOTE]
tjsjr is offline   Reply With Quote
Old 08-29-2008, 11:40 PM   #5 (permalink)
Stay the Trail
mrboyle's Avatar
Member # 3937
I have read both of the threads and both only mention painting with Duracote on synthetic stocks. I also have read the thread about Duracote being re-packaged Shermin Williams paint and from what I gathered in that thread Duracote is a different type of paint than most automotive urathane paints, so I wasn't sure if the urathane would work like the Duracote.
So you are saying it isn't worth it, as in the paint won't adhear properly?
Mike Boyle
1980 Toyota PU
Battlement Fab
Old 08-29-2008, 11:41 PM   #6 (permalink)
Stay the Trail
mrboyle's Avatar
Member # 3937
"I" wont be painting the stock.
Mike Boyle
1980 Toyota PU
Battlement Fab
Old 08-30-2008, 07:05 AM   #7 (permalink)
Axes of E-ville
Aces'n'8s's Avatar
Member # 48097
No at all. If that's what you want, it's completely worth it. I'm just relating that my experience has shown me "adhesion" to a plastic substrate requires just a little more prep than painting over metal/wood. However, that's using automotive grade paint.
Who knows? Maybe that plastic rated Krylon works much better at 1/10 the cost?
Old 08-30-2008, 08:21 AM   #8 (permalink)
Stay the Trail
mrboyle's Avatar
Member # 3937
Thanks for the input. The guy painting it does a lot of motorcycles and helmets so he has experience with painting plastics. I know that some plastics are a lot harder to get good adheasion on than others and that's kinda why I threw the question up here (to see if anyone else has had any experience with the subject).
Mike Boyle
1980 Toyota PU
Battlement Fab
Old 08-30-2008, 07:51 PM   #9 (permalink)
F the Gub'ment!
soilantgreen's Avatar
Member # 70321
Location: Writing angry letters to anti-2A legislators--like you should be doing!
Painting plastic is accomplished with a proper adhesion promoter.
First clean the plastic with Matthews Paint Company's Plastic Prep.
Next spray two medium wet coats of Matthews Tie Bond. This is the adhesion promoter for all plastics except polyethelene and polypropolene. When the solvent "flashes" and loses its wet look, it is ready for the topcoat.
Finally, spray two coats of Matthews Acrylic Polyurethane. An automotive urethane like PPG's Deltron, Global, or Autokolor 2K will also work.
Tech sheets are here...
Plastic Prep...
http://corporateportal.ppg.com/NR/rd...3/0/MPC171.pdf
Tie Bond...
http://corporateportal.ppg.com/NR/rd...16074777SP.pdf
Topcoats in 54,000 colors...
http://corporateportal.ppg.com/NA/Re...s/topcoats.htm
http://www.spiderwebshade.com/
soilantgreen is offline   Reply With Quote
Old 08-31-2008, 12:03 PM   #10 (permalink)
Stay the Trail
mrboyle's Avatar
Member # 3937
Thanks for the info. After looking yestreday I think I'm going to get a thumb hole stock for the rifle and have it painted instead of the factory stock.
Mike Boyle
1980 Toyota PU
Battlement Fab
Old 08-31-2008, 01:28 PM   #11 (permalink)
F the Gub'ment!
Member # 70321
You mean I posted all those links for nothing?
